Old 09-30-2007, 02:00 PM   #1
usual510
usual510's Avatar
Whats the correct back seat???
I bought a rear seat for my 71 cst from a guy. He said its stock but there are no arm rests. ive seen a similar truck around town and his back seat has arm rests. It looked much better in his truck. Which one is correct?/or are they both correct????
usual510 is offline   Reply With Quote
Old 09-30-2007, 02:08 PM   #2
1969k10stepside
Re: Whats the correct back seat???
They had armrests stock but they may have been removed..
1969k10stepside is offline   Reply With Quote
Old 09-30-2007, 02:18 PM   #3
Classic Bowties
Always on the hunt...
The arm rest & support/mounting tube's are attached to the seat with only 3 screws per side and could have been removed from the seat at some point, I have seen it before. It's hard to know/say what you have for sure without any pics of your purchased seat. Does the seat have bent tubular type mounting frames under each fwd corner of the seat? Cb
Classic Bowties is offline   Reply With Quote
Old 10-01-2007, 04:05 PM   #4
usual510
usual510's Avatar
I dont see any mounts.I think the search continues. I guess i need ta find the seat with the arm rests...
Old 10-01-2007, 04:47 PM   #5
Burt4x4
Burt4x4's Avatar
Mine does not have armrests, as far as I know it's the original seat just recovered...
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 10-02-2007, 07:40 AM   #6
Mike C
Mike C's Avatar
I've never seen an original without the arm rests. Most likely they are removed. I have the tubes which help brace the seat, but the pads I removed nearly 20 years ago because they were unserviceable at that time. Most likely underneath the seat cover, the holes still exist to mount the tubular supports to which the arm rest pads attach.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 10-02-2007, 03:21 PM   #7
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
I have one done each way, cause I did it (Armrests)
Pic's of brackets and backside / bottom of a rear seat
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Big Piggy: "Goliath" 07 Kodiak C4500
Lil Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 10-02-2007, 04:53 PM   #8
Burt4x4
Burt4x4's Avatar
Yup, that looks like the bottom of mine...I must be in the "removed by prior owner" club!
