Old 10-18-2002, 02:49 AM   #1
blowermtr
Brakes don't work
I did the conversion to pwr brakes and from drum to disc/drum set up on my 67/68 chevy. Every thing worked great except... the rear brakes. I have replaced the master cyl. 3 times, the booster, all lines, calipers, wheel cyl, and took the prop valve off an 81 chevy. The fronts are great but i can't even get pressure to the rear to bleed them. Please help me stop.
Mike D
67/68 slammed, blown C10 so close
blowermtr is offline   Reply With Quote
Old 10-19-2002, 06:01 PM   #2
guitarman
Do it well or don't do it
guitarman's Avatar
You probably have a crimped line or trash in the distribution block. Pull the lines from the rear drums and at the distribution block and use compressed air and try to blow them out. If after that you get no air flow replace the rear lines or the distribution block or replace both they are cheap any way.
Try to be the person your dog thinks you are.
Excellent paint and body site:
http://www.autobody101.com/
Visit my Web Site
http://home.attbi.com/~agfosteriii
guitarman is offline   Reply With Quote
Old 10-19-2002, 06:14 PM   #3
crazy longhorn
Fabricate till you "puke"
You might also check for a collapsed rear brake hose. good luck.......longhorn
crazy longhorn is offline   Reply With Quote
Old 10-22-2002, 09:53 PM   #4
Spoof
Spoof's Avatar
I'm sorry if this is vauge but...the proportioning valve (at least on 71 models) has a reset button on the front of the valve. It needs to be pulled out and retained while the brakes are pumped I believe, this will reset the proportion of braking power between the front and rear brakes. I don't have my service manual handy so I can't elaborate or even know if this could be part of your prob. Good luck any how.
71 GMC 1500 LWB
Spoof is offline   Reply With Quote
Old 10-28-2002, 10:26 PM   #5
guitarman
guitarman's Avatar
Spoof, that's a new one on me I don't think that factory GM p-valves are adjustable.
Visit my Web Site
Old 10-30-2002, 10:41 AM   #6
1-PU70
1-PU70's Avatar
There not adjustable but when you bleed the braks sometimes the light in the cabe coimes on and the switch inside needs to be centered .
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters
1-PU70 is offline   Reply With Quote
Old 11-04-2002, 02:19 PM   #7
Alex Hayley
How do you center that switch?
Alex Hayley is offline   Reply With Quote
