Old 11-18-2007, 02:12 AM   #1
scrapmetalart
Junior Member
lowering by loosening up the torsion bars?
I have a 62 GMC is it possible to get 2" - 3" lower in the front with just loosening up the bars? I have 5" lowered springs in the back & shorter tires in the front. i just want 2" - 3" lower in the front... How do I go about it with the torsion bars?
frontstreetcycle on Instagram
scrapmetalart is offline   Reply With Quote
Old 11-18-2007, 04:24 AM   #2
TINKERDUKE
Re: lowering by loosening up the torsion bars?
Drop spindles would be best. The torsion bars may throw off the wheel camber lowering that much, or the torsion bar bolts will be very close to the ground! You could always give it a try and if it ain't right just adjust back- nothing to lose. Steve.
TINKERDUKE is offline   Reply With Quote
Old 11-18-2007, 04:18 PM   #3
Frizzle Fry
Frizzle Fry's Avatar
This was with a torsion adjustment and 2.75" blocks in the rear:
Frizzle Fry is offline   Reply With Quote
Old 11-18-2007, 05:20 PM   #4
fuelpump
fuelpump's Avatar
This was also lowered with the torsion bars and cut coils in the rear.
Name:  truck 060A (Small).jpg
fuelpump is offline   Reply With Quote
Old 11-18-2007, 06:30 PM   #5
scrapmetalart
Junior Member
I got it 1 1/2" lower in the front but would like another inch. I may get some longer bolts. I am out of "safe" adjustment at the moment...
How much did you guys get?
Old 11-19-2007, 12:18 AM   #6
Frizzle Fry
No idea on mine. Never measured before/after
Old 11-19-2007, 12:23 AM   #7
Imperial Kustom
100% gearhead
Imperial Kustom's Avatar
I got about 4" out of mine when I still had torsion bars.
Imperial Kustom is offline   Reply With Quote
Old 11-20-2007, 12:59 PM   #8
Revin68
Recreational Grease Monkey
Revin68's Avatar
I got 3-4 on mine and I hate it. The mounting arms catch on driveways etc and it hits the the bumpstops regulary. I am in the process of putting a '73 1/2 ton front under it.
Robert
Revin68 is offline   Reply With Quote
