08-25-2007, 11:27 PM | #1 |
I think there's somethin' wrong with my lockouts
Got the blazer home,the PO said the front hub on one side needs worked on...I grabbed hold of it and it turns completly around. I don't know what to expect when I take the lockout off..I hope I can just get by with swapping out a lockout..What a shame,they are the original blue ones..I've got some mile marker ones somewhere...Will lockout hubs from a corp. 10 bolt fit on the dana 44?
08-26-2007, 09:14 AM | #2 |
Re: I think there's somethin' wrong with my lockouts
From what I've read before they should. Never personally tried it.
08-26-2007, 12:47 PM | #3 |
Everything is work in progress
Stepside, take a look at this diagram. If this is your hub there is only a a couple of reasons that it can turn all the way around. Hope this helps.
Good luck with your truck! How much?! It's just an old truck part!! 49 International on a 80 GMC 3/4ton 4x4 chassis 48 International KB-5 2 ton dump bed 04 Honda CRF "500" 09 Honda CRF450 fuel injected rocket 03 Suzuki hayabusa carbonfiber wheeled monster. 02 Ford diesel stretch van (toy hauler) 01 38' Monaco diesel pusher motorhome |
08-26-2007, 12:47 PM | #4 |
Opps I mean this diagram.
http://www2.dana.com/pdf/5306-1.PDF
08-26-2007, 02:37 PM | #5 |
I have the set off my 68... You can probably use the guts and your outers and be original... Let me know...
Yes, any 1/2T Dana44 lockout will work on the 1/2T corp 10 and vice versa...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
08-26-2007, 09:41 PM | #6 |
Thanks for the offer Mike..I think I'm just going to use the ones from the corp 10 bolt I got from the wrecked '79...
I took the blazer out and tried it..Both wheels were pulling with the hubs engaged and the one that spins all the way around in the proper spot where it should be to lock it in. Last edited by 1969k10stepside; 08-26-2007 at 09:42 PM. |
