View Poll Results: What to do with the inner fenders
Yank 'em 4 13.79%
Leave 'em 25 86.21%
Voters: 29. You may not vote on this poll
Old 01-19-2008, 10:01 AM   #1
Lated
Lated's Avatar
Inner Fender Dilema
I just did a 3.5/4 drop on my truck and if I'm not careful when I go over bumps the front tires hit the inner fender. I've considered removing them but didn't know if there were any downsides to removing them. What are the pros and cons? Will the front sheetmetal still have enough rigidity without them? I know more road crap like snow, rain and, dirt will make it into the engine compartment. What should I do? Keep in mind that this is my daily driver.
“If you don’t have time to do it right now, how will you ever find time to fix it.” - author unknown
'70 SWB Step-Side (More rust than metal)
Lated is offline   Reply With Quote
Old 01-19-2008, 10:15 AM   #2
whatnow123
whatnow123's Avatar
Re: Inner Fender Dilema
For one, you will dent the hood as the tires will catch rocks and such and toss them that way.
If it wasn't a DD, no big deal, but i'm thinking you might want to seek alternatives since it is.
67 Short Step, 355, 700R 4.11 posi rear, 4/6 drop Discs on all 4 corners.
Build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=219094
whatnow123 is offline   Reply With Quote
Old 01-19-2008, 10:24 AM   #3
Shane
Shane's Avatar
If it were mine and I used it as a daily driver then i would keep them in.
Shane is offline   Reply With Quote
Old 01-19-2008, 10:40 AM   #4
454_72_4X4
454_72_4X4's Avatar
The front sheet metal will be rigid enough but you will get alot of road grime. I haven't had one in my 72 for a couple years now. Removed it to work on the clutch linkage and it never got put back in.
Rocks in the radiator worries me the most but it hasn't happened yet.
72 C20 4X4 454 4 speed
89 Trans Am (was) 305 TPI 700r4
93 C1500 2wd Extended cab 350 700r4
98 Sonoma (TPI outa the Trans Am)
03 Yamaha 660 Raptor
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
454_72_4X4 is offline   Reply With Quote
Old 01-19-2008, 10:42 AM   #5
Ol'Rover
Project: years too late.
Ol'Rover's Avatar
its nice that your brought this up, I will be doing the same thing, and i didnt even know this would happen. Theres probably a way to raise the inner fender up enough that wheels wont touch. you should definatly keep them tho, You dont want dirt in your engine compartment. Nasty things could happen.
1971 C10 Stepper LSX 5.3/4L60E 3.73 12bolt posi. Father Son Project. In Memory of Bruce C. Shorten. Rest easy Dad. Ill take it fryom here.
Ol'Rover is offline   Reply With Quote
Old 01-19-2008, 10:43 AM   #6
GREASEMONKEY72
GREASEMONKEY72's Avatar
you can pull them and take some sheet metal and make some new ones to protect the hood
something like this
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 01-19-2008, 12:06 PM   #7
70c10
67-72 Addict!
70c10's Avatar
I'm suprised because mine is lowered almost 5" in the front and I don't hit. How old are your shocks?. How tall are your tires?
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 01-19-2008, 12:48 PM   #8
wibilly
wibilly's Avatar
thats what i was thinking, put on tires that fit your wheel wells
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 01-19-2008, 12:52 PM   #9
72BlckButy
Tot Roddin'
72BlckButy's Avatar
I was thinking it might have to do with the height of your tires. What size tire are you running. I know that lolife99 dropped his Blazer 4.5/6 and hasn't had any real issues, except on the occassional pot hole. If it were me I would leave them in...
Great pics greasemonkey!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 01-19-2008, 01:50 PM   #10
Mondo
Mondo's Avatar
that shouldn't be a problem, I assume you got the front re-aligned or the camber may cause the rubbing. I have a 5 1/2 drop on front and can't quite get the camber back, but it doesn't rub (255/60/15s)
Mondo is offline   Reply With Quote
Old 01-19-2008, 02:23 PM   #11
Frizzle Fry
Frizzle Fry's Avatar
Plus, unless you have serious backspacing and/or negative camber your tires will rub the arches on the inside of the actual fenders pretty quick (ie. the inners don't buy you much). You have to mod the inside fender arches too.
