09-30-2002, 03:55 AM | #1 |
some parts sale
- 250 engine mount frame trees pairs
- pass side 292 tree(driver side is same as 250) - L-6 cyl engine bock mount brackets pairs - SBC V-8 frame trees pairs - other 6 cyl engine parts also - '55-68(-'72 truck) V-8 short pump pullies stuff -oil pans - '64-72 various leaf and coil rear truck chassis/frame parts and disc and drum related parts - 5 lug 12 bolt axle shaft pairs - good dana 60 3/4 ton axle for parts or whole, 4.56 and powrlok, 30 spline - long water pump a/c brackets set for 454, etc. - V-8 HEI distributor - 69-72 guages dash, no bezel - 67 CST dash knobs - assorted 68-72 CST dash knobs - NOS 292 emblem with GM box -1971 Chevrolet dealer communication inventory cleanup/sales kit with box, stil in pretty good shape, alot of goodies including films and some 45-records and some pamphlets and so forth - big 1979 Honda CM/CB400 motorcycle service book with original large three ring binder and wiring diagrams, etc - big block front springs - std front springs - front control arms for disc brake trucks, some for 71-72 and others for 73-up - front control arms for drum brake trucks - '64-87 engine cradles - pair of 5 lug 15" GM older painted wagons - pair of 6 lug 15" GM older painted wagons(both pairs accept the GM truck rally wheel caps and screws) - matched set of four older small nosed truck rally wheel caps - 4x4 203/th350/dana 44 frotnt driveshafts - clutch linkage parts of all kinds including frame mounted idler pivot bracket and block mounted idler ball pivot brackets, some for L-6 and some for SBC, no pedal assemblies right now though. - '73-up 454 frame trees pair( about 1" shorter than others) - 72 4x4 blazer rear driveshaft thatll work for now, if are interested in aything thne lemmew know and i can give details that you may want to know thanks Last edited by Fast68Chevy; 09-30-2002 at 04:09 AM. |
09-30-2002, 02:27 PM | #2 |
rear trailing arms
I'm looking for a set for my 69 SWB step
94 K1500 SWB w/ 4" body and suspension lift |
09-30-2002, 04:11 PM | #3 | |
Re: some parts sale
Do you have an unmodified air filter housing for a 250 with power brakes? That's the offset type. |
09-30-2002, 06:17 PM | #4 |
frame parts
hey randy, i do need the cross member that goes right behind the cab and the shock mount brackets for the rear. also a 454 oil pan. still working on the box jeff
10-01-2002, 03:50 PM | #5 | |
Re: rear trailing arms
thans |
10-01-2002, 03:52 PM | #6 | |
Re: Re: some parts sale
10-01-2002, 03:59 PM | #7 |
addition of a few more things:
addd few more items 11:04 pm 10/02/02:
-69-up 4x4 p/s box, $60 and some mail. '71-up dana 44 front with 3.07 and also all steering linkages and related parts and sway bar and all... $125 for axle and $75 for sway bar setup and $80 for leaves packs with load leveler leaves intact -5 lug 12 bolt axle shafts pair $30 -drums $15 pair -12 bolt 3.07 posi carrier, '75 or so- '81 unit $75 -12 bolt 3.07 gear set $25 -flywheels and flexplates, 25 and 15 -tall tranny tunnel pan for 67-72 2wd 4 speed $25 -various driveshafts one and two piece- $25 each, - manual trans flywheel inspection cover sets, $20 each set, for 72 and older trucks - various kickdown cables and dipstick tubes, $5 -73-80 complete cab wiring harness for auto trans and a/c trucks $35 -85 burb receiver hitch $23 -73-87 pickup real heavy reciever hitch $28 -manual trans cast iron thre bolt nosed starters, $15 each -SM318 tranny, $20 -newer replacement 6 cyl manifolds and head, etc -some 73-87 windshields $25 each -'64-'72 40" spring pack centers- 12 bolt truck rear posi axle housing, minus brake backing plates, $15 entire front third of a '73-87 rolling big block 3/4 ton 2wd chevy truck chassis in good shape, good for converting to disc brakes on 64-70 trucks, $50 or part out for BB springs and cradle and all control arms and spindles and rotors and so forth, spindles and arms and rotors can be mailed, i have extra rotors and shields