Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 02-21-2008, 12:01 PM   #1
bill8333
Performance help
Hi Y'all. I'm trying to figure out what it's going to take to get my s/b up to 9.6 compression with 76cc 882 heads. I have the bucks to buy the summit steel heads 64cc but I’m not sure if I should go with the vortec or the stock ones. The truck is a 1981 GMC 1/2 ton 4x4 so it needs to pass smog in this state. What heads will give me better performance. The summit brand heads are 550 bucks till the end of the month then they go up 100 bucks and if I go with the vortec heads I’ll need to buy an intake as well. So that money for the intake will come out of my bottom end rebuild, like cutting corners on pistons. What do y'all think is the better way to go?
Thanks Bill
1972 K-10 L/B 4x4 Matching #'s 350 4 speed from the factory. P/S P/B
1981 GMC 1/2 L/B 4x4 one owner truck. 4" lift
2004 Dodge Cummins Diesel 4x4 Q/C S/B
1986 Dodge D150 L/B 2WD
bill8333 is offline   Reply With Quote
Old 02-21-2008, 12:20 PM   #2
Couch
Daily Driver
Couch's Avatar
Re: Performance help
IMO go vortechs. theyre advertised 64cc heads but theyre more like a 60. and from 76cc's that'll give you the comp that your seeking after
nitrous...the equal opportunity destroyer.
Couch is offline   Reply With Quote
Old 02-21-2008, 12:51 PM   #3
djracer
djracer's Avatar
vortecs run really well but if you buy used make sure the owner will stand behind them cause they crack real easy!
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 02-22-2008, 01:49 AM   #4
bill8333
So if I keep my stock bottom end Ill be able to get the compression up to 9.6 just with the vortec heads ??? Sounds good to me. I was going to put flat top pistons in her and go with the summit 64cc steel heads, keeping my crank and rods. Of course I'm going to change the cam but I'll need some help with that information from y'all.
Thanks Bill
Old 02-22-2008, 06:05 AM   #5
Couch
Daily Driver
Couch's Avatar
no prob. good luck with the build
Old 02-23-2008, 04:58 AM   #6
bill8333
If I buy a brand new set and it over heats the heads could crack. ???? Hmmm think I might stay with the summit heads. I do a lot of 4 wheel-in and she does have a tendency to heat up a bit when I get stuck in the mud, you know sitting still and rocking her back and forth.
Old 02-23-2008, 05:25 AM   #7
Billla
Billla's Avatar
I'm not sure I fully understand the question - are you overhauling the engine, or you're looking to raise the CR by bolting on new heads? If you're looking for hypereutectic pistons, there are a lot of choices that will work with any head selection.
Swapping from a 76 cc to 64cc head will raise the CR approximately 1.1 points.
A 1 point increase in CR is worth maybe 3% power increase on an engine that's making around 1 HP/CID...so unless you're stuck on increasing the CR there are other ways to make more power - and for less money.
I have no idea what the comment is regarding Vortec heads and cracking; I've never heard of this happening. They certainly don't "crack real easy".
More information on your usage and budget would help. Usage drives the cam selection, cam drives the head and the rest of the engine is built around those two pieces.
Billla is offline   Reply With Quote
Old 02-23-2008, 06:07 AM   #8
Couch
Daily Driver
Couch's Avatar
ive never experienced the cracking of vortecs real easy. and mine has gotten pretty hot in the past. there are 2 casting of the vortecs i believe the 062 or something close to that is the good casting to get
Old 02-23-2008, 11:21 AM   #9
bigjimzlll
bigjimzlll's Avatar
The rise in compression on paper maybe 3%, but the true advantage is the ability to use more cam...with the better heads, hence increasing the HP by way more than 3%
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 02-23-2008, 10:35 PM   #10
bill8333
It's a complete rebuild. I bought the engine thinking it had a rod knock and when I tore it down there was nothing wrong. So I figured I'd build it up and try to make more bottom end and mid range. Now I know I can put a cam in it but i'm looking for a little more than that and thats why I was thinking pistons and heads. As for buget i'd like to keep it under 1000 if possible. Buy the way it's not going into the 72 listed below it's going in a 1981 GMC 1/2 ton L/B 4x4.
Buy the way it's not going into the 72 I have it going in a 1981 GMC 4x4 1/2 ton L/B
Old 02-23-2008, 10:40 PM   #11
Billla
Billla's Avatar
Completely agree that the benefits of CR as part of the overall design has significantly more impact - especially as the build moves beyond 1 HP/CID.
Old 02-23-2008, 10:43 PM   #12
Billla
Billla's Avatar
If there's nothing wrong with the bottom end I'd just do a cam swap and some better heads and leave it - that'll use all of your $1000 by the time it's all back together.
Old 03-01-2008, 10:26 PM   #13
bill8333
In your opinion would it be better to go with Iron heads or aluminum. The iron heads will be the summit brand 152123 $585.00 a set, or go with the aluminum ones on e bay, link below. Remember this is going into a truck at 5000 feet elevation. Also I don't have the confident in myself or enough engine building experience to make this decision without input from people that have been there.
http://cgi.ebay.com/ebaymotors/NEW-S...mZ360027837974
Old 03-01-2008, 10:37 PM   #14
SRH916
1975 C-10 Silverado LWB
SRH916's Avatar
I was interning at a machine shop in sacramento, and I heard that Vortecs "weren't too good" which for a machinist means they crack easier, and are near impossible to fix. just my understanding on them.