Frizzle Fry is offline   Reply With Quote
Old 01-19-2008, 11:24 PM   #12
greasy68
greasy68's Avatar
Keep them or fab something else up but on a DD it will be pretty messy and there is a lot of potential for damage under the hood.
Mike
68 C10 LWB midnight blue metallic
307ci, 700R4, HEI
front discs, leaf spring rear
tilt steering wheel, stock ride height, rally wheels,
2007 Dodge Charger(Hemi)
greasy68 is offline   Reply With Quote
Old 01-20-2008, 12:17 AM   #13
matthufham
i have a 4.5/6 drop, with 20X8.5 rims with 5.107.." backspace. 245/35/20 tires, stock inner fenders and they never hit. you need different tires and rims for this problem to be solved. don't remove the inner fenders
matthufham is offline   Reply With Quote
Old 01-20-2008, 03:08 AM   #14
Mordachai
Fat Fendered Fleetside
Mordachai's Avatar
I don't have much to say other than inner fenders are important!! keep all the crap outta your engine bay.
Even though my truck isn't a DD(right now it's in pieces) when I'd take it out even a few miles of driving will really get your engine bay dirty. I got a tilt forward front, and all kinds of crap gets tossed up in there.
When I put it back together, I'm gonna fab up some inners, probably vette style, ie mounted to the frame, so when the front comes down, it does a reasonable job of sealing up the space.
I'd do like the other guys here are suggesting, take a good look at your wheel/tire combo and your alignment!
|M|
71 GMC lwb
56 Big window swb
93 GMC Sonoma (dd)
radiused fiberglass fender project for 67-72
Mordachai is offline   Reply With Quote
Old 01-20-2008, 07:40 AM   #15
matthufham
another thing, my dad claims the inner fenders are an essential part of the cooling system. the fan has needs its shroud and inner fenders to work properly. sounds stupid to me. on my last truck he made me buy a set of inner fenders, which i didn't have, for that reason.
Old 01-20-2008, 08:54 AM   #16
crazy longhorn
Fabricate till you "puke"
No sir I have been running a steel tilt clip, with no inners for about 10,000 miles.....& she runs nice & cool. I will say shes he!! on air filters tho.... crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 01-21-2008, 01:32 PM   #17
Lated
Lated's Avatar
Forgive me if what follows doesn't make much sense but I've been hittin' the sauce tonight. If I remember correctly the tires are 235/70/15 and I did have an allingment done. The shop couldn't quite get the camber to spec, they said it's at 0.9 and should be 0.8, but it should be close enough. I put new shocks on when I lowered it. Would some sort of adjustable shock let me raise the front just a little? The shocks were a pain in the ass to get on due to the angle of the lower mount on my new control arms (I'll try to post a pic tomorrow) and I wonder if they might be too short and it might sit higher with different shocks. The tires only hit when I hit a pot hole too hard. As far as new wheels and tires go the tires are brand new and the wheels are just what I had from my parts truck. Later this year when I've saved up a little cash I was planning on buying shorter tires for the front and wider tires for the rear (and possibly new wheels front and back) and just using what I have now for snow tires. It looks like the general consensus is to keep the innerfenders on.
Old 01-21-2008, 03:14 PM   #18
Riveted1
Tasty Cakes!
Riveted1's Avatar
A.) You just answered your own question....
B.) You could go to a lower profile tire and probably not have that problem (as bad)
Like the others said, you shouldn't have to do anything w/the fenders w/the drop that you have.
I'm a little and a lot
Ground beef: A cow with no legs.
'66 Chevy SWB "Penny"
'67 Chevy Big Window SWB- aka "Pearl"
'72 Burb- "Betty" "It's not a hearse dammit"
'99 Chevy Ext. cab Silverado
Riveted1 is offline   Reply With Quote
