Cab Differences 67-72?
Hi
I was wondering what differences there were between the 67 thru 72 cabs.I know there is that "vent" at the door jamb on the later models,but was wondering if there were any more differences or anything stopping me from using my 67/68 front sheetmetal and doors on a later cab? I will eventually need to find a "decent" cab to rebuild as the one on my 68 is well beyond repair,and would rather not use the one off my 67 while iam using it for daily trransportation. Thanks RaTTrap 68 ![]() |
its all about the +6 inches
The main things are as follows, and please add more if i forget or am unaware of anything.
67 small window, hand brake 68 hand brake 69/70 foot brake. Also 69 first year for cargo light (and dome light door pins maybe?) 71 cable throttle 72 no mirror holes in cab metal, and door vent. |
It seems like a while back I saw something about 71-2's & 67-70's actually had different windshields but I'm not 100% sure what the diff was supposed to be. Can anyone confirm this?
Same windshield but the windshield gasket is different if it has the stainless trim.
Rest in Peace Ed. Thanks for all the good times. |
I need another Barley Pop
Longhornmail, some 67's had the "Panoramic View" option which has the big back window. My 67 has this option. I'm sure you know this already so I'm just adding what you left out.
67 Short Fleet 4x4 04 Honda CRF450R 89 Toyota 4-Runner 34 Ford 2 door sedan - Long term project ---------------------------------------------- There is a very fine line between "hobby" and "mental illness" ![]() |
Very true Pont. Thank you.
Like I said, I am sure I left some things out...please keep adding them. |
![]() Join Date: Dec 1999
I friend of mine had over 30 trucks at his place. I noticed the 71's had a raised place for the rear view mirror to mount. None of the 67-70 had this. Anybody confirm or deny.
72 Shortbed fleetside 402 BB, AC, Posi 72 Super Cheyenne Longbed 350 49,000 original miles and My dad ordered it new 66 Chevy Caprice 2 dr 74 Honda CB750 New Palestine, IN |
Seņor Member
What about--
firewall is embossed differently on the driver's side little metal balls in floor under gas pedal rearview mirror mount Kenneth
TOTY 2006
dashboard is different from an early 67 then later 67-72. Ashtry is different. Ignition switch hole is different. I think lighter hole is different too...
Recovering 67-72 Addict
![]() Join Date: Oct 2000
Wiper/Light controls are also in different locations on the dash as well as an additional location for choke cable in 67 and 68's.
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt. "Friends call me cruzer cuz I like fast cars and fast women" |
