01-03-2008, 10:14 AM | #1 |
1/2 Ton frame vs. 3/4 Ton
Is there a differance between the 1/2 ton frame and 3/4 ton frame? I know all the suspension is different, but what about the frame its self? I am in need of a 3/4 ton 2wd frame, but as you know that is harder to find than a 1/2frame. So I am hoping I could use the 1/2 frame and put all my 3/4 ton suspension on it.
01-03-2008, 10:18 AM | #2 |
Re: 1/2 Ton frame vs. 3/4 Ton
Frame is the same,there is a little extra bracing though.If it's a 3/4 ton Longhorn,they use a one ton frame though.
01-03-2008, 10:41 AM | #3 | |
Darren
67- 72 Parts collecter |
01-03-2008, 11:01 AM | #4 |
its all about the +6 inches
I agree with everything said
However... look around, I've always found 3/4 ton stuff to be WAY more common and cheaper too. |
01-03-2008, 01:16 PM | #5 |
Thank you for the info. My search might be easier now.
01-03-2008, 01:54 PM | #6 |
Are you looking for a coil or leaf spring frame?
01-03-2008, 02:02 PM | #7 |
I am looking for a coil spring frame
01-03-2008, 04:25 PM | #8 |
I got what you need........
A........
69' 3/4 4X4 470ci BBC 700 HP.... D60/14bolt 205/465 http://profile.myspace.com/index.cfm...ndid=127691959 |
01-03-2008, 06:07 PM | #9 |
bummer there's like 1800 miles between point a and b huh?
01-03-2008, 06:20 PM | #10 |
I also have a frame i'm taking from under my 3/4 ton. Mine is setup for bags. It currently has bags at all four corners with the rear notched. Let me know if you are interested, I'm switching to a shortbed
01-04-2008, 03:19 PM | #11 |
DieselEater....Thank you but Colorado is just a bit to far especially since the vehicle I am trying to fix is my tow vehicle.
snacob14...I don't know anything about bad suspensions I am just trying to fix mine that recently got wrecked. |
01-09-2008, 02:52 PM | #12 |
Well I seem to have found a rolling frame in Atlanta area. Any open trailers heading towards nashville area from atlanata area able to give me a good deal on transprortation of it?
01-10-2008, 03:04 AM | #13 |
Check pull-a-part salvage. 3/4 frames are almost giveaways. The cab mounts are very different then 1/2 ton. doing a swap is not worth all the work involved in my opinion. Huck
01-10-2008, 06:54 AM | #14 | |
So putting a 1/2 cab on a 3/4 ton frame requires alot of extra work?? I thought the cabs would bolt right on. Educate me please.
Happiness is towing your "new" truck home. 1972 C-10 1982 GMC (parts truck??) 1969 c10 parts truck 1969 C-10 ( my sons) 1992 Silverado 4X4 (now the boys truck)(now mine again) 2002 Tarus (my wife loves that car) |
01-10-2008, 07:20 AM | #15 |
I think you just use the 3/4 ton cab mounts on the 3/4 ton frame.
01-10-2008, 08:00 AM | #16 |
I have a 3/4 ton frame as well. Sent you a pm. I got it from Huck a couple years ago and never used it.
Woody |
01-10-2008, 10:07 AM | #17 | |
huh ???
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's "I am a bomb technician. If you see me running try to keep up!" |
