Old 10-21-2007, 11:20 PM   #1
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Power steering hose thru inner fender?
This is a pic of my 72 GMC with power steering. Notice there is a hole in the inner fender for the low pressure side of the power steering hose. Is this original? I've looked at other trucks with power steering and never seen that before. What do I need to route it around the inner fender like I think it's suppose to be?
2 wrongs don't make a right, but 3 lefts do.
66 Chevelle Malibu 406ci, 573hp, 10.99@121mph
96 Chevy Silverado Z71
72 GMC 1500 Super Custom LS 6.0/4L65 on airride
http://www.cardomain.com/ride/707879...mc-c-k-pick-up
chevydog66 is offline   Reply With Quote
Old 10-21-2007, 11:51 PM   #2
skokie
skokie's Avatar
Re: Power steering hose thru inner fender?
My 68 has the same hole. I took a quick check through my factory assembly manual and couldn't find anything.
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 10-21-2007, 11:56 PM   #3
68 P.O.S.
Umm, yeah, that's definitely a "custom" job there. In your picture you see how the other hose has a metal line at the box then hose connected to that...well, both hoses are supposed to have a metal line at the box. I bought my hoses at Napa, but for the return line, I had to buy the metal line from ECE.
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
Old 10-22-2007, 12:43 AM   #4
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
I have a '68 and '72, both with ps. neither has a small hole like that...rather a much larger half oval one that has a piece that bolts on to close the gap (in one form or another).
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 10-22-2007, 10:38 AM   #5
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
The paint on the top of the inner fender looks original. The metal from the hole that is punched is still there and visible on the top side. I can't imagine a 72 GMC coming out of the factory without p/s, can you? I mean it has A/C, and power front disc brakes. I have seen the 2 metal lines that curve around the bottom of the inner fender. I guess I need to call ECE and get the return line. I'm buying new inner fenders and the truck is coming apart and getting painted.
Old 10-22-2007, 10:44 AM   #6
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
So Skokie is the only other member with the same holy fender option?
Old 10-22-2007, 11:01 AM   #7
Dean
Dean's Avatar
I know if you put a steering box off a later model truck you will get into that. I put a new late model box on a K20 I used to have and had to drill a hole like that.
Dean is offline   Reply With Quote
Old 10-22-2007, 02:34 PM   #8
Lated
Lated's Avatar
My fender doesn't have a hole but it does appear to have been attacked with a pair of tin snips. Gotta love POs. Check out my lines and the awesome PS bracket made with angle iron and a lug nut. I would much rather just have hole drilled in the fender than this.
“If you don’t have time to do it right now, how will you ever find time to fix it.” - author unknown
'70 SWB Step-Side (More rust than metal)
Lated is offline   Reply With Quote
Old 10-22-2007, 03:00 PM   #9
grayw0lf
Wow! Thats classic. Very nice work. I'm sure the PO was quite proud of his handywork.
85' CUCV M1009!!! The newest addition!
6.2diesel, Th400, NP208, & only 36k miles!
70' C-10 LWB Fleetside - Looking good these days!
05' Dodge Neon
88' Winner Escape Sport 1750 - 4.3v6
94' Seadoo SP
84' Honda TRX200, bare nekkid. Just a frame & tires.
Always looking for another project or any good deal!
grayw0lf is offline   Reply With Quote
Old 10-22-2007, 03:27 PM   #10
67ChevyRedneck
67ChevyRedneck's Avatar
I recently pulled a complete set-up off an all original 72. If I remember correctly, there should be a 90 degree fitting where yours goes through the fender. From the 90 degree fitting, it should come out between the fender and frame next to the other hose. There should be no extra holes, cuts, dimples, whatever in p/s inner fender vs. non power steering fenders... that I'm aware of. 4x4's may be different?
Here's some pics. Yes, the fender is peeled back, but I did that because it was so rusty and it made taking the system off a lot easier than trying to remove 35 year old New York fender bolts
I still have the set-up all connected (took it off assembled.) If I can remember, I'll try to take a pic of the set-up tonight.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 10-22-2007, 04:14 PM   #11
fun in dirt
fun in dirt's Avatar
Mine is the same way too...damn PO!
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432
'85 K30 "Big Nassy"
'06 3500 Duramax ...tow truck
'06 Silverado SS...DD
'06 C1500 WT...DD
'07 Classic C1500 WT...DD
Built & sold cause can't keep 'em all:
'72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190
'55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938
'69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541
'86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619
fun in dirt is offline   Reply With Quote
Old 10-22-2007, 04:22 PM   #12
69GMCor70Chevy
69GMCor70Chevy's Avatar
I have a 69 GMC and mine as the hole in the fender. Looked factory to me.
68 Camaro - 327 Original Red on Red Car
69 GMC LWB - Built 350 a Blast To Drive
69 GMC LWB - "Green Machine" One Family Truck
70 Mercury Marauder - Future Project
69GMCor70Chevy is offline   Reply With Quote
Old 10-22-2007, 04:24 PM   #13
67ChevyRedneck
Hmmm, maybe it's factory for six cylinder, the V-6, or maybe big block truck?
Is there any similarities engine-wise for all those who have the hole.
Personally, I've never seen one done that way.
Jesse James
Project "On a Dime"
Old 10-22-2007, 04:31 PM   #14
69GMCor70Chevy
I don't know if my engine (350) or even the PS is factory as I have a diff cab so no glovebox label.
Old 10-22-2007, 04:41 PM   #15
OlChev67
Ever heard of Beech Island??
OlChev67's Avatar
Heres my inner fender chop job. I didnt have the patience to do it right, so I used an air grinder and cut the piece out. Saved the piece because I think I am going to weld it back in.
OlChev67 is offline   Reply With Quote