1975 LWB C-10 Silverado
- Stock
- "BIG 10"
- 4 Bolt 350 "Brand new" 1200mi
- THM-375 "Brand new w/trans cooler" 5000mi
1995 Ford Lightning
- Bone Stock
- 351W
- Vortech??
SRH916 is offline   Reply With Quote
Old 03-01-2008, 11:34 PM   #15
malibu795
malibu795's Avatar
anything flow better than stock.
summits heads iirc are rebadged vortech heads...
mind you vortech is still and emission head as well iirc
peak flow is one thing avg flow is another. yes vortech have a high peak air flow. both dart and world have a high/flater curve than vortech... kinda like which motor would want peakhp of 525 avg hp 450 or peak 500 avg 475? hope that makes sense
and make more power on a same setup than vortech
IMHO i would take a pair of ~180cc s/r torquers or iron eagles over vortechs any day
got to pay to play and you get what you pay for....
-A DAM WILD MAN-
59 apache pannel truck 38 I-6/sm420
79 malibu wagon 305/t56
02 2500hd duramax/allision 1/4 13.82 @100 mph efi live and built tranny
500hp 383 on the engine stand
U.S. Navy 2000-Current
Peace through Superior Firepower
Horsepower = Condom.....I would rather have it and not need it than to need it and not have it
malibu795 is offline   Reply With Quote
Old 03-01-2008, 11:49 PM   #16
bigjimzlll
bigjimzlll's Avatar
I think the summit heads are a fuellie/camel head recasting.
Vortecs would be just fine. I havent used a set but a lot of friends have with good success. The only problems with them can be...intake gasket sealing and they require a different intake and center bolt valve covers. They are a thinner casting then an aftermarket head,
Those Ebay heads actually work quite well(if they are assembled correctly). They are cheap Chinese castings that don't have very good QC., but if assembled by someone who knows what their doing they work real well. I wouldn't hesitate using them on a street car(especially at altitude)
Anderson,CA
Old 03-01-2008, 11:50 PM   #17
bill8333
So your saying that iron would be better than aluminum and that the summit heads are iron vortec heads from GM but are being sold as summit. As fare as money wise the s/r torquers or iron eagle are the better way to go than the summit heads.
I was told that if I had a choice between aluminum and iron to always go with aluminum. Keep in mind the engine is smog headed and will need to pass smog in the future
Old 03-01-2008, 11:57 PM   #18
malibu795
malibu795's Avatar
to me it is funny the summits iron head have the same spec as gm iron vortech heads. go figure
As fare as money wise the s/r torquers or iron eagle are the better way to go than the summit heads.i would agree with that statement
I was told that if I had a choice between aluminum and iron to always go with aluminum.depend on the application pro/con both ways
alluminum is great and has it pros and cons over iron. and vise versa
as for the the need for emision you will be hard pressed to find a oem replacement head that is emision compatible.
s/r torquers are emisions and 50 state as well.
-A DAM WILD MAN-
Old 03-01-2008, 11:58 PM   #19
bill8333
Summit head in question above
http://store.summitracing.com/partde...5&autoview=sku
Old 03-02-2008, 02:10 AM   #20
bigjimzlll
bigjimzlll's Avatar
They look like fuelie/camel hump remakes...heres their discription(also the intake manifold gasket is non vortec)
Small block power for less!
Think you have to scour the local bone yards to find a decent set of GM's old double hump or fuelie cylinder head castings? Not true. In fact, we've brought back classic Chevy performance in a big way with these ready-to-run heads for small block Chevy. Our versions of the popular GM cylinder heads offer great performance for less than it would cost to rebuild an old set of double hump castings.
Anderson,CA
Old 03-03-2008, 03:05 AM   #21
PhilaTruck
Right on the line, baby!
PhilaTruck's Avatar
You may be able to keep within your emissions standards with the head swap, but when you chase the power with the cam, you're probably gonna drop out of spec, depending on how strict they are in Reno.
83 GMC 406 th400/3.73 Eaton Truetrac posi, headers, x pipe, & racePros. Tubular control arms, lowering rear springs, caltracs. Still ugly, but getting built right, although slowly
Click and scroll down for site vendors!
Subscribe here!
PhilaTruck is offline   Reply With Quote
Old 03-05-2008, 07:22 AM   #22
bill8333
Anyone in the Reno area that’s built an engine within these specs? please e mail me. I should just sell the darn thing and buy an older truck without the smog on it. It's hard to let go a clean one-owner truck that just needs a paint job, no rust, no bondo, and no dents anywhere. The only problem is the year.
Old 03-10-2008, 10:37 AM   #23
ton*loc
ton*loc's Avatar
just bolting on vortec heads is a 30-40 hp gain not necessarily because of the compression gain but because of the amazing flow characteristics of the head.
1986 chevy c10 in the "build" process as we speak 358 flat tops, vortec heads, .500 lift cam, NOS power shot plate system, yada yada yada
MMA PIX http://www.clgpix.com/MMA/Fighters/F...C/CoteTony.htm
MMA RECORD 24-5
ton*loc is offline   Reply With Quote
Old 03-11-2008, 08:23 AM   #24
djracer
djracer's Avatar
it has allot to do with the swirl and tumble of these heads
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
