Old 01-24-2008, 04:01 AM   #1
SkylineNXS
SkylineNXS's Avatar
2000 GMC Sierra 1500 4x4 drop?
Hey guys. My dads got a 2000 GMC Sierra EXT cab 4x4 that i drove through my last 2 years of highschool. Its got the torsion bar setup in the front and i was wondering if anyone knew if it was possible to drop the front and how far? I think ive found spindles that are supposed to work that are 2 inches and then LMC has torsion keys that are adjustable (1" - 2"), but they say their for the suv's, and i wasnt sure if these would work? For the back i would just do blocks and shackles or a flip kit or something...thanks, sorry for the long post...how bout a coulpe pics...one of as is, one of maybe...?...
BRAD
2000 GMC Sierra EXT Cab Short 4x4, finally mine...
1966 C10 SWB Fleet, 250 I6, three on the tree....
Previously Owned....
1987 Chevy R10 "Silverado" (at least the badges were) Short Step 350 700r4....
1972 Chevy LWB Fleet 350/350
EXTENDED CAB ALL THE WAY!
.._..~...-...._...____
.._..-...______|_|__\____
..-..~.|_(O)__|_|__|_(O)]
SkylineNXS is offline   Reply With Quote
Old 01-24-2008, 02:03 PM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: 2000 GMC Sierra 1500 4x4 drop?
Nice truck. Sounds like you need to convert it to 2wd and go from there.
Who's truck is for sale in the background?
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 01-24-2008, 03:38 PM   #3
red02chevy
How low are you wanting to go?
Up front you can do spindles and/or drop keys. Both will get you about 2" each.
For the rear you can get a flip kit, shackles, hangers, or drop leafs. I'd start out with removing the block and then go from there. After you remove the block and you decide that isn't low enough make sure that you install a bolt in notch on 5 or more inches of drop. If not it wont be a very good ride.....
If you need any more help PM me or post up here
red02chevy is offline   Reply With Quote
Old 01-25-2008, 04:05 AM   #4
72BlckButy
Tot Roddin'
72BlckButy's Avatar
This truck would look sweet though if it was brought closer to the pavement..
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 01-25-2008, 05:47 AM   #5
Pyrotechnic
Pyrotechnic's Avatar
Or...you can get the AWD transfer case out of a SS, Denali, Escalade, etc...and convert to AWD. That'll shut anyone up who wants to criticize you for lowering a 4x4. Don't forget to remove the Z71 sticker.
Pyrotechnic is offline   Reply With Quote
Old 01-25-2008, 08:24 AM   #6
SkylineNXS
SkylineNXS's Avatar
The truck in the background is mine, the main reason we use the 4 wheel drive isnt necessarily for offroading but really just to get through conditions a 2wd wont, like snow. My parents own a small piece of land in wisconsin and to get to it there is a rather steep windy gravel road, nad in the winter, 2wd just doesnt do it, that and doin some sweet doughnuts in the highschool parking lot. Really i would just wanna o for like a 3-5 drop or maybe a little less, i just dont really like the way the fenders are so far above the tires, im sure somebody knows what im talkin about. Of course this isnt my truck, but i might somehow cut a deal with em and sometime make it mine, but for then i suppose...thanks guys...
BRAD
Old 01-25-2008, 10:22 AM   #7
kszygc
The problem that I see is the compression stops in the front end. I read that one of the reason that lifted chevy's with the torsion bar suspension ride all screwy is that they lift the suspension up off the compresson stops. GM engineered them into the spring system. They are not just bumpstops. They add to the spring rate of the front end torsion bars. Take a look at the front end at normal ride height. The compression stop are touching the lower a-arm, aren't they? It might be fine if you pull them out, then measure the opening and cut off a portion of the stop. I'm not sure if this would cause problems or not.
One of the lift companies, either Superlift or Skyjacker include spacer washers to maintain contact with the stop and lower a-arm.
I bet it would pretty tough sitting down low. What size tire are you running? My 99 Z71 has 285/75/16's and they don't have a lot of fenderwell space, although much more than the second image you have. they just kinda touch a little bit at the back side of the well at full lock.
kszygc is offline   Reply With Quote
Old 01-25-2008, 02:05 PM   #8
SkylineNXS
SkylineNXS's Avatar
Yea i was wondering about those "bumpstops", but never figured out how it really worked. I guess now i know, and yes they do touch at ride hight, and i see the dilema. Im not quite sure what size tires they are, sorry, im 3.5 hrs from the truck right now, sadly, so i cant really check it out...thanks...
BRAD
Old 01-26-2008, 03:46 AM   #9
67ChevyRedneck
67ChevyRedneck's Avatar
You probably won't be able to get it anywhere near as low as the second pic, but these may help:
http://www.gm-trucks.com/forums/inde...opic=45491&hl=
http://www.gm-trucks.com/forums/inde...opic=56687&hl=
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 01-26-2008, 06:00 AM   #10
SkylineNXS
SkylineNXS's Avatar
yea i kno, im not plannin that low, just 4 fun...thanks for the links
BRAD
Old 01-26-2008, 09:45 AM   #11
kszygc
I knew that I shouldn't have looked at those links. Now I want to drop my Z71! But my driveway entrance may disagree with me.
Old 02-07-2008, 10:54 PM   #12
Joe67
67 is sold
No need to convert it to 2wd, not sure where that comes from.
There are kits out there for 4x4 trucks, let me dig up a few links.
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
Old 02-07-2008, 10:58 PM   #13
Joe67
67 is sold
Here are a few from FSC.com - they have a forum dedicated to this
http://www.fullsizechevy.com/forums/...-6-8-drop.html
http://www.fullsizechevy.com/forums/...x4-7-drop.html
