Old 02-06-2008, 09:00 AM   #1
tvblazer78
Low & Fast!
tvblazer78's Avatar
Smile Help!! 04 Yukon power and heated seats or not working!
I have an 04 Yukon with power and heated seats. My drivers seat will not work but my passenger seat will work, but my heaters in both of my seats will not work. I have checked all fuses and relays and did not find any thing wrong. I am lost on this one, I have looked under the drivers seat to see if it came unpluged and it looked good. So please let me know what I should look for.
Thanks,
Trav
tvblazer78 is offline   Reply With Quote
Old 02-07-2008, 08:26 PM   #2
WLPTMP
Active Member
WLPTMP's Avatar
Re: Help with my 04 Yukon powers and heaters seats!
there buttons on the door on the drivers side is actually a module and may need to be reprogrammed or more than likely replaced.what happens is they get wet from window being open or some people hang a cup holder above it and stuff drips on the controls
good luck
WLPTMP is offline   Reply With Quote
Old 02-08-2008, 04:37 AM   #3
tvblazer78
Low & Fast!
tvblazer78's Avatar
Thank you, I will take a look at that..
Old 02-08-2008, 10:39 PM   #4
tvblazer78
Low & Fast!
tvblazer78's Avatar
Got it fixed last night, I could kick my own butt!! The main plug that sends all the power to both seats had come lose. You could not see that it had came lose, but I pushed on it and it made a click.
Thanks for your help.
Old 02-14-2008, 09:56 AM   #5
jamie72
jamie72's Avatar
hey .. i am having similar problems with the wife's avalanche.. drivers side heated seat kicks off when you turn it on .. but the passenger side works fine.. can you tell me where to look for this plug at??
thanks
jamie72
72 BB cheyenne -- Restoration getting started..
member #807
http://www.myspace.com/whitetailobsession
www.antlertalk.com
jamie72 is offline   Reply With Quote
Old 02-14-2008, 01:27 PM   #6
BP68
BP68's Avatar
thanks
I would check that plug, but generally when I see one of these with the pass side working and the driver side kicking off, it usually means an open (burned) spot in the driver's seat back heating element. If you unhook the seat back cover and pull it up or out far enough to peek up inside between the cover and the cushion you can usually see the burned spot in the element. Generally toward the top outer side.
68 C10 Shortbed Fleetside
06 Chevy Ext Cab Fleetside
03 Grand Prix GTP
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=269999
BP68 is offline   Reply With Quote
