Old 09-26-2007, 01:32 PM   #1
66skylarkpost
66skylarkpost's Avatar
12 bolt axle carnage
this is out of a buddy's ' 85 long box with 33" bfg all terrains . he swaped out the axles and springs last year from an old farm beater ( 3.42 10-bolt and 12 bolt/ 6 inch superlift front springs and 4 " springs and 2 "blocks out back ) . then i guess last week he was tearing it up around town , and luckily he was near his house and heared a loud " clank " . locked it in 4 wheel and limped it home . i just thought i'd share
'70 k-10 longbox- mid 70's drivetrain 350/350 487x heads 10.1:1 flowmasters ,35's 3.73's auburn posi ,rear shackle flip. '72 short stepside U.S. forestry truck, '73 455 buick,400 turbo,dropped 2"-4 1/4" ,3.07 posi,:'89 silverado 1500 ,OK truck ,5.7 holley tbi ,trick 700r4 3.07 auburn posi ,and my '66 skylark ,'73 centurion and my '84 monte carlo imca stock car
66skylarkpost is offline   Reply With Quote
Old 09-27-2007, 06:20 AM   #2
vtblazer
vtblazer's Avatar
Re: 12 bolt axle carnage
A little surprised 33's did that to a 12 bolt.
Sounds like lots of tire smoke with a bad case of wheel hop thrown in.
vtblazer is offline   Reply With Quote
Old 09-27-2007, 10:48 AM   #3
Zoomad75
K5Camper
Zoomad75's Avatar
I'm thinking "tearing it up" is the right term. He must have been pushing the throttle through the floor to end up with that!
I've put lots of street miles on my 12 bolt with 33's and 35's and never broke it. But then again, I'm not out racing anyone either or really hammering on it hard.
Rob Z.
1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP
1991 K5 8.1L/NV4500/241/D44/14b FWC Camper
Zoomad75 is offline   Reply With Quote
Old 09-27-2007, 12:35 PM   #4
66skylarkpost
i'm sure he was tearing it up .it has a strong early 350 with 993 heads. when he called me , i was like " what are you talking about ?" ive ran many 12 bolts with 33's and 35's , the most ive seen is bent wheel flanges . ive broken teeth off gears , busted cross pins and carriers , and even broke off pinion yokes , but never broke and axle . the axles my buddy have are from an old farm truck , where it looked like it was rode hard and put away , ya know !
Old 09-27-2007, 04:52 PM   #5
Elwayno
Going from spinning to sticking on the street is very abrupt. Had a buddy spinning in the dirt from the side of the road and come on to the pavement and snap both axles when the tires suddenly gripped.
Elwayno is offline   Reply With Quote
Old 09-27-2007, 06:46 PM   #6
Zoomad75
K5Camper
Zoomad75's Avatar
That's probably how it happened. 33's have a pretty big contact patch so when it grabs, the torque has to go somewhere. I helped a guy snap his 10 bolt rear axle that way. During a block party for the Woodward Dream cruise back in Detroit we would all do burnouts on our street. One of the party attendees decides to try out his 84 K10 that's pretty much stock down to the 305, but lifted 4" and sitting on 33's. No amount of water poured out would help the 305 spin the right rear (open diff too). 5 of us lift up on the right rear corner of the bed/bumper to take enough load off of the tire to get it to spin. Just as planned it does and the smoke begins to roll. The five of us lifting see smoke and figure now that it's spinning it should keep spinning when we let go. I kid you not to say as soon as we let go the tire stopped spinning (the guy had his foot buried in the throttle) and we here a nice loud metallic *SNAP*. That was it! He dove a few blocks home on the front axle with a passenger in the bed to shove the wheel/axle assembly back into the axle when it started to wobble out.
We all warned him it was high probability that he would snap an axle shaft but he went for it. I laughed my arse off.
Rob Z.
Old 10-03-2007, 04:13 PM   #7
70rs/ss
70rs/ss's Avatar
That is why the $250 upgrade to new aftermarket axles is always a great idea!
70rs/ss is offline   Reply With Quote
Old 10-04-2007, 09:07 AM   #8
OLDCHEV4X4
OLDCHEV4X4's Avatar
I race a 12 bolt in my 72 Blazer with 33's. Only thing i ever broke was the spider gears.
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 10-04-2007, 10:38 AM   #9
jkaylor68gmc
jkaylor68gmc's Avatar
Ouch! That had to hurt,
Your axle called and it hates you.
1947 International KB-1
1957 Chevy Bel-Air riding low
1962 swb fleetside
2002 Chevrolet Silverado 7-inch lift on 35 Daily driver
2016 Chevy Tahoe Better halves ride
jkaylor68gmc is offline   Reply With Quote
Old 10-04-2007, 12:13 PM   #10
ND_guy
Tool Addiction=Money Shortage
ND_guy's Avatar
Four years ago in my 77 k5, the highway was a mix of glare ice and dry pavement. I was going about 50mph and locked in 4x4. I was on a dry section of road when the rear gear set locked up and instantly it broke the left 12 bolt shaft. Since the t-case was locked in a front axle steering u-joint and yoke shattered, giving me zero wheel drive. That day was very expensive. I had to buy a flatbed tow and a junk suburban for both axles. The axle swap was done in 10degree North Dakota and I don't plan on ever doing it again!
1967 K20 400TBI SM465/NP205
posi front, Detroit locker 4.56 rear
ND_guy is offline   Reply With Quote
Old 10-04-2007, 03:15 PM   #11
earl87gta
earl87gta's Avatar
time for the 14blt
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
Old 10-04-2007, 04:04 PM   #12
hilbilly
I do everything twice, so what
hilbilly's Avatar
Location: To the Right. One may go as far to say WAY to the Right
two Yukon 4340 fronts w/ CTM joints. snaped both at the same time. Good thing, 5 year warrenty
hilbilly is offline   Reply With Quote
