09-10-2007, 12:10 AM | #1 |
Help Speedo to NP205 thingy
Does anybody know what that thing is called that is some kida of gear convert that goes from the NP205 to the speedo cable. Its an L shaped box and with female connector on one side and a male on the other. I had to replace my speedo cable and when I was removing it I noticed the screws that held that thing to gether had kinda fallen out and it was not closed all the way. I opened it up to check the inside and like an idiot I let the double sided gear in the middle fall out. I can't figure out which way to put it back in. It has more teeth on one side or the other.
Thanks -Jason Ok I figured out its called a ratio adapter.
- Jason Orange Crush - 1969 K5 Blazer CST 4WD MONEY PIT 1975 CJ5 Renegade - Levi's Edition - 304 V8 original paint Last edited by CJ5 Convert; 09-10-2007 at 12:46 AM. |
09-10-2007, 01:29 AM | #2 |
Out of the carpool lane.
Re: Help Speedo to NP205 thingy
I had one of these a long time and just sold it last week. Had you been a week earlier, I could've helped you figure out how it goes together! Perhaps you can email the company you got that pic from and ask them.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
09-10-2007, 01:56 AM | #3 |
Brad now that I've figured out what it does I guess I'll just put it together. The middle carrier gear (it's actually a double gear stacked and it ties together the input and output gear) is my problem at first glance it looks like a 1:1 gear but it's not. One side has a few more teeth. It seems to go in either way it just clicks louder when it's in one way. Also what the heck were these things lubed with? was it gear oil? Could I just pack this thing with grease?
- Jason Orange Crush - 1969 K5 Blazer CST 4WD MONEY PIT 1975 CJ5 Renegade - Levi's Edition - 304 V8 original paint |
09-10-2007, 02:45 AM | #4 |
I'm sure you could probably pack it with bearing grease and call it good.
09-10-2007, 08:51 AM | #5 |
So who sells a new one?? Mine is toast.
09-10-2007, 08:58 AM | #6 |
This is were I found that pic
http://www.transmissioncenter.net/sp...n_______va.htm mine is made by stewart-warner and if you search that with ratio adapter it will come up a bunch of places.
09-10-2007, 09:07 AM | #7 |
Active Member
Re: greasing the box. I would use white lithium grease.
09-10-2007, 09:33 AM | #8 |
Thanks 68 GMC. My big question now is which way soes this dumb gear go in. But I guess if I put it in th wrong way I'll know it quick enough and I can swap it.
- Jason Orange Crush - 1969 K5 Blazer CST 4WD MONEY PIT 1975 CJ5 Renegade - Levi's Edition - 304 V8 original paint Last edited by CJ5 Convert; 09-10-2007 at 09:33 AM. Reason: bad spellin |
09-10-2007, 09:40 AM | #9 |
Ya wanna know something sad...................I have that dang thing on my TRANSMISSION and the trucks only a 2 wheel drive . Sorry just seen the part and wanted to add my 2 cents.............I know way off the subject, sorry
"When you were born, you cried and the world rejoiced. Live your life so that when you die, the world cries and you rejoice." [Cherokee saying] 2001 Dodge Ram Sport 1500 4x4. (old ride) 1987 GMC V1500 Sierra Classic ("new" ride) |
09-10-2007, 09:47 AM | #10 | |
Active Member
I'm thinking of buying one of these once I determine what my exact ration percentage is. I've measured it with my wife going behind me on gravel road ( but no license plates yet) and at first it was off 15mph. I put a different gear in and now it's app. 5mph. But, it may be more or less once I get it checked out correctly. |
09-10-2007, 09:55 AM | #11 | |
Ha I'm fixin to change the tire size too so I guess it won't matter. Alot of the threads I saw last night said a speedo shop could adjust the gears in it.
09-10-2007, 03:56 PM | #12 |
Was Your Speedo Correct Before It Fell Apart? You Can Remove It And Your Cable Will Fit Direct Into Your T Case. Mine Did Because I Looked For Daus And Couldnt Find One So I Went Streight In. My Truck Is A 3/4 Ton W/410s. Its Within 2 Mph Of My Wifes Nw Envoy
72 2wd lwb cheyenne super youngest son.green/white 72 2wd lwb cheyenne super oldest son.green/white 71 4wd 3/4 cheyenne super frame off manderin copper / white 4 inch lift. FINALLY DONE / SOLD 72 4WD SWB CHEYENNE BLUE/WHITE 388 AUTO REMEMBER THE COPS NEVER THINK ITS AS FUNNY AS YOU DO. NORWOOD SURVIVOR COPPERTONE BUILD THREAD/ http://www.67-72chevytrucks.com/vboa...d.php?t=259856 |
09-10-2007, 04:36 PM | #13 |
So , do I understand the cable is a plug and play without this gadget??? Just put cable in transfercase????
Sounds too easy............. |
09-10-2007, 04:44 PM | #14 |
It Was Too Easy. I Couldnt Beleive It. Yours May Be Way Off?
09-10-2007, 04:47 PM | #15 |
Oh I Forgot That I Had To Get A 85 Inch Cable But Oreilly Had It In Stock. I Had A Freind Tell Me Later That The Peice Your Looking For Was Just To Make A 90. For Clearance Issues? I Dont Know
09-10-2007, 06:26 PM | #16 |
Thanks guys I'll try it both ways . All of those pages I found said it was for a situation where you couldn't get enough ratio change (by changing the ones in you T-case or Tranny) because you had had put some really low gears in the diffs.
