Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 11-17-2007, 01:18 AM   #1
Andy4639
Old member
Andy4639's Avatar
2 10" subs
OK here is the deal:
As of now I have 2 10" subs, 2 - 3 way speakers under the seat running off a old 4 channel amp. 25 watts per speaker, 2 tweeters mounted on the door panels that are running just off the radio out puts that have the crossover thing in line for them not to blow up.
The amp is hooked up with 2 RCA cables to the amp from radio.
Question: How would I go about hooking up a higher powered amp to the 10" sub and use the old one for the other 4 speakers. I want to put the 3 way and the tweeters on the old amp and I'll buy a new amp for the 10's.
It's in a 1971 C-10 pickup. Thanks
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 11-17-2007, 12:32 PM   #2
Classic69
Love That '69
Classic69's Avatar
Re: 2 10" subs
LOL.....Simple.....I've got a similar setup in my '69. I have a 400W 4-channel amp powering my front 5.25" component speakers/tweeters in the kickpanels and my rear 6.5" 2-way speakers. Also, I have an 300W 2-channel amp bridged, powering my 10" sub. Then I have a 1 farad capacitator to help power it all.
Here's how you gotta do it:
Your 4-channel amp has 2 front outputs and 2 rear outputs. It puts out the same wattage per all 4 channels. So you can wire in your 3-way speakers to each rear channel and your tweeters to each front channel. This should increase the capabilites of your tweeters quite a bit.
Then for your 2 subwoofers you have some options. It depends on the amp that you buy, what impedence your subs are, and whether they are single or dual. Are you gonna buy a mono-channel or a 2-channel amplifier? Are your subs 2 or 4 ohms? Do your subs have single or dual voice coils (ie. 1 or 2 wire hook-ups)?
I AM CANADIAN!!!!!
1969 Chevy C/10 Truck - SBC V8, TH-350, 3.73 Posi, 1000W Rockford Fosgate Stereo System, B&M Megashifter, GT Grant Steering Wheel, Dual Magnaflow Exhaust System, Dynomax Headers, Lowered 1" Front & 3" Rear, Front/Rear Sway Bars, Racing Seats, 6000K HID Headlights
2008 Chevy Colorado LT - 3.7L I5, 4 Speed Automatic, Crew Cab, 4X4, Z71 Off-Road Package, "Ground Effects" Package, K&N Cold Air Intake, Supermod PTB, Magnaflow Exhaust w/ Resonator, 500W Kenwood / Rockford Fosgate Stereo System, Custom LED Lighting, 6000K HID Low's / High's, Blackcat Customs Gauges / Needles, Carbon Fiber Interior Accents, KrFabs 2" Lift Shackles / Torsion Bar Crank with Rancho RS5000 Shocks, Superskids Skid Plates
Classic69 is offline   Reply With Quote
Old 11-17-2007, 03:22 PM   #3
Andy4639
Old member
Andy4639's Avatar
Re: 2 10" subs
All I can tell you about the subs are that they have a 2 wire hookup, that's all I know about them. I don't know anymore than that except I bought them at Wally World.
Old 11-17-2007, 10:08 PM   #4
Andy4639
Old member
Andy4639's Avatar
Re: 2 10" subs
I just purchased this amp. Hope it works like I want it to. I have it figured out I think.
http://cgi.ebay.com/ebaymotors/ws/eB...ayphotohosting
Old 11-18-2007, 12:53 PM   #5
Classic69
Love That '69
Classic69's Avatar
Re: 2 10" subs
OK....So hook up your old amp to your speakers and tweeters like I mentioned previously.
Then, for your new 4-channel amp that you picked up for your subs you gotta bridge it to both of them. On the amp there are 4 rear hook-ups and 4 front hook-ups. It should say on it which ones you gotta hook up to "bridge" the channels. It will be one + and one - terminal on both the front and rear connections. This will increase the power from the amp going to your subs. The bridged front channel will go to one sub and the bridged rear channel will go to the other sub. Here is a pic to show you what I mean:
For more information on wiring your DVC (dual voice coil) subwoofers check out this link to Rockford Fosgate's subwoofer wiring wizard:
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp
I AM CANADIAN!!!!!
Old 11-18-2007, 09:07 PM   #6
Andy4639
Old member
Andy4639's Avatar
Re: 2 10" subs
Thanks for the info.
The old amp can be used with RCA cords or the regular speaker wire hookups.
I only have 2 RCA cords now.
I will be checking in on here when I start the wiring. I have to get the truck back first. I have to clean the old wiring up some to.
THANKS again!
Old 11-21-2007, 11:35 PM   #7
Classic69
Love That '69
Classic69's Avatar
Re: 2 10" subs
No problem.....This is a great site for information. Ask and you'll always get an answer.
I AM CANADIAN!!!!!
Old 11-25-2007, 04:09 AM   #8
corn
Re: 2 10" subs
I would rather see you use RCA Y adaptors than using the hi level (wire) connections. A "Y" adaptor will allow you to use another set of RCA cables for another amp. Most stereos have a couple sets on them, have you looked to see if there are any more on the radio?
corn is offline   Reply With Quote
Old 11-26-2007, 10:28 AM   #9
Andy4639
Old member
Andy4639's Avatar
Re: 2 10" subs
I have the Y connector's. I didn't know this would work. That's cool that's the way I'll go.
Old 12-19-2007, 04:17 PM   #10
Andy4639
Old member
Andy4639's Avatar
Re: 2 10" subs
Here is some pictures of what I have got. 2 -10" subs behind the seat
Tweeter's mounted where the coat hanger was on the passenger side and copied it over to the driver's side.
Three way's under the seat. The sound is a lot differant since I mounted the tweeter's where I did. Very pleased and it took about 20 minutes to do.
