drag it like you stole it
rear bag placement
anyone see a problem with putting the bags over the axle on our trucks? i have a 7" step notch that i was going to run box tubing from one side to the other. then have my mounting plates welded to the rearend and to the tubing. the reason i say this is because i have a 3" gap there (between the tubing and the rearend) when the truck is laid out and my bags, when fully compressed, are 3". i dont have that large of a gap in the coil spring spot. thanks for any input
negative camber //LA\\ |
My dad's 68
are you running the stock trailing arm setup or leaf? if your running the trailing arm setup then why put them there if you can put them where the springs go and get more lift from them?
Jack M. 67 C-10 SWB 355 built T-350 tranny hurst shifter 17x8in KMC's on michelins, clear tails and back up lights slammed**UPDATE i have decided on my bag setup and will post further info when i recieve all the parts ****************************** 88 1/2 ton suburban 4x4 350/700R-4*having a 9 in lift w/ 38 in tires 4 12 inch Lightning Audios ****************************** 87 silverado 3/4ton jacked up 10-12 inches black and rubberized bed coating 35 in michelans ****************************** Dad's truck 68 C-10 stepside, 468 BB, tubbed, weld wheels, Nason black,lots more ****************************** grand dads truck 68 C-10 stepside fuel inj. 350/700R-4*soon in audi silver* ****************************** 84 toyota pickup 22R 5 speed 2WD slammed, shaved and all the body lines filled w/ buickGN scoop,bout to be sprayed in 2003 mustang green metallic w/ silver flames ****************************** S/N=BIGGYTYME@aol.com (hydros) "No fat chics, truck will scrape" |
So Many Ideas, So Little Money
I think thats ok to mount them on top, look athow semi's and sh*t re set up, there are s manyways to do it. I think over the axel wouldn'tbe any worse on a bag than on the trailing arm
72 Blazer 3/4 ton running gear 4.10s NP205/TH350 350 4in lift half doors 71 C10 with 454 99 S-10 5.1L SBC 700R4 09 Malibu ![]() Marshalltown, Iowa |
The only thing that i have heard about this set up is that it is a rough ride but i have never experienced it
