Old 10-17-2002, 10:47 PM   #1
mikep
Used to have a truck
mikep's Avatar
Oil Pressure too high?
I rebuilt the engine in my truck about 3000 miles ago and recently switched to 20W50 oil from the 10W30 I used for the first 3000 miles for break in. In the motor I have a meeling Hi Volume , Hi Pressure pump and I am running with .0025" bearing clearance. Anyway when the motor is cold the needle is off the gauge. I mean I can't even see the needle at all and when its warm its at the far right of the gauge . Even at idle its between the 3/4 mark and H . This super hi oil pressure isnt really something Ive experienced before. I'm running the super long Fram filter , valvoline 20W 50 and CL77 bearings. I dont leak a drop. Is this going to blow something up or should I just be happy and drive on down the road? Anyone had similar experiences that turnd out sour?
No truck :-(
mikep is offline   Reply With Quote
Old 10-17-2002, 11:13 PM   #2
crazy longhorn
Fabricate till you "puke"
Its hard to say how much pressure you have with the factory guage. I run a Melling 10555 hy vol/hy press pump on my 383. With 2500 mi on a fresh eng, I run 70 psi hot @ 3000 rpms, & run 20/50 castrol. this is measured by an Autometer mechanical guage. From my understanding , you really dont need or want more than 65-70 psi pressure on a sb chev......the old rule of thumb was 10 psi per 1000 rpms,& 6500-7000 is pretty tight on a street /strip engine! I havent had any problems with my setup, but do have a 6 Q truck pan ,& dont buzz the throttle till the oil temp stabilizes. my thoughts are, toss an after market guage on, just to verify the reading on your stocker. .......crazy longhorn
crazy longhorn is offline   Reply With Quote
Old 10-17-2002, 11:21 PM   #3
whateva
Do you guys realize that with that much oil preasure you are probably bypassing your oil filter?
This is not meant to be a slam on you guys, but why do people feel that excessive oil preasure is better. It is not like the average small block is turning 10,000 rpms like a Nascar engine.
First think I would do is get that 20w50 out of there.
whateva is offline   Reply With Quote
Old 10-17-2002, 11:26 PM   #4
Blue_71
Bloo
Blue_71's Avatar
i dont know whats too high, but i always run 10w40. i build up about 25 lbs cranking it (and its pretty easy to start) and stay about 35-40 running
ASE Master Certified-GM Trained-Mechanic
1968 Chevy C30 157" WB Wrecker
1969 Chevy CST/10 SWB
1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed
1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205
1974 Chevy Custom Deluxe/10
1979 Chevy Custom Deluxe K10 farm truck beater
1989 Chevy K2500
Originally Posted by Alan Jackson, Cause I'm a country boy
35s whinin on the asphalt, grabbin mud, throwin up some red dirt
R.I.P. Michael Stilts... I will always love and miss you brother! (9-12-80, murdered 4-9-05)
Blue_71 is offline   Reply With Quote
Old 10-17-2002, 11:29 PM   #5
racedvl
racedvl's Avatar
I wish I had oil pressure........
racedvl is offline   Reply With Quote
Old 10-17-2002, 11:45 PM   #6
Zkast
Zkast's Avatar
There's also the heat factor. I cant remember the exact ratio but I think its this:
For every 10psi of pressure you raise the oil temp by 20 degree's
The bypass valve will sense a difference between the oil pressure in and the oil pressure out and if that difference in pressure is greater than 10-20 psi it will close off the filter and send unfiltered oil into the system. So if you are running 20w-50 with a system producing 80psi on cold starts, your definatly bypassing the filter. With pressure like that you could easily step down to 10w-30 or 40 and be on the safe side.
Zkast is offline   Reply With Quote
Old 10-17-2002, 11:58 PM   #7
mikep
mikep's Avatar
Bypass? What Bypass ? I'm running the non bypass filter and the non bypass adapter. Full flow all the way! Thats why I am running the tall filter in the first place. It's probably part of the hi oil pressure thingy going on. Iv'e lost more than one engine to having a bypass oil filter. Never again! I probably will go down to 10w 40 or to even 5 W 30 during the cold season.
