02-03-2008, 03:40 PM | #1 |
4.56 Rear Gears?!?!?!?!?!
I was playing around with a rpm-speed calculator this afternoon trying to figure out what the 700r4 would change my crusing rpm to. I typed in 3.73 rear gears with a 1:1 transmission ratio for final gear in the th350. I put in my tire size and all that and what it calculates is all wrong. So i started typing in other rear end gears because it is obvious that a PO was in the differential because there's blue gasket stuff all around the cover. I discovered that the closest rear gearing that matches what my truck actually does is 4.56.
Were these gears ever put out on these trucks or did someone change the gearing in my differential? If anyone else wants to play around with their own calculator to see if I'm all wrong here's what I have. Turbo-350 235/75/R15's. At 55MPH Im running about 2800RPM give or take a few. |
02-03-2008, 04:57 PM | #2 |
Re: 4.56 Rear Gears?!?!?!?!?!
I know that some 3/4 ton configurations were available with a 4.57 diff. Not sure about the 1/2 tons. Jack up one wheel,turm the DS by hand 2 1/4 revs and the wheel should turn one rev with 4.57s (open diff).
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme. Last edited by WorkinLonghorn; 02-03-2008 at 05:03 PM. |
02-03-2008, 11:33 PM | #3 |
I came up with 4.11 running about 2700 at 55, 4.56 came in at 3000 at 55.
67 Short Step, 355, 700R 4.11 posi rear, 4/6 drop Discs on all 4 corners. Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=219094 |
02-03-2008, 11:48 PM | #4 |
4.11's would make more sense to me. The calculator I was using could be off some i suppose. Ill try jacking up the rear end tonight to see if it matches what workinlonghorn said. I'd do it this morning but I'm going to Oreilly's Autofest with a couple of friends. Either way I'm going to want to try to find a 3.73 differential to drop in this thing.
02-04-2008, 12:18 AM | #5 |
Still Just Havin Some Fun!
I came up with 4:11 also.
a green one with some stuff done to it.... |
02-04-2008, 01:23 AM | #6 |
I had one with 4.56 from the factory.
02-04-2008, 01:45 AM | #7 |
Well, Whoop-dee-do!
The old automatic trannys without a lockup torque converter will "skew" calculations since there is no mechanical coupling of the crank-to-driveshaft. Even when engine rpm is way over the converters stall speed, it's not a true 1-1 ratio. Generally, you can figure 200-300 rpm more than what the calculator shows- if you have an old TH350, 400, powerglide, etc.
'68 GMC shortbox 4x4 350/SM465/T221- bought it in '83 SOLD '72 K20 500 Cad/TH400/NP205 SOLD '92 Chevy 2500 6.5 mech TD 4L80E crusty daily driver '72 Monte Carlo... sweet low mile toy '11 Dodge Challenger IE 392 6spd... midlife car |
02-04-2008, 10:20 AM | #8 |
All I know is somethings got to give because I went to springfield today and was running 4000 RPM constant on the Interstate. There's no way that's anywhere near good on the truck.
02-04-2008, 11:35 AM | #9 |
Yeah, that's getting a little excessive on a driver, or just about any street motor.
I bet she's fun in low gear though. Jay
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape. If a hammer doesn't fix it, you have an electrical problem! Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels! |
02-04-2008, 12:07 PM | #10 |
Official Site Guitar Shredder
i run a 4.56 posi rear ...love it....not very pratical on the freeway but lots of fun light to light driving....when it was all together i ran about 2900 at 55mph.....i think this time around i will run either a 3.42 or 3.73 spool.....?
02-04-2008, 12:52 PM | #11 |
1972 Chevrolet SWB
With overdrive transmissions and tires in the 31" range 4.11-4.56 gears can actually be used. On my 2002 Ram with 3.92 gear and 4 speed overdrive I swapped to 4.56 and only gained 300 rpm across the entire mph scale,it also helped my lil 287 (4.7) V8 run much much stouter. My 04 Ram has a hemi,3.92 and 5 speed auto and I will also place 4.56 in it. Since the overdrives are so efficent adding lower gears dont cut down as much on your top end and can actually increase fuel mileage. 4.10s with a slightly shorter tire and overdrives work great also.
My New thread with pics (not my build thread yet.) http://67-72chevytrucks.com/vboard/s...46#post2573646 1972 Chevrolet 1/2 ton short wide bed,68 frt clip Project. 1980 Camaro Inherited when father passed,68K Miles 2003 Ford Mach1 FUN as Hell!! 2002 Dodge Ram 5-8 slam Rolling BillBoard (Gone not forgot) 2004 Dodge Ram HEMI 10" lifted on 37's and 2wd. |
02-04-2008, 02:57 PM | #12 |
Oh yeah she's real fun in low gear. But I'd give that up anyday for the better gas mileage. I did the BEST burnout I've ever done today in Springfield. But I'd rather not be able to do that than run 4000 RPM on the Interstate when I head home.
02-04-2008, 02:58 PM | #13 |
I notice that the gear is listed (ref.Truck Data Book) as a 4.57 unless it's a Dana,then it's a 4.56.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme. Last edited by WorkinLonghorn; 02-04-2008 at 05:19 PM. |
02-07-2008, 07:18 AM | #14 |
But the top of that page says C-20. Mines a C-10. Would that make a difference?
02-07-2008, 11:31 PM | #15 |
Welcome to the club. My C-10 has 4.56 out back on 27" tires. Its painful onthe interstate.
85' CUCV M1009!!! The newest addition! 6.2diesel, Th400, NP208, & only 36k miles! 70' C-10 LWB Fleetside - Looking good these days! 05' Dodge Neon 88' Winner Escape Sport 1750 - 4.3v6 94' Seadoo SP 84' Honda TRX200, bare nekkid. Just a frame & tires. Always looking for another project or any good deal! |
