Old 02-13-2008, 08:40 AM   #1
samwise68
FarmBoy.
samwise68's Avatar
Clutch Questions?
Hey guys,
I have a few questions regarding my clutch, and those that can replace it.
First, the clutch on my 307 is an 11 inch. Will a 12 inch work with the fly wheel, if i replace the clutch and pressure plate?
Second, if the 12" will work, can a 12" from like, a '95 Chevy, work in my '69? They're both small blocks...same bell housing..fly wheel...etc.
Now, the explanation. I'm low on cash. my clutch is going to hell in a handbasket, to put it frankly. My dad works at the area salvage yard, and today a '95 Chevy came in with a good 12" clutch. he can get it pretty cheap, and save me lots moneys. (I know...I know...i shouldn't use a used clutch. but, gotta do whatcha gotta do.)
So, ANY input would be appreciate regarding the situation.
Thanks in advance guys.
-Sam.
1969 GMC C1500. long fleet.
307. 3 on the tree. 3.07 gears.
Oliver green. Bent and bruised. Daily Driver.
Screw patina... it's a beater...Beaters are cool.
my build thread - Project Homebrew:
http://67-72chevytrucks.com/vboard/s...d.php?t=242993
samwise68 is offline   Reply With Quote
Old 02-13-2008, 08:55 AM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: Clutch Questions?
My 69 came originally with a heavy duty clutch setup and when I converted it to the lighter duty (got cramps in my legs) that had a smaller clutch diameter, I had to replace the flywheel, clutch and plate. The bolt pattern of the pressure plate was different on the heavy duty, larger diameter clutch and pressure plate.
68gmsee is offline   Reply With Quote
Old 02-13-2008, 09:32 AM   #3
samwise68
FarmBoy.
samwise68's Avatar
Ah, thanks 68gmsee!
Thats just the info i needed.
I'll order a clutch disc from autozone on wednesday then for my 307, and hope that my pressure plate isn't screwy. I don't think it is, just the clutch is so worn down that it's not grabbing good.
thanks again. i really appreciate it.
-Sam.
Old 02-13-2008, 09:57 AM   #4
Ace in the hole
If you are looking for a used clutch, I have one I just took out.
1970 K20, 350--- SOLD
05 silverado extended cab short box- duramax
Jeep wrangler unlimited
Ace in the hole is offline   Reply With Quote
Old 02-13-2008, 10:21 AM   #5
passthebuck
Sisyphus was my mentor!
passthebuck's Avatar
I did this exact swap - my 67 250/3sp came with an 11" clutch & I was able to replace it with a 12" out of a new diesel by merely changing the throwout bearing, clutch & the pressure plate. The clutch dude who sold it to explained that the 10" need their own setups (flywheel, pressureplate, etc) but the 11s & 12s share the same flywheel, just a different clutch plate & pressure plate. i know its extra money, but ya gotta get the flywheel ground. the 11" left a bit of wear that the 12 will be bigger than. Its cheap - like 15-25 dollars.
passthebuck
#5642
-TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4.
-a 2013 Honda Civic as my "sensible" car
passthebuck is offline   Reply With Quote
