12-26-2007, 12:07 PM | #1 |
Front drive shaft!!
Aight this weekend i put a 6in procomp lift on my 79 ling bed. i totally forgot about the front drive shaft going to be tooo short. so what do u guys think that i can do. this is my first full size truck, im still learning yet!!!
1979 Chevy Custom Deluxe (Ole Blue), built 350, Edelbeock carb, Hooker headers, dual glass packs, 2 in lift wit 32in Bfg a/t's on mickey tompson classic II's. - -Certified Welder-
12-26-2007, 12:39 PM | #2 |
Re: Front drive shaft!!
How much spline is left in the slip yoke??? If it's less than half...which it probably is...you'll need to hit the junk yards for a longer model, and cut/weld it to size. Your shorter one can be sent to me!!!
A......
69' 3/4 4X4 470ci BBC 700 HP.... D60/14bolt 205/465 http://profile.myspace.com/index.cfm...ndid=127691959 |
12-26-2007, 04:48 PM | #3 |
I put a 6 inch lift on a blazer and have had no front drive shaft issues at all. I wheel the heck out of it and not one problem. You could also look into dropping your crossmember that could be enough.
12-26-2007, 06:23 PM | #4 |
Same here..4" lift should be fine with stock drive shaft.With a 6" lift the stock driveshaft should work,but it may not extend out that much.Having the stock one lengthened shouldn't cost that much.I don't know what models interchange that have a longer front driveshaft..
12-27-2007, 03:38 AM | #5 |
well looks like im going to cut it and weld it up at work and have the machine shop turn it back down.
12-27-2007, 03:51 AM | #6 |
I would still take it to a driveline shop and have it balanced. It doesn't take much to cause a vibration, which at the very least is hard on seals/bearings.
12-27-2007, 08:29 AM | #7 |
I had rear driveshaft shortened, balanced and new U-joints installed and it was only $115.00. They sprayed some kind if stuff looks like a bunch of bumps on it to get it balanced right. They also welded wieghts on(or kept original) to balance.
Ron
Member #111 68 C-10 Daily Driver 70 4x4 Project 76 Jeep CJ-5 Help Support the Board: http://67-72chevytrucks.com/vboard/payments.php He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors. Thomas Jefferson |
12-28-2007, 07:52 AM | #8 |
Or how bout i found the front drive shaft off of my first gen s10 blazer i bought for parts a year or so back. Its the same damn thing, universals are the same just 4 inches longer!!
