Transcendental Trucker
Are valve seals just supposed to.. slip out?
Okie, pulled my valve covers to adjust the valves today.. (made quite a difference, BTW.
![]() I was under the impression that valve seals are locked in there pretty well, and that they just don't fly out randomly.. am I wrong? None of my valve springs are broken.. I haven't been floating valves lately.. though maybe my Dad was, he drove my Chevy for a week. So, er, how the hell did this thing come out?! And maybe more importantly, how do I get it back in? There are no big blue clouds of smoke coming out my exhaust.. yet..
Patrick Sullivan | sullivan@oregoncoast.com Rockaway Beach, Oregon 1972 Chevy Cheyenne C-20 1998 Dodge Dakota 4x4 So, fill to me the parting glass And drink a health whate'er befalls... Then gently rise and softly call Goodnight and joy be to you all! |
MAybe it was left over from the rebuild? If it has no tears in it thats the only way it could be there. If you find a valve with no seal on it all you have to do is get a valve compressor (the kind you can use with the heads on the block). Its just a lever you bolt down to the rocker stud. THen all you gotta do is pull the keeper clips out, stuff seal in, re-install keepers and adjust rockers.
Good Luck. CoryM
1970 heavy duty C-10 fleetside sport truck. Vancouver B.C. Canada http://www.geocities.com/chevroletc1070 "Take up our quarrel with the foe: To you from failing hands we throw The torch; be yours to hold it high." Lieutenant Colonel John McCrae, Canadian Army |
Engine has never been rebuilt as far as I know, at least not since I have owned it.. and I have had the valve covers off before. It is solid, though hard and worn, it was definately being used before it, er, slipped out.
Now where does the valve seal sit on things? On top of the spring?
Quick pic 1
Quick pic 2 - is it supposed to be taller? It looks like it sheared in the middle or something.. I didn't find another half.. it's rough on one side either way.
cracker
hey what is the diameter of that thing? not sure from the pic, but if is bigger then about 1/4 -3/8 of an inch, then its not a valve seal.
FOUNDING MEMBER OF THE DRUM BRAKE CLUB Harry John Albert III located in Phoenix, AZ 1972 GMC JIMMY, 1969 lwb Chevy Frame, 1999 bmw k1200 ltc 1992 Kawasaki concours 1991 bmw k75 1973 cortez motorhome |
cracker
thats not a valve seal, its probalbly your pcv valvegrommetg, or your breather grommet
Oo I am stupid, I somehow connected the rubber thing being the same diameter as the spring with it being a valve seal of some sort..
![]() Except I'm not missing a grommet, either.. hahah. Was wondering how the stuffed this thing around the valve stem.. :p Thanks.
cracker
what looks like happened is your grommet ripped in half, and that half fell in, the other half is probalbly still sitting in you valve cover, take a look and see if they mate up
![]() Join Date: Dec 2001
Or, if your truck is like mine, they were probably all old and crusty and brittle, the guy that changed them before probably ripped one, left the piece in there without taking the valve cover off and getting it out, and you found it. That almost happened to me, I was changing the grommets and a piece fell in, but I fished in there with a flashlight and a good pair of needlenose pliers and got it out. If it was during the day, I would have taken the cover off-but this was at night.
1942 Master Deluxe 1969 C/10 1985 Blazer CUCV 1987 Jimmy 2004 Tahoe 2005 Silverado 1500 2005 Silverado 3500 |
