01-23-2008, 11:19 AM | #1 |
One of the First
WTB-Engine stuff
I have 71 SWB 4x4 with a 454 CID squeezed between the rails, I’m going to change it back to a standard ‘71 – 350 CID, 4x4 setup. So, I’m looking for the following items:
1. Spark plug shields. 2. Little spark plug wire holders tabs that bolt to the oil pan and the ones that fit on the back of the motor and by the distributer. 3. Timing chain cover, timing tab and hardware for a 72 truck, 350 CID. 4. Valve cover set, 68-72 truck, Passenger side, standard / drivers side, big hole in rear for oil filler tube/front-pcv valve. 5. Also, a cap/plug that goes into the top of an oil filler tube. Dog chewed mine up… 6. Two belt, crankshaft/harmonic balancer pulley with bolts/ 2 belt water pump pully 7. Flywheel with bolts 8. 4x4 dipstick and tube 9. Any hardware, too. I know some of this stuff is take –off time consuming with a low payback, but thanks for thinking about it, nothing really survives to long in Florida junkyards.
DAVID PASSMORE ST AUGUSTINE ,FL ZIP 32084 '71 SWB K/10 CUSTOM DELUXE (Chili) '72 BLAZER K/5 Muscle Truck (Mule) '72 LWB K/20 CHEYENNE (Blackie) |
01-24-2008, 12:40 AM | #2 |
One of the First
Re: WTB-Engine stuff
Back up to the top!
01-24-2008, 06:03 AM | #3 |
Real Projects never die
get with teeitup (randy) he goes through alot of trucks.
Ill put it this way, ive got a few lawn ornaments My name tag says Ryan KansasTwister On other forums
01-24-2008, 08:10 AM | #4 |
One of the First
He is fresh out...Kinda hoping one of the bigger used parts dealers on the board will come through as a package.
01-25-2008, 10:05 AM | #5 |
One of the First
Hmmm?
01-26-2008, 11:42 AM | #6 |
One of the First
Ttt
01-27-2008, 03:22 AM | #7 |
I probably have some of this stuff. I'll take a look and see.
Flywheel? manual trans or auto? Pulleys, short waterpump or long?
72 C20 4X4 454 4 speed 89 Trans Am (was) 305 TPI 700r4 93 C1500 2wd Extended cab 350 700r4 98 Sonoma (TPI outa the Trans Am) 03 Yamaha 660 Raptor 03/04 660 Raptor 07 700 Raptor 85 Honda Odyssey |
01-27-2008, 04:24 AM | #8 |
One of the First
Flywheel, Auto / Short water pump. Thanks
01-28-2008, 06:19 AM | #9 |
One of the First
01-28-2008, 11:45 AM | #10 |
PROJECT 7DEUCE
I have the timing chain cover but you could most likely get one closer cheaper then the shipping would cost..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
01-29-2008, 04:39 AM | #11 |
Got some pics of the stuff I've found so far.
I might have the 2 groove waterpump pulley too, but i'm not sure. if I get pics of the ones I have, could you identify it? The pulleys above can "stack up" to go various forms of pulleys;
01-29-2008, 09:46 AM | #12 |
One of the First
454, let me get some measurments on the Fly wheel, Its just the basic set up on the pullies, two belts on the crank and a single belt on water pump.
01-30-2008, 12:20 PM | #13 | |
Most trucks would use the bigger flywheel I'd think. (168 tooth IIRC) single groove water pump pulley will be alot easier to find. I'll get some pics asap. I'll get some measurement on the crank pulleys too. one of them is bigger dia than the others.
01-30-2008, 02:59 PM | #14 |
One of the First
Give me through the weekend, I'll be out at my storage barn. I'll get some measurements an compare with you. Thanks _D
