Old 11-15-2007, 08:54 PM   #1
ScottH
ScottH's Avatar
Can a 4 speed be used with a Dana 20?
Just got a restored frame on ebay and it has a rebuilt Dana 20 in it.
No engine or trans, was thinking of looking for a 4 speed to use in it.
I know Dana 20 cases often had 3 speeds, but would rather have the 4 speed if I can.
Any info or suggestions are greatly appreciated.
Thanks.
Scott
1963 C10 swb fleetside
1966 GMC G1000 Handi-bus (future project)
1955 Chevy 2 dr. wagon
ScottH is offline   Reply With Quote
Old 11-15-2007, 11:17 PM   #2
GMCMAX
Active Member
GMCMAX's Avatar
Re: Can a 4 speed be used with a Dana 20?
The 70 blazer drivetrain I bought to do my conversion is a 4 speed and D20, I think the trans is the SM465
Never try to teach a pig to sing; it wastes your time and annoys the pig!
Gets More Chicks
My lugnuts require more torque than your honda makes!
68 GMC, 4X4 conversion w/73 k20 running gear and springs, 350 4spd, 4.10's, D44 powerlok front, 14BFF govlock rear, 33" tires, lifted 4".
GMCMAX is offline   Reply With Quote
Old 11-16-2007, 07:00 AM   #3
Blazer1970
Blazer1970's Avatar
From the picture, it looks like the Dana 20 on that frame you bought has the adapter for an SM465 on it. You would just need to find a 465 with the correct output shaft. Is the shifter for the Dana 20 there?
Blazer1970 is offline   Reply With Quote
Old 11-16-2007, 09:28 AM   #4
ScottH
ScottH's Avatar
Thanks guys, GMCMAX sounds like you answered my question.
Tim, I believe the auction includes a chrome shifter for the Dana 20 (can't get to ebay from work).
Can anyone tell me the pros or cons of the Dana 20 vs say a NP205?
Thanks again to all.
Scott
Old 11-16-2007, 02:23 PM   #5
ScottH
ScottH's Avatar
Tim, forgot to ask, would you know what the correct output shaft would be for the Dana 20?
thanks.
Scott
Old 11-16-2007, 05:40 PM   #6
1969 GMC
1969 GMC's Avatar
thanks.
Scott
It will be 10 spline output, just like the 205's of this era.
As far as size is concerned, the D20 was most prevalent in Jeeps, Scouts, and perhaps early Broncos (don't know much about them). I think it would be fine if you left everything stock, stockish hp that is. If you want lots of power I'd go ahead and get a 205 now and save yourself some headache.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 11-16-2007, 11:58 PM   #7
GMCMAX
Active Member
GMCMAX's Avatar
I haven't broken mine behind a stock 350, but I don't do any hardcore four wheelin, shifter doesn't come through the standard hole in the hump, it's to the rear of the trans shifter and leans left.
Gets More Chicks
Old 11-17-2007, 09:16 AM   #8
ScottH
ScottH's Avatar
Thanks guys!
