02-27-2008, 10:16 AM | #1 |
BlahBlahBlah
Spid and sales order questions
My spid says I have a G86 no spin. Longhair told me that was a detroit locker. I was looking at my original sales order and it says I have G87max trac...Whats that? The spid doesn't list the G87 and the sales order doesn't list the G86.
Id like to learn a little bit more about whats going on under my truck. I get some pretty big clunking under there at times. Is there a tag or numbers on the front and rears I can take pictures of and post em here for identification? Id like to know the ratios too. The original owner told me they were 4 something but I dont remember. |
02-27-2008, 10:27 AM | #2 |
Re: Spid and sales order questions
I have seen a G86 MAX TRAC option on an GMC longhorn spid before. It's just Dealer Double speak for a Detroit locker. The G87 must be a fat-finger mistake (typo)
02-27-2008, 10:32 AM | #3 |
BlahBlahBlah
couple of pics...
02-27-2008, 07:26 PM | #4 |
So this "clunk" does it generally happen right when you get rolling under power? Maybe when you start a turn from a stop?
If you get a "SlipBANG" then no more noise it sure sounds like a Detriot. Mine freaked me out the first time it happend. I didn't know Detroit Lockers were around back then, then again never thought to try and find out..
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks |
02-27-2008, 07:38 PM | #5 |
Post Whore
My 69 K20 still has it's factory NoSpin (Detroit Locker)
The SPID says: 9514BB No Spin Rear Axle (and then maybe 4) Behind the drivers side of the seat is a sticker that states: This Driving Axle/s of this vehicle equipped with a NoSpin Differential for greater Traction, Safety and Economy NoSpin postively rotate all driven wheels under power Warning Elevate driving wheels when balancing servicing axles or brakes (See manual) Maintain uniform tire pressure Detroit Automotive Products Corporation 11445 Stephens Drive P.O. Box 441 Warren, Michigan 48090 U.S.A. Model No. KS-10
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
02-27-2008, 07:57 PM | #6 |
Does it have a Dana60?My`72 GMC has the G87 "Trac-Loc" listed on the SPID.It`s a limited slip.Mine`s great.If the clunk is from back there,it may be springs or clutches failing.Pull the cover and inspect it.That`s what Andy would say.Is yours a 4spd?
My`72 Chevy has the G86 "No-Spin" (Detroit Locker) in the Corporate rear and it`s a 4spd.I`m getting some scary clunks from that.I think the lack of "give" coupled by the rigid lock-up of a manual drivetrain is bringing out a problem with the trans or t-case.It occurs when I`m manuvering in 2nd or neutral,like parking,when I let of and am rolling.Sometimes it`s an outright "slip" then catch (clanky clunky).The problem started following rebuilding the rear and putting a locker back in.I actually put one in,had this problem,and then put another locker in...same problem.It only does it occasionally,I can drive it long trips and doesn`t slip while wheelin`.I expest to find an all but stripped spline/shaft situation.But,I can pull off just fine without any symptoms.Pretty strange,never saw this problem before.
02-28-2008, 04:00 AM | #7 |
special k hit the nail on the head. it all boils down to what rearend you have. if its the eaton, its a detroit...if its a D60, you have a powr-lok clutch type posi.
1969 GMC K2500 1996 Honda Accord 2007 Kawasaki KLR 650 |
02-28-2008, 05:18 AM | #8 |
BlahBlahBlah
Ill have to take pics and post em. I really dont know much about this kind of stuff.
02-28-2008, 06:49 AM | #9 |
Me neither.Just fake it like me.No one will know,except Adam.That sucka know his drivetrainin`.
02-28-2008, 07:14 AM | #10 | |
Thanks for the compliment, special-k. In my travels, I guess I should clear the above up, I have always seen the G86 rpo denoting a detroit locker with the Eaton rear, called a No-Spin. The G87 is Maximum Traction, or sometimes just posi, with the D60 rear. This is what I have seen.
03-08-2008, 06:02 AM | #11 |
BlahBlahBlah
Finally got a couple of pics of my front and rear ends. Please let me know what these are, and are these strong or weak...Thanks
And it does give me the slip bang. I bought this from the original owner and he said its always done that. He took it back when he first got it and they told him thats just what they do...get used to it. Mark Last edited by CG; 03-08-2008 at 06:04 AM. |
03-08-2008, 11:05 AM | #12 |
Yup, if it is all original it will have the "No-Spin" which is the same as a Detroit Locker, just the commercial name.
The sales order must have been a typo, it's not like these codes are confusing or anything...lol. Oh yeah, driving with a Detroit is interesting until you get used to it. Especially in snow!
03-08-2008, 05:39 PM | #13 |
Yeah,I agree,since it`s not a Dana60 and each of the two rears only came with the one optional traction device,both different.If you didn`t want a No-Spin(locker) you had to order a Dana rear.
Funny...musta been the same salesman that sold me my`92.When it came in and I ran it around the lot I told him it sure clanked bad at the rear.He told me the same exact thing.
03-08-2008, 07:51 PM | #14 |
What I see is an Eaton rear end and a Dana44 front
My fater-in-law has a 72 3/4ton p/u with the same setup, got the big external hubs on the 8lug D44.
03-09-2008, 07:43 AM | #15 |
BlahBlahBlah
Well it sounds like this stuff is pretty stout. Ill have to do some more crawling around under there. I want to figure out what gear ratio I have and I need to put some new springs up front to get it a couple of inches higher.
Thanks for all the help fellas. |
03-09-2008, 03:41 PM | #16 |
Is there still an I.D. tag on the 2nd bolt up from center on the D44?It may be broken off or too rusty.But,my crapped-out eyes think they see something.
03-09-2008, 07:53 PM | #17 |
Back in the day you had to add additive the rear to stop the noise, now you just use synthetic and lockers are just noisy.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
03-10-2008, 11:34 AM | #18 |
Only 3 gears came in that Eaton rear so if its original its ether 4:10s or 4:57. Most likely it’s the 4:57; 4:10s were not very common. They also cam in a 5:13 but you don’t see them very often. I love Eaton rears I keep a few of them in storage just incase a new project shows up.
Earl 68 2500 4x4 GMC Burb Last edited by earl87gta; 03-10-2008 at 11:34 AM. |
03-11-2008, 06:30 PM | #19 |
Me too,I have a spare 4.10 w/locker.It`s going in my shortbed project instead of the 14-bolt that came with the 1t set I bought.
