Old 01-27-2008, 02:45 AM   #1
Tomsriv
Tomsriv's Avatar
Does anyone reproduce the choke bezel?
I have seen the wiper/headlight bezel for sale from the Truck Shop, but I would like to do all of them so it matches. I looked in the LMC and Brothers truck parts catalogs and it appears that none of those three reproduce the choke bezel, or the choke with the stock knob for a 65.
Also, I ordered a cigerette lighter because the PO, my brother, removed it and put a new choke there because the cable wasn't long enough to reach.
How does the lighter attach? I have the part and it looks like it needs to be held in position from the bottom side.
Tomsriv is offline   Reply With Quote
Old 01-27-2008, 03:36 AM   #2
kris's66lwb
resident wrencher
Re: Does anyone reproduce the choke bezel?
they should try chevy duty as for lighter i think the pice that holds it from the botems is like the one on the ignition its a flat nut looks like a home made sheet matal nut that backs to the bezelk and a a collets type nut should sandwich the bezel between the two
kris's66lwb is offline   Reply With Quote
Old 01-27-2008, 07:38 AM   #3
63sbssbbw
UCA63
63sbssbbw's Avatar
I believe they are kind of a one piece unit,the bezel and collar part that holds the cable are the same unit.
run the business end through hole in dash,slide nut onto cable ,thread cable through firewall,tighten up nut at backside of dash.
My factory ones have the knob molded right on,repros might be diifferent.
Hope this helps
T
member#7816
"63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt
'61 GMC in progress
'63 GMC to use for parts
'90 Chevy Ext cab sbfs 5.7l (current d d)
63sbssbbw is offline   Reply With Quote
Old 01-27-2008, 11:13 AM   #4
LILRED66
LILRED66's Avatar
The factory throttle cable is retained in the dash bezel with the bezel nut. The throttle knob unscrews from the trottle cable and is inserted into the dash bezel from the backside. The bezel nut tightens onto the throttle cable assembly and the throttle knob is screwed on.
I am not aware of any aftermarket suppliers providing the throttle cable bezel nut. I have a number of them in my inventory, if you need a good, used bezel nut.
The cigarette lighter is a two piece assembly. The two pieces unscrew from each other. The male piece drops into the dash bezel from the top and the female piece secures it to the dash bezel from the backside by threading the two pieces together. The lighter element can then be inserted into the assembly.
I hope this information is helpful.
LILRED66 is offline   Reply With Quote
Old 01-28-2008, 06:50 AM   #5
63sbssbbw
UCA63
63sbssbbw's Avatar
Sorry 'bout that Tom, it was the fresh air vent pulls that I was workin' on
Must of had a spell of HIAS (Head In A$$ Syndrome)
Thanks lilred, I was really scratchin' my a$$ when I read your post ('cause that's where my head was).
Again, sorry guys ,hope I didn't confuse any one
Thanx T
member#7816
'61 GMC in progress
