03-23-2002, 07:09 PM | #1 |
Outlet fittings for 3/4 ton Master cyl...
Are they the same size as those of the 1/2 ton master cyl? I'm thinking about getting rid of this leaky 1/2 ton master w/ the single hold-down clip for a 3/4 ton master (2 hold-downs) seeing as how I already have a 3/4 ton booster. And I don't want to have to re-fabricate the lines going to the prop. valve. Going to buy NEW this time and it will be closely inspected. Any nicks in the top rim and its going down the guy's gullet.
------------------ Southpa 1970 GMC 1500 Custom Victoria, BC, Canada [This message has been edited by Southpa (edited March 23, 2002).]
1970 GMC 1500 Custom Original 350/TH350 Victoria, BC, Canada You can wish in one hand and crap in the other. See which one gets filled first. |
03-23-2002, 07:53 PM | #2 |
Jostrans68
no they are not they are backwards
------------------ 68 c20 in progress 327 TH400 tach dash Disc Brakes and soon 3.90 rear gears.. have many new parts now just need the time..... Sound Familar
[CGTW Member former 67-72 now with a 96 silverado |
03-23-2002, 07:59 PM | #3 |
you can make your own lines form short pieces of lines from auto parts stores, the lines are inexpensive, just out the correct ends that you need on the lines, theya re 3/16" and 1/4"
03-23-2002, 09:31 PM | #4 |
They are reversed, but you can buy adapters at auto parts stores. I ordered new lines for my 3/4 ton when I did the disc swap and they sent 1/2 ton lines. I just bought the adapters and bolted it all up.
------------------ 70 GMC 3/4 ton Sierra Grande 402/TH400 72 Jimmy 4WD 4spd 4" & 35's 64 Corvette Coupe 68 Camaro 'vert TPI & TH700 69 Z/28 355 12.6's @110 72 Datsun 240Z-ol' reliable
