Old 01-29-2008, 02:49 AM   #1
fuelpump
fuelpump's Avatar
A real stupid question
I want to get my cigarette lighter to work so I can charge my cell phone. There is no wiring going to it. All I have is the empty female receptacle (see pictures). The replacement lighter assemblies that I see in the catalogs include the receptacle. Do I need a complete kit or can I just hook up power to the tip in the back and buy a universal element???
fuelpump is offline   Reply With Quote
Old 01-29-2008, 02:59 AM   #2
poorboy
poorboy's Avatar
Re: A real stupid question
This is what I used. 1 wire to grond and 1 wire to the fuse box.
63 short fleet Patina build
http://67-72chevytrucks.com/vboard/s...d.php?t=287751 Man I want another one.
poorboy is offline   Reply With Quote
Old 01-29-2008, 04:19 AM   #3
fuelpump
fuelpump's Avatar
Thanks for the pictures. So how does the female recpticle disconnect fron the dash??
Old 01-29-2008, 04:37 AM   #4
SIR
SIR
SIR's Avatar
...it un-screws (note threads on back of piece)...
66long low fleet http://community.webshots.com/user/LVNR66
SIR is offline   Reply With Quote
Old 01-29-2008, 05:00 AM   #5
fuelpump
fuelpump's Avatar
Yea I see the treads on the back. But I still don't see how the whole assembly is attached to the face of the dash.
Old 01-29-2008, 05:06 AM   #6
63 & 64 Bowties
and a few others
Look at poorboy's last pic. See the part with the 3 vertical lines? Hold onto the threads and turn the part with the vertical lines counterclockwise. The outer sleave (very thin) is what goes up against the hole in the dash to hold it in place.
Bill US Army Vet -193rd Infantry
BlueRidgeMuscleCars.com
“The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi
63 & 64 Bowties is offline   Reply With Quote
Old 01-29-2008, 05:55 AM   #7
poorboy
poorboy's Avatar
Here's the assembly taken apart.
Old 01-29-2008, 06:34 AM   #8
502tripower
502tripower's Avatar
What Poorboy has displayed in his pic is a late model aftermarket element with -+ spades that would be used with a "Plastic" dash. The reason your original only has one terminal is because the fixture is attached to your dash "Metal" and that is what is making the ground. All you need to do is provide a power wire from the fuse block. A assembly manual is a very important asset in working on these old trucks. It will provide wiring diagrams. If you go to the wrecking yard you can find the correct terminal to fit your original fixture on most any 60'-70' GM vehicle. Good Luck
http://cgi.ebay.com/ebaymotors/ws/eB...ksid=p3907.m29
1963' Chev Custom Cab 502, 67' 435hp 3X2 intake, 9" 4:30 Posi
1961 Impala SS 348/350 4-speed 3:70 Posi
1961 Bel-Air Bubble Top 283 Turboglide soon to have a 348 3X2 4-speed
1950 17' Fairliner twin cockpit barrel stern 312 Y block 1X1 intake Borg Warner 1:1 gear
1957 Fleetform 14' twin cockpit barrel stern 1969 BP-125 Merc
1949 Transitier 3-wheel forklift Crosley 4-Banger
98' FXD
2002 2500HD
502tripower is offline   Reply With Quote
Old 01-29-2008, 08:50 AM   #9
fuelpump
fuelpump's Avatar
Thanks guys I got it out. I've got the shop manual but all it had was the wiring diagram. It didn't have anything on assembly.
I didn't realize there was an assembly manual. I guess that will have to be my next purchase. Thanks again guys.