also., also have a nice 2wd p/s gear box $40 plus mail,. wil remove andmail the sector shaft for use on 4x4 crossover conversion if you want., $30 plus the ride 74 tilt column in super excellent clean shape, $50 plus ride, steering wheel in same nice shape, $30 plus ride,. pair of 56" 8-leaf spring packs $45 plus ride, also U bolts and related too pair of '64-72 cast iron rear axle tube U bolt leaf clamps $20 and ride, other related parts too including leaf packs and original overload packs and such. 72 1/2 ton 2wd front disc brake entire assembly, parts or whole, good for converting 64-70 trucks to disc brakes., manual steering box for most all '68-older 4x4 and all 2wd '64-87 $25 and ride pair of optional 5 lug GM painted wagons, and pair of optional 6 lug GM painted wagons, both pairs accept GM truck rally caps and are 15" $25 a pair set of four 73-75 small nose truck rally wheel caps, screws on outside, these arent the common '76-86 rally caps you see around, but are very close to same. $40/all four more to add as i stumble across it.... thanks Last edited by Fast68Chevy; 10-02-2002 at 02:20 AM. |
10-01-2002, 04:01 PM | #8 | |
Re: frame parts
xmember and shock mounts for what year and what rear supension and for 2wd or 4x4 ? i have shock mount brackets for lower of coil rears and upper ones for leaf rear 64-72's 454 oil pan, hmm, dunno about that one, depends on if i part the 454 engine out, hate to though, its a rebuilt low miles one.,,,, no biggie on the bed, only one other person is interested in it if you arent, its up to you... thanks Last edited by Fast68Chevy; 10-01-2002 at 04:46 PM. |
10-01-2002, 09:37 PM | #9 |
pm
sent you a pm
10-02-2002, 01:10 AM | #10 |
Jeff, ok, got one sent back at ya
thanks Last edited by Fast68Chevy; 10-02-2002 at 02:21 AM. |
10-02-2002, 05:53 AM | #11 |
pm
sent pm
10-02-2002, 05:47 PM | #12 |
How much for the HEI distributor and wiper arms
10-02-2002, 08:56 PM | #13 |
It's just a check engine lamp.
How much for the 72 1/2 ton 2wd front disc brake entire assembly? Also, does the manual steering box for '68-older need to be rebuilt?
bigchevy66@hotmail.com
Active Inliner---bigchevy66 68 SWB Stepside 250 L6/3 on the floor/ Hedman headers, HEI, MSD 6A box, K&N filter, Offy intake and Edelbrock 600cfm 4 barrel Soon to have: WC T-5 five speed 66 SWB Stepside-undergoing restoration |
10-03-2002, 07:24 PM | #14 | |
thanks |
10-03-2002, 07:26 PM | #15 | |
35 for front entire assembly with cradle and all(cut frame rails behind shocks) ? |
10-03-2002, 07:33 PM | #16 |
Not the nightly winner
RANDY
PRICE ON 6 CYL. MANIFOLDS?? THANKS TODD.
72C10SWB BLUE 350/350 86K10LWB BLUE 5.7 700r4 7.5' fisher plow 93S10XCAB4X4 BLUE 4.3 4L60e 69gmc c10 v8 3 on the tree yellow 72k10 swb 350 3 on the tree green 86k15 swb5.0L 4spd brown |
10-03-2002, 09:38 PM | #17 |
sent ya PM
thanks Todd |
05-29-2003, 05:13 AM | #18 |
Do you still have the Dana 60 rear with coil springs?
Is it a full floater? Are the axles held on by bolts or studs with nuts? I am need of a 30 spline axle held on by stud/nuts and can't find one around here. Let me know thanks, Mike
Mike 1989 C1500 SWB Reg Cab 2003 Chevy Tahoe Z-71 70 Camaro RS/SS - 454 |
05-29-2003, 04:10 PM | #19 |
Sorry already got one have to pass.
05-29-2003, 07:57 PM | #20 |
Welcome Back !
69 Lwb C-10 402/700R4 70 Lwb C-10 250/3pd Wisc. |
05-29-2003, 09:07 PM | #21 |
Glad to see you here Fast
been awhile Bubba. Wootdog
1969 Chevelle 1990 IROC Z Convertible 2002 Silverado LT |
05-29-2003, 09:14 PM | #22 |
Take a look at the dates. Fast (randy) isn't back.
Fawker Fab three seater rock crawler buggy 498 BBC/SM465/203/205 doubler, propane, 5.13's, 42" PB Rockers '66 C10 - The new hot rod '77 3+3 Dually - 12 valve 4wd conversion tow rig project '28 Ford 2 door sedan street rod RevLimit Offroad "Hang on beer, we can do this." |
05-29-2003, 10:18 PM | #23 |
you are right
Wish he was. He is well versed in this hobby, and or obsession. Wootdog
