Old 10-01-2007, 09:44 AM   #1
fun in dirt
fun in dirt's Avatar
pics of bikini top, family cage, side panels & floor
Just about finished putting this ole Bucket back together this weekend. Took it all apart to install a family cage. Then decided might as well fix a few rust spots. So floors need painting again after all that, so might as well go ahead & do the spray in bed liner. Then decided to make some aluminum side panels for the rear. Also went ahead & cut up the softtop (that was missing hardware) & made a bikini top.
As the sticker on my rear bumper says "NEV-R-DONE"
I think it all turned out pretty good! So we're finally almost ready to leave on Thursday to go Cruisin' the Coast!
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432
'85 K30 "Big Nassy"
'06 3500 Duramax ...tow truck
'06 Silverado SS...DD
'06 C1500 WT...DD
'07 Classic C1500 WT...DD
Built & sold cause can't keep 'em all:
'72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190
'55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938
'69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541
'86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619
fun in dirt is offline   Reply With Quote
Old 10-01-2007, 09:48 AM   #2
Yukon Jack
Post Whore
Yukon Jack's Avatar
Re: pics of bikini top, family cage, side panels & floor
Looks great!
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 10-01-2007, 11:45 AM   #3
herb101
Used Register
herb101's Avatar
Awesome work for a single weekend - Heck, I just cleaned 1/2 of my garage (and only half-assed at that)!!
Looks great
Have you driven it around much with the new side panels in place? I'd like to do somthing similar, but was worried about the rattles and resonance of the metal panel. Have you seen any issues with that?
Thanks,
Herb
herb101 is offline   Reply With Quote
Old 10-01-2007, 11:56 AM   #4
fun in dirt
Looks great
Thanks,
Herb
THANKS! Actually we've been working on it for about 3 weeks, just got it all back together this weekend.
Side panels are real quiet... no noise at all. But I was sure to put plenty of screws in it, and also used 3/16 thick alum. tread plate. The thinner the material the more it will try to resonate.
'85 K30 "Big Nassy"
'06 C1500 WT...DD
Old 10-02-2007, 12:35 AM   #5
cablazer
70 4x4 k5 Blazer
cablazer's Avatar
Side panels look great. I was thinking of doing the same. What did you use to cut the them and did you have to grind the edges to make them clean?
cablazer is offline   Reply With Quote
Old 10-02-2007, 09:54 AM   #6
fun in dirt
Just used a jigsaw with a metal cutting blade in it and sprayed alot of WD-40 while cutting. The WD is very important or you'll burn up several blades & not get a clean cut. I didn't have to grind the edges (FYI - alum. will trash a grinding wheel). However, I may still go back & file the top edge a little smoother because my little boy likes to climb in over the side.
'85 K30 "Big Nassy"
'06 C1500 WT...DD
Old 10-02-2007, 03:15 PM   #7
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Very nice
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Big Piggy: "Goliath" 07 Kodiak C4500
Lil Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
