Old 01-03-2008, 12:39 PM   #1
7T2
Active Member
7T2's Avatar
Would a 69 6 lug 12 bolt rear end be the narrow one?
I'm looking at one on ebay, and I'm looking for the slightly narrower rear end. The one I'm looking at is out of a 69 SWB 4X4 truck and is a GM 12 bolt with 6 lug axles. Not sure if I can get out to measure it myself before the auction ends. I asked seller to measure it, but there are so many different ways to measure that you never know if someone is measuring the same way you would.
Just wondering if ALL 6 lug rear ends were narrower than the later 5 lug ones.
1957 GMC Ambulance
1962 Belair Wagon
1963 C80 Truck Cab *FOR SALE*
1969 Chevy C10 Short Bed
1972 Chevy C10 Long Bed *SOLD*
1996 C3500 Dually *SOLD*
7T2 is offline   Reply With Quote
Old 01-03-2008, 12:44 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Would a 69 6 lug 12 bolt rear end be the narrow one?
it would be the wide on.
in 70, the early ones were wide, later ones were narrow.
Old 01-03-2008, 12:59 PM   #3
7T2
Active Member
7T2's Avatar
Forgot to mention it's off a half ton. Did 4x4's and 2x4's use different rear ends?
1957 GMC Ambulance
1962 Belair Wagon
Old 01-03-2008, 01:26 PM   #4
1969k10stepside
I don't know if they are narrower or wider than the 2wds in any year.There will be leaf spring perches on a 4wd (which are different from 2wd leaf spring perches I believe too),and the 2wd axle if it has coils on the back would have the tracking arm mount the 4wd won't have.But the axle is the same axle.
1969k10stepside is offline   Reply With Quote
Old 01-03-2008, 01:28 PM   #5
Longhorn Man
I was talkin 2 wheel drive, no clue on the 4X4's
Old 01-03-2008, 01:30 PM   #6
Andy, I thought in mid 70 to 72 the rear axles were longer (wider) that the others. Sure seems that way on mine. The 70, and 72 axles are wider than the one that came on the 69..
Old 01-03-2008, 01:42 PM   #7
kelsfine69
18 Till I Die
kelsfine69's Avatar
I know that the 65-66 trucks are narrower than a 69 6 bolt( i put one in my truck) But it looks the same and bolts the same( trailing arm) so if he says its a 69 that it might not be?? something to concider
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Old 01-03-2008, 01:45 PM   #8
uncle
They are wider starting sometime in 70. All 4x4's will be leaf spring. The difference in width is about 3/4" on each side. Yes,it is the narrow one.
uncle is offline   Reply With Quote
Old 01-03-2008, 02:15 PM   #9
Longhorn Man
oh crap...
I got it totally bass ackwards.
Old 01-03-2008, 02:56 PM   #10
Originally Posted by Longhorn Man View Post
oh crap...
You sure those were normal brownies??
Old 01-03-2008, 03:02 PM   #11
Longhorn Man
Lol!!!!!!
Old 01-03-2008, 03:31 PM   #12
7T2
Active Member
7T2's Avatar
oh crap...
Well, that's what I was thinkin', but I didn't want to call out the man with 63,000 posts until I had some more proof...
I think I'll take a chance on it. Comes with the front axle too, maybe if I clean 'em up real nice I can end up with what I need for free...
1957 GMC Ambulance
1962 Belair Wagon
Old 01-04-2008, 02:03 AM   #13
The 4wds and 2wds got wider in`70.
Old 01-04-2008, 03:51 AM   #14
class01
class01's Avatar
So if i have a 69 rearend, does that mean i can fit a wider rim or run more offset?
class01 is offline   Reply With Quote
Old 01-04-2008, 11:34 AM   #15
Longhorn Man
It's only a 3/8 inch diff on each side, but in a nutshell, yeah.
Old 01-04-2008, 11:38 AM   #16
uncle
I think it's actually 3/4" on each side,but have been wrong several times this year already.
Old 01-04-2008, 11:49 AM   #17
Longhorn Man
I'm just gonna shut up.
I just looked in my notes, you are right. 56 inch verses 57 1/2 inch wide.
Old 01-04-2008, 12:39 PM   #18
uncle
The only reason I know is because I used to have around 40 12 bolts sitting around. I also had several people years ago lie to me about the axle swap on these year trucks and found out the hard way.
Old 10-01-2015, 11:58 PM   #19
gijoecarlos
Quick Question, If i have a 2wd leaf 71 c10 and want to get that more narrow 67-69 rear end, Can i just get a 4x4 rear end or does it have to be a 2wd rear end? Im just currious to save me the trouble of having to weld anything onto the new rear end? Also what kind of gear rations did the 67-69 rear ends have? Mines currently a 373 and its good with my 700r4 but the axle is a little wide for my tires and rim combo
gijoecarlos is offline   Reply With Quote
Old 10-02-2015, 01:21 PM   #20
uncle
Pretty sure spring perches and shock mounts are different. Be easier to get early leaf rear.
