Old 02-11-2008, 01:14 PM   #1
tyjoja
fuel pump change
Hey guys, a little off topic here, but I need some help if possible. I'm usually here on the 73-87 posts with my 73 shortwide, but have a question on my wifes 2000 astro van. It died on her and it looks like the fuel pump the chev garage wants 1000.00 plus to fix it, so I've been trying to research here and there to see if this is something I might be able to do on my own. I'm not the best mechanic around but do okay on most of the basics. Any help or hints would be much appreciated. do I need any special tools? I saw on ebay a new fuel pump for a 100.00 bucks, is this the way to go? the part from chevy is 5 to 6 hundred and 3 hundred from autozone. thanks in advance bob
tyjoja is offline   Reply With Quote
Old 02-12-2008, 06:58 AM   #2
mothertrucker424
mothertrucker424's Avatar
Re: fuel pump change
drop drive shaft out
remove gas
disconnect lines and hoses and pigtail
support tank
remove 2 straps
you may need to jack van up to get tank out from under
its a tight squeeze getting it in and out but possible
and befor removing the old unit blow top off so that dirt doesn't fall into tank
its probally a larger job in a driveway but on a rack its probally a hour
or you could try a local shop
_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-
1972 K10 4"lift 33"tires (soon to be bigger and better)
2000 silverado 1500 2wd 2"coil spacers3" BL 285/75/16's
mothertrucker424 is offline   Reply With Quote
Old 02-12-2008, 07:04 AM   #3
EyeH8the24
EyeH8the24's Avatar
hope it isnt like our trans am was ...had to drop rear end,to get the tank out
EyeH8the24 is offline   Reply With Quote
Old 02-12-2008, 12:35 PM   #4
tyjoja
thanks guys, I'm going to give it a shot, appreciate the help bob
Old 02-13-2008, 01:46 AM   #5
RANDYC
clay
Make sure it is the fuel pump, i know these trucks are noted for bad fuel pumps, However had mine replaced ($650) and problem still exists. I know you guys are thinking dumb@#$, I know I am live and learn, I already knew it was not a bid job, but I was out of town, I know Im still a dunb@#$#
RANDYC is offline   Reply With Quote
