09-06-2007, 09:09 AM | #1 |
2" drop & tire rub!?.
I finally finished my front disc conversion (2" drop spindles) on my '70 C-10. When I go over a bump, my front right tire rubs.
I'm running 255/60/15's (27" tall) all around. Anyone else running similar tires & having / not having similar problems?
85' CUCV M1009!!! The newest addition! 6.2diesel, Th400, NP208, & only 36k miles! 70' C-10 LWB Fleetside - Looking good these days! 05' Dodge Neon 88' Winner Escape Sport 1750 - 4.3v6 94' Seadoo SP 84' Honda TRX200, bare nekkid. Just a frame & tires. Always looking for another project or any good deal! |
09-06-2007, 10:45 AM | #2 |
Next project: 1970 K10
Re: 2" drop & tire rub!?.
Rubbing on what?
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
09-06-2007, 11:21 AM | #3 |
I'm guessing its hitting the fender/inner fender well.
09-06-2007, 11:37 AM | #4 |
Hmm, that's not an unusual size tire. I'm running 245/60/15's with 2.5" drop spindles and I'm not close anywhere. I know there are a lot of lowered trucks running 255's.
How wide are your rims, and is the offset normal, or are they pretty deep? You might try some plain ol' masking tape run around the inside lip of the fender (and wherever else you think it might be rubbing) and go for a drive and look at the tape to see if you can tell where it is hitting. The tape should have some scuff marks wherever they hit.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE Last edited by glock35ipsc; 09-06-2007 at 11:39 AM. |
09-06-2007, 12:05 PM | #5 |
I have drop spindles 2.5 inch and drop coils on my 67. I had 17" rims originally with this set up but it was bad. In my neighborhood which is a newer area great streets and all I was rubbing frame and wheel wells. I went with 20" rims which raised the truck up. But even now when I hit dips in roads going semi fast it rubbs wheel wells. If I had to do it again I would go with spindles that accept disc brakes with NO DROP AT ALL. here is my current set up pic.
09-06-2007, 12:16 PM | #6 |
Out of the carpool lane.
I have a 4" drop up front and was running 275 wide tires on an 8" rim. I didn't get any rubbing at all- ever. I've now got 245's on the same rim just for appearances.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
09-06-2007, 01:36 PM | #7 |
I'm thinking that if I had to do it again, I'd go stock height.
I'm running 10" wide rims front & back. About 5.5" backspace & 4.5" on the front side. Glock 35, Great idea on the masking tape!
09-06-2007, 03:00 PM | #8 |
I can only guess at this point that the 10" wide rims on the front are the culprit. There are a ton of trucks running around with drop spindles, and spindles and drop springs, that have never had a problem. That's why I am guessing the 10" rims may have the tire out too far.
*** Woo-Hoo! I just hit 2500 posts!
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE Last edited by glock35ipsc; 09-06-2007 at 03:03 PM. |
09-06-2007, 03:11 PM | #9 |
Burnouts are therapeutic
you can use a spacer to possible solve this problem I have two quarter inch spacers on rear of mine, that is if its rubbing on inside of fender well.
1969 CHEVELLE SS 1972 C10 ALMOST DAILY DRIVER 1968 C10 RUSTBUCKET (MISSION IMPOSSIBLE) 1972 PONTIAC LEMANS CONVERTIBLE (WIFE'S CAR) "My wife and I were happy for twenty years. Then we met." - Rodney Dangerfield "The difference between genius and stupidity is that genius has its limits." - Einstein |
09-06-2007, 03:24 PM | #10 |
Um, wouldn't that just push them farther into the fender?? Might work if the rub was occurring when making a turn, but it sounds like it happens just when he hits a bump.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE Last edited by glock35ipsc; 09-06-2007 at 03:25 PM. |
09-06-2007, 05:24 PM | #11 |
if its rubbing on the inner fender towards the framerails then a spacer sounds like it would work but if its hitting the inside of the fender then it would make it worse.
(Only) Member of the CPNE Fan Club Aint that the truth 67 C-10 350 with 3-speed tranny and 308 gears swb step 82 Z28 Camaro 355 small block over 350 hp and a borg warner super t-10 (blown engine) 72 Chevy K20 Suburban (future project) 70 Chevy K20 now 68 GMC K2500 2003 Chevy 2500hd ccsb 4X4 (daily driver) |
09-06-2007, 05:33 PM | #12 |
make sure it isn't the WHEEL rubbing on the LOWER CONTROL ARM ...
09-06-2007, 06:14 PM | #13 |
Old Skool Club
Too much back space, with the 10-inch wheel width.
When I did my conversion, using ECE 2.5-inch dropped spindles, I reinstalled the 8-inch wide wheels I had been running. The disc conversion created a wider track width in the front and the 255-70's would contact the inner lip of the front fenders. I changed them to a 15x7, same size tire, and solve my problem.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
09-06-2007, 10:38 PM | #14 |
I'll definately check on that.
Thanks everyone for all the good help. Hopefully a thinner rim will fix the problem. I'm really hoping to go with a taller tire, something like 255/70 instead of 255/60's. John
09-07-2007, 06:03 AM | #15 |
It`s the 10" rims with the deeper dish.The wide track look gave way to lower stance/8" max. front rims.Some question how to keep rear 10" from rubbing.I`ve seen up to 295s work out back on 10s.I like 10s out back,but desided to keep the combo square to keep rotation possible.Mine`s getting built to travel.
09-07-2007, 03:21 PM | #16 |
I'm getting an alignment today, that may help some.
What do you think about 235/75x25 on 15x7's or 30x9.5x15 on 15x7? Am i wasting my time? Anyone see any problems with 31x10.5x15's in back on either 15x7's or 15x10's?
09-10-2007, 01:34 PM | #17 |
FYI, I think i found the problem. The inner fender on the right side doesn't fit quite right. I remember having difficulties when putting the fenders back on after paint.
I think the P.O. replaced the inner fender w/ the wrong one. It looks right, but the holes to the outer fender don't line up right.
09-10-2007, 02:04 PM | #18 |
That might be a big part but my guess is w/10" front wheels, you're still going to rub.
For reference, I had 15x6.5" ralleys w/215-75/15's @ 27.5" tall w/2.5" drop spindles & 1-coil cut from the original stock springs & rarely buzzed (only on large dips @ speed).
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 09-10-2007 at 02:06 PM. |
09-10-2007, 03:30 PM | #19 |
I have 10 inch wide rims all around, and I beleive the drop is 2 inches. I do not have this problem. Mine are:
Front tires are 255 60 15 and the rears are 275 60 15's. |
09-10-2007, 06:24 PM | #20 |
Old Skool Club
[QUOTE=rcheesem;2351748]I have 10 inch wide rims QUOTE]
I am running the hot rod trim rings on my wheels....which trim rings are you running on yours? I couldn't picture in my mind, the way that they would look.
09-11-2007, 10:26 AM | #21 |
[QUOTE=ChevLoRay;2352010]I'll try and find out. They were on it when I got it. They have little chevy bowties molded in them if that helps. I will look around.
