Old 10-24-2002, 10:47 PM   #1
chevjayfsd
Project 7dos
chevjayfsd's Avatar
Vortec Head Question???!!!!
Can anyone tell me what the biggest cam you can run in the vortec heads. I have a 350 w/vortec heads and my cam recently went flat and i am replacing it...Can someone do some research(I wouldn't know the 1st place to start looking). I have a .454 lift in it right now and i have heard you can go bigger...
Jason
7DOS - 1972 C-10
350/350
Porterbuilt/Accuair
20x8.5/20x10
Ride Low or Die
PSSST - Yes it's bagged.
7dos build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=610290
chevjayfsd is offline   Reply With Quote
Old 10-24-2002, 10:55 PM   #2
Hooter
My other Love
Hooter's Avatar
why do cams go flat? do the lifters hang up?
MEMBER DISCS UP FRONT CLUB
  • 69 custom camper/cst 10
  • 70 monte carlo 383 stroker with a 700r4
  • 77 fully loaded silverado (back in the backyard for a little while longer)
  • 1980 BMW 320i (back in the garage finally)
  • 1981 f@*d f150 4x4 (Robert red ford) tried to kill me
  • 1972 Honda ct 90 trailbike
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com AC/DC RULES!!!
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
Old 10-24-2002, 11:21 PM   #3
truckster
truckster's Avatar
The factory specs for the vortec say .5 inch lift max with the stock springs.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 10-24-2002, 11:23 PM   #4
bigjimzlll
bigjimzlll's Avatar
this gets a little quirky...most publications say dont go over .460 lift...then ever one says the 350 ramjet has .480 lift with vortecs. Then I read never go over .450 ever(with out the spring upgrade). My suggestion...go with the spring upgrade to be safe.
Jim
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 10-24-2002, 11:24 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Having never read any GM papers on them, I am going by what all the magazines say...
.480 due to the lighter spring pressure.
Old 10-24-2002, 11:25 PM   #6
crazy longhorn
Fabricate till you "puke"
I dont believe you can run that much lift with stock springs on the vortecs.......I think it was in the .460-.470 range.
crazy longhorn is offline   Reply With Quote
Old 10-25-2002, 12:08 AM   #7
crazy longhorn
Scoggin-dickey has som info, If i can get the page up.... it sounds like to about .450 lift. http://www.sdpc2000.com/cart.asp?act...art&catid=2172
Old 10-25-2002, 03:45 AM   #8
Project1970
14.1 @ 96MPH
Project1970's Avatar
I'd say whatever cam they spec in the RamJet is probably as big as you can get. The 350HO 330hp engine uses one in the low .450's...
FWIW, messing around with Desktop Dyno, the Comp Cams XE256H seemed to work really well. WIIIIDE torque curve, and lots of it.
Project1970 - LS1 Swap Complete!
Project1970 is offline   Reply With Quote
Old 10-25-2002, 07:42 AM   #9
Blazer1970
Blazer1970's Avatar
It's easy enough to check for coil bind when you assemble the engine. I have heard it is close to .500.
Blazer1970 is offline   Reply With Quote
Old 10-25-2002, 08:50 AM   #10
Fred T
Cantankerous Geezer
Fred T's Avatar
Cams can go flat from a lack of lube, improper break-in (run at 2,000 rpm for 20 minutes immediately), dirty oil or the big one, lifters adjusted to tight or springs that are to stiff. Throw in failure of other parts, such as a stuck valve and it's a wonder they don't go flat more often.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 10-25-2002, 10:23 AM   #11
chevyracing
Location: Go to the middle of no-where then go another 25 miles East.
If you run more than a 465 lift you need to have the heads machined for clearance on the valve guides. It runs about 25 bucks a head to do this to. Scogin sells a set of heads that already have the machining done for an aditional charge, I am not sure but I think they run about 30 bucks more than the standard ones.
John
Life begins at 100 miles per hour, then just keeps getting better and better the more you mash the gas.....
chevyracing is offline   Reply With Quote
Old 10-25-2002, 11:03 AM   #12
SCOTI
SCOTI's Avatar
I believe the RamJet cam spec's are .431/.451. You prob could run up to .470 lift max but the real question would be how long will the stock springs last w/more lift than the factory intended. The LT4 valvespring upgrade is good insurance & they have passed GM's 300 hr. full throttle test so they should last 100k in your motor.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
