Formerly yellow72custom
Carb Spacer?
Since i will be replacing the base gasket on my carb, i was thinking about getting a 1" , 4-hole spacer for it. Would the spacer give me any more power, mpg, or is it just a waste of money? Which is better, the plastic or allumium spacer? My engine specs are in my signature....
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
![]() Join Date: Dec 1999
my opinion more oppurtunity for leaks,but keep fuel from boiling.id go plastic.i have several of those Mr Gaskets ones in a crate,i wont use one.but some say they are beneficial.
![]() Join Date: Sep 2002
torque
They help to build torque just like a high rise intake,same concept my race car buddy swares by them on a dirt track. I would go with an aluminum spacer as oposed to plastic simply because of how well alum. disapates heat.
67' Chevy C10 Lwb small rear window 71' Gmc 1500 custom 4x4 72' Gmc Grande Sierra |
I installed a 2 inch, 4 hole, plastic spacer mainly to insulate the carb and prevent the fuel from boiling, but as an added bonus, I also got a noticeable increase in torque on the bottom end.
"Negative people always seem to have a problem for every solution" |
its all about the +6 inches
It is a crap shoot really.
Car Craft has done a couple shoot outs on them, and they found that some are worth quite a bit, while others don't do squat. The funny thing is, the ones that don't do squat on one motor, will work awsome on another motor. I had one at one time on an internally stock motor, and it did in fact make more torque, and helped my MPG. |
