02-15-2008, 11:09 PM | #1 |
I do everything twice, so what
Location: To the Right. One may go as far to say WAY to the Right
A little Progress
thought a I'd show a couple progress pic's
got the full hydro stearing mounted wheels fit & finally clear everything upper links mock'ed up
www.hilbillytruckpulling.com |
02-15-2008, 11:15 PM | #2 |
Re: A little Progress
sled puller huh?!? I'm suprised to see old style closed knuckels up front - but think it's awesome you're still using them!
I want to see more...
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current 1969 K20 - V8, 465, 221, Eaton, D44 2012-current Nothin' but drums on all 4 corners! past horses in the stable 72 C10-short step (97-02), 68 C10-long fleet (06-12) |
02-15-2008, 11:22 PM | #3 |
Here's some of the axles. the front is a G.M 2.5 ton military, rear is a rockwell 106
02-16-2008, 02:44 AM | #4 |
Tot Roddin'
Da*#..... those axles are stout!
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
02-20-2008, 08:41 AM | #5 |
had to move the stearing to the front, the ram is mounted upsided down in the pic, sorry. had to change placement & length of lower links. got the scs t-case mounted and the drive shaft's running horz. next to install the rear housing
02-29-2008, 07:44 PM | #6 |
ROCKWELL 5 TON CLUB !!
looks good man,wish i could swing the $$ for a scs case in mine.
1970 K5 "ON THE ROCKS" PROJECT:500hp 6.0 fuel injected. 2wd sm465 trans,t136 2.5 ton transfercase,5ton rockwells with 9.34 gears,custom wheel disc brakes,full hydro steering20+" OF LIFT AND 67/35/25's..67" tall TRACTOR TIRES.."THE MUD SLUT!!" MY BUILD THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=221935 1997 TAHOE,SAS D60 14B,5:13 DISC BRAKES,CROSSOVER STEER,HYDRO ASSIST,42 IROKS HINT:NEW NAME "K5ontheROCKS!" |
03-17-2008, 07:26 PM | #7 |
A little Progress
When we started the install of the rear we noticed a problem. We'll my buddie Shane noticed I had cut the ds front links 3/4" to long. When he pulled the 133" wheel base for the install of the rear is what brought it our his attention. So that was fixed and the rear welded in. The next problem was fitting the MRT threee piece wheels on the hub. The went smooth after 2hours of grinding the hub down.
03-18-2008, 02:34 AM | #8 |
Are your front links bolted in single shear at the axle?
No suspension in the rear? Got to be a fun ride... |
03-18-2008, 10:13 AM | #9 |
Yes, the bars work more as ladders. The front will only move 3"-4" vert. controled by limit straps and bags.
As for the rear, the use of suspension is a non-issue. Trying to carry/pull 20klbs+ w/ any kind of rear spring is not possiable. This makes the set up of hitch angle & length important, followed up by front suspensioin and weight distance.
03-18-2008, 03:55 PM | #10 | |
I figured on the rear suspension, but it did crack me up to see it. Looks like a fun ride! |
03-18-2008, 09:55 PM | #11 |
I agree, a single shear would be nuts on high lift, mudtruck, rock crawler etc... driving around the pits w/o suspension feels like driving on railroad tracks. you can feel every lug on the tire
03-20-2008, 12:42 AM | #12 |
Road trip is only 300' so the ride would be worth a few little bumps.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
