Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 02-08-2008, 06:20 PM   #1
Super73
Super73's Avatar
Holly stored energy (Front spring change)
They were a little tough going in.
Had to compress the spring 7" or so
Drop the control arm from the cross member
Set the arm with spring in it under the pocket
Jack it up a little to set the ball joint and shock
Jack up the cross shaft with a block of wood
Bolt it all together
Release the spring
Moroso Sring 47140
240lb rate
17 3/8" long
Truck sits about 3/4" higher than it did with the 14.5" 350lb springs.
Yesterday I pulled the ball joints out of the upper control arm and mounted them from the bottom side.
I have about 6" of true apward travel with out the spring settled yet.
Heated up the tires on a test road and left. It tops the suspension out now even on the 70/30 front shock setting. I was using the 90/10 before with the other spring. I tried to slow down the lift with the 70/30 setting after taking it for a ride in the 90/10 setting..
http://73-ls1.com/63truck/gtech/Movie_0005.wmv
Super73 is offline   Reply With Quote
Old 02-09-2008, 11:38 AM   #2
Outlaw72
Hay Team!!
Outlaw72's Avatar
Re: Holly stored energy (Front spring change)
Awesome!
1972 Chevrolet Cheyenne LWB "Orange and White" 8)
Outlaw72 is offline   Reply With Quote
Old 02-09-2008, 11:50 PM   #3
whatnow123
whatnow123's Avatar
cool video however, I think you were breaking the law.
67 Short Step, 355, 700R 4.11 posi rear, 4/6 drop Discs on all 4 corners.
Build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=219094
whatnow123 is offline   Reply With Quote
Old 02-10-2008, 05:30 AM   #4
Super73
Super73's Avatar
I data loged the whole thing.. I never went over 45mph
Old 02-10-2008, 06:11 AM   #5
PA-IndianRider
PA-IndianRider's Avatar
Love those kind of "night sounds"..... still sounds "illegal" to me....HA!!!
John aka "Milner"
PA-IndianRider - Pittsburgh, PA
70 Chevy C10 Stepside
"Gasser/Altered Drag Race Hot Rod"
Where were You in '62 ?
PA-IndianRider is offline   Reply With Quote
Old 02-12-2008, 01:35 PM   #6
Outlaw72
Hay Team!!
Outlaw72's Avatar
Nuthin wrong with a lil night TNT on the access road
