Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 01-16-2008, 04:41 AM   #1
RatPwrd72
RatPwrd72's Avatar
Video's of my '67
Haven't posted any new pics of vids since the rebirth of this truck. Last pass before these vids was 1992. One of the other vids posted up is when my dad drove in 1985. All the rest are me. On this pass, the oil pump pickup fell off as i
was going through the traps. Weather has since gone ****ty, and we haven't been back to the track.
1972 Chevy Cheyenne Super- Pump gas 496,TH-400, TCI Stall, 3.73's,Ochre & White two-tone w/Olive
Interior
1967 Chevy Short Step Drag Truck-Iron Headed 468 Making Memories
My momma took me off the bottle years ago.....
RatPwrd72 is offline   Reply With Quote
Old 01-16-2008, 06:11 AM   #2
Outlaw72
Hay Team!!
Outlaw72's Avatar
Re: Video's of my '67
Cool Truck
1972 Chevrolet Cheyenne LWB "Orange and White" 8)
Outlaw72 is offline   Reply With Quote
Old 01-16-2008, 09:44 AM   #3
Super73
Super73's Avatar
Moves pretty good..
Super73 is offline   Reply With Quote
Old 01-16-2008, 10:00 AM   #4
RatPwrd72
RatPwrd72's Avatar
Thanks guys, that run was on a mild tune-up. There's still more to be had when we get the barrel valve and pill adjustments just right. I'm ready to go racing some more
Interior
Old 01-18-2008, 12:30 AM   #5
Yukon Jack
Post Whore
Yukon Jack's Avatar
Very nice! Sounds great.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 01-22-2008, 12:41 AM   #6
whatnow123
whatnow123's Avatar
awesome!!
67 Short Step, 355, 700R 4.11 posi rear, 4/6 drop Discs on all 4 corners.
Build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=219094
whatnow123 is offline   Reply With Quote
Old 01-22-2008, 06:58 AM   #7
CyanJaguar
SICK!!! is the truck tubbed? how big are those tires?
CyanJaguar is offline   Reply With Quote
Old 01-23-2008, 09:06 AM   #8
Igotachevyor2
Apache Club
Igotachevyor2's Avatar
great vid
58 CHEVY APACHE I 74 CHEVY C-10 I 78 K-10 donor truck I 89 SONOMA
My Trucks Apache Sitting Idle MySpace
Project Dad's Truck (74 C-10 to K-10 conversion)
Igotachevyor2 is offline   Reply With Quote
Old 01-23-2008, 10:20 AM   #9
70-Chevy
-Chris
70-Chevy's Avatar
That gave made the hair on the back of my neck stand up! Awesome, just simply awesome.
1970 Chevy C-10 P/U, Shortbed, Fleetside - 5/7 drop, 496, TH400, 12 bolt.
BUILD THREAD - http://67-72chevytrucks.com/vboard/s...d.php?t=404481
2012 F250 Super Duty P/U - intake, exhaust, tuner, 4" lift with 35's
2017 Chevy Suburban (Wifes Car)
- Fully Loaded & Stock
"Some people spend an entire lifetime wondering if they made a difference in the world. But, the Marines don't have that problem."
Ronald Reagan, President of the United States; 1985
70-Chevy is offline   Reply With Quote
Old 01-24-2008, 06:28 AM   #10
RatPwrd72
RatPwrd72's Avatar
No, it's not tubbed, so to speak. We run a 12 Bolt Car rearend ('70 Camaro) that has been narrowed slightly, I can't remember how much. The tires are 32x14.5x15 and the wheels are 15x14. The rear fenders are stock, with no mods. The bed floor was originally wood and is now a 1/4 piece of plywood. The batteries are the only other thing in the back. All of the rear suspension is stock (Trailing arms, shock mount, shocks are from Autozone). The only thing different is the mounting point at the front of the trailing arms. They are on an adjustable plate and work best at 5" lower than stock. Who needs a 4-link and coilovers?
If you notice in the video, the front rises at the hit, but falls causing the rear to unsettle. I ordered some new Lakewood 90/10's for the front and new Goodyear's for the back, maybe that will help. Also, the front springs are older than I am, I need to pull them and check their rate.......
