11-12-2007, 05:01 PM | #1 |
how do i remove my front brakes
[I]'m having trouble removing my front drums. [I] tried penetrating oil and using a ballpei hammer. Can i remove the whole hub together
11-12-2007, 11:09 PM | #2 |
Re: how do i remove my front brakes
I know it's a stupd question, but did you back off the pads?
if they're still in contact, the drum aint coming off...
2003 GMC Sierra 1500 WT 1995 Nissan Hardbody 2016 Hyundai Veloster Turbo DC2 (SW/AW) Clyde W. Harvey USN "Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill |
11-12-2007, 11:32 PM | #3 |
Active Member
on my 67, I *had* to remove the entire hub / drum assembly. On mine, the front hubs were rivited to the drums. I just did a total brake overhaul, and when I replaced the front drums I didn't re-rivet them in, so now I can remove just the drums without removing the hubs.
11-17-2007, 07:04 PM | #4 |
Friday's Toy
I just did my front bearings the other day. From the factory the drums were riveted on. I was told that it does not matter if the rivets are replaced, it's only an assembly line procedure. My rivets wouldn't budge so I just ground them down flush with the hub.
68 C10, SWB Fleetside with a 454, Turbo 400 and 4.11 posi....Exxon/Mobil loves me. 2009 Jeep Rubicon 2011 Powerstroke FX4 (totaled) 71 C10, SWB Fleet with factory tilt 72 LWB C10, 350 700R4 with factory tilt |
11-17-2007, 07:45 PM | #5 | |
ya what he said!!! thats what you do it makes it nice to get in to if there is a quick fix
1995... 2DOOR TAHOE 1999... SUBURBAN 2 WHEEL DRIVE LOW RIDER sold!! 1999... SUBURBAN 4X4 sold!!! 1967...3/4 TON 4X4 SHORT BED 454 sold!! 1972...Cheyanne Super 454 1/2 lwb new toy!! 1972...1 TON 4X4 SUBURBAN CHEVY "RULE" GO OLD SCHOOL!!!!!!http://www.myspace.com/slicks72 |
12-31-2008, 10:57 PM | #6 |
i soaked mine in penatrating oil for a couple of days and beat the hell out of the hub and it came off. p.s, use a block of wood when you hit it off.