No truck :-(
Old 10-18-2002, 12:27 AM   #8
flyin99
creator of kong
flyin99's Avatar
I do have a question.........What psi are these factory gauges? I was told by somebody that they were either 40 or 60 psi...if this is so, it wouldn't be that hard to make the needle fly to the other side......................
flyin99 is offline   Reply With Quote
Old 10-18-2002, 12:50 AM   #9
crazy longhorn
Im not sure on the 67-72, but 60 psi pins the factory guage on my 78.
Old 10-18-2002, 02:18 AM   #10
72bigblock
also running that much press. can cause bearing to hyd. lock causeing the bearing to spin. 50 p.s.i is more than you will ever need on the street!
72bigblock is offline   Reply With Quote
Old 10-18-2002, 08:25 AM   #11
Blazer1970
Blazer1970's Avatar
I can't understand why you would want to run 20W50, especially in a tight engine. You are not going to bypass the filter. The bypass valve is only going to open when there is excessive pressure drop ACROSS THE FILTER. This happens when the filter is plugged, not just because your oil pressure is high. When the oil pressure is high, unless the filter is plugged, it is high on both the inlet and the outlet of the filter. The biggest problem with that high pressure is the wear on the distibutor drive gear, and the gear on the cam that drives it. Also, it uses a lot of hp just to drive the oil pump.
Blazer1970 is offline   Reply With Quote
Old 10-18-2002, 09:37 AM   #12
crazy longhorn
I agree that it takes more hp to run a big pump, & dist gear wear is also a concern. I have run a Z28 pump, or a properly clearanced stocker,with a Z28 spring on just about every sb I have built, &had no problems. From the factory ,GM put the high pressure pump on the z28's, & they ran @ 65 psi hot runnin down the hyway. My reading in How to Hotrod sb Chevs tells me that the z28 pump is a good street /strip pc with the proper pan. The Melling pump I have on the 383 has a bolt on pickup, pressure balance grooves,& post extended ito the cover to keep the gears running straight. I probably dont need 70 psi, but from time to time the engine is run up in the 6500 rpm range
Old 10-18-2002, 09:45 AM   #13
slam33
slam33's Avatar
Try running 10/40 in it
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html
" TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410
</A>
slam33 is offline   Reply With Quote
Old 10-18-2002, 10:49 AM   #14
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
I had my 402 rebuilt by a local and reputable engine builder and I wanted them to install a high pressure/high volume oil pump in my engine. They told me that High pressure/High volume oil pumps tend to wash out the bearings leading to premature failure. They also told me that what I wanted was a Low pressure/High volume oil pump so that is what I went with, seeing how they would have to warrantee the engine if it broke. I don't know it to be fact, but it warrents concideration... WES www.ClassicHeartbeat.com
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 10-18-2002, 11:05 AM   #15
jhwkns
Registered Cruiser
jhwkns's Avatar
I use high volume pumps on any performance small block, and have never had any problems. It gets pretty hot here in Vegas so in the summertime I use 20w50 when things cool off I run 10w40. Pegging the stock gauge isn't a hard thing to do. At 65psi mines buried.
I intend to live forever. So far, so good.
jhwkns is offline   Reply With Quote
Old 10-18-2002, 05:21 PM   #16
tom hand
CCRider
tom hand's Avatar
When it comes to oil pressure, more is not better. There is little reason for a street motor to have more than 40 psi. Besides the wear on the distributor gear and the Hp needed to drive it, on most high pressure motors, the rear main seal have a premature demise. My 2 cents.
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
Old 10-18-2002, 05:26 PM   #17
bigjimzlll
bigjimzlll's Avatar
you know that all sounds right....about too much pressure hurting things....but for me..I vote for the high volume pump with a 7 quart oil pan....better too much oil than not enuff
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 10-18-2002, 05:49 PM   #18
Blazer1970
Blazer1970's Avatar
A high volume pump is fine. You don't need it on a tight engine, but it won't hurt anything. It is the high pressure pump that you don't really want. Most of the pumps come with two springs for the relief valve, so you can choose to install the high pressure spring, or the low pressure one.
Old 10-20-2002, 10:33 AM   #19
6869704X4
Check out this site. Good info.
http://www.melling.com/support/bulletins/default.asp
The more I learn about women, the more I love my truck.
6869704X4 is offline   Reply With Quote