Interior
Old 01-24-2008, 12:06 PM   #11
djracer
djracer's Avatar
I bet if you went to a smaller rear wheel and tire and lowered the back of the truck it would help your 60ft a bunch!
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 01-24-2008, 01:26 PM   #12
CyanJaguar
thanks man. I think I will eventually try to do a 12 inch wide tire in the back. might need to cut some out but its all good.
Old 01-24-2008, 02:36 PM   #13
RatPwrd72
RatPwrd72's Avatar
When we started racing this truck (1981) there were no 60' times. You were lucky to get both MPH and E.T. A smaller tire would help the short time, but the truck has 5.38 gears and needs the tire height for the big end. It's cut a 1.45 60' before we mounted the tires you see in the video. I love the throttle response of fuel injection.
Interior
Old 01-24-2008, 09:17 PM   #14
djracer
djracer's Avatar
I use to run a toilet on alcohol on my old camaro and it was sweet! The tires I was talking about are 33 tall just about 11.5 inches wide. Another cool thing about these is if you have 10.5 races in your area you can buy take offs
with 4 or 5 runs for 150 or less a set! I would run the narrower tire and lower the truck down over the tire and it should help you weight transfer off the line a bunch!
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 01-24-2008, 10:43 PM   #15
RatPwrd72
RatPwrd72's Avatar
We used to run a Kinsler stack set up that was a PITA. If it was set right, it ran great. We switched to the toilet and love it. I might look into the narrower tire, they do have some 10.5 races at the local track.
Interior
Old 01-25-2008, 12:27 AM   #16
djracer
djracer's Avatar
Yes we have 10.5 races quite often.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 01-27-2008, 09:05 AM   #17
royo
royo's Avatar
Kool ride !! but wheres the trans brake
nickle and dime
royo is offline   Reply With Quote
Old 01-27-2008, 01:33 PM   #18
RatPwrd72
RatPwrd72's Avatar
Doin it old school right now. No Brake, no two step, no throttle stop. Just enough stuff on it to run.
Interior
Old 01-28-2008, 12:31 AM   #19
Legend56BC
Legend56BC's Avatar
great video,Luv that sound!
Legend56BC is offline   Reply With Quote
Old 03-10-2008, 10:11 AM   #20
Truckracer
Truckracer's Avatar
Older video of the same truck,, I;m driving.RatPwrd72 is the little guy sitting on the three wheeler to the right..
23t Altered..
Truckracer is offline   Reply With Quote
Old 03-19-2008, 05:28 AM   #21
larry may
Sweeeeet!
The biggest problem people have, is other people
Thou shalt be cool and not hassle
Be a site supporter.
The heart of the wise inclines to the right, but the heart of the fool inclines to the left." Ecclesiastes 10:2
larry may is offline   Reply With Quote
Old 03-19-2008, 07:54 AM   #22
RatPwrd72
RatPwrd72's Avatar
Just a small update. After setting all winter, decided to put fresh springs and shocks up front to help it launch. Shocks are Comp. Engineering 90/10's and springs are custom made for a '78 Monza (Remember it has an older Jegster front clip). Thanks again, TruckRacer! Didn't change anything else from Nov. and it went 10.90 @ 120 back to back. Third pass it ran 10.87 @ 121. Almost ready for some No Electronics brackets. Thinking about switching the 5.38 gears for some 5.14's or 4.88's to lower the RPM's through the traps. Should have some updated pics in the next few days.
Interior
Old 03-19-2008, 03:34 PM   #23
djracer
djracer's Avatar
what did it run before the changes?
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 03-19-2008, 05:48 PM   #24
RatPwrd72
RatPwrd72's Avatar
Best pass for me last year was a 11.26 with a 1.65 60' being the best. It pulled 1.54 60' twice. Last year the front end would rise at the hit, then fall right back down unsettling the rear.
Interior
Old 03-20-2008, 03:59 AM   #25
djracer
djracer's Avatar
I need to get some good video of my junk leaving! to see what its doing. I am off about a tenth in sixty compared to what the previous owner did with a similar E.T.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
