Old 03-04-2008, 06:01 AM   #1
vegas_k10
Cool Changing wheel studs on 4x4 77 k10
hey guys i think someone loosened my lugnuts................. when i pulled in the driveway the other nite i heard a clicking sound so i looked when i parked and saw there were 2 lugnuts laying in the street and NONE on my driver side front wheel. so all the studs are ruined. How do i get the hub apart and get the rotor out so i can get new studs put in? any help would be appreciated
vegas_k10 is offline   Reply With Quote
Old 03-04-2008, 08:37 AM   #2
72lb4x4
Re: Changing wheel studs on 4x4 77 k10
Sounds like someone wanted your wheels and tires...
I'm certainly not promoting autozone, but if you go to their web site, you can find repair procedures that are not so bad...
Remove tire (apparently its about to remove itself)
Remove the caliper and hang it up so there's no weight on the line.
Remove the locking hub. Mine's a 72 and just has 6 allen head bolts holding it on...
Remove the spindle nuts. On my D44 there's a socket for this at O'reilly's. They have a few different ones for different applications.
Now you can get the rotor off and beat out the studs. I think they are in the rotor, not the spindle.
Plan on packing the wheel bearings, replacing the pads, etc.
Check before to see if the ball joints are bad.
That's what I recall from replacing ball joints at least...
72lb4x4 is offline   Reply With Quote
Old 03-04-2008, 10:09 AM   #3
OldCreek
OldCreek's Avatar
Probably time to buy some wheel lock lug nuts.... they may return for your wheels.
It may be time to lie awake at night waiting for them to return. Or, run a video camera at night to hopefully catch them!
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold
1972 C10 5.3L/4L60E 12bolt 5Lug - Sold
1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!!
1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold
1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold
1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold)
2003 K2500HD 8.1/Allison1000/NP263
OldCreek is offline   Reply With Quote
Old 03-04-2008, 10:22 AM   #4
ohsocountry86
ohsocountry86's Avatar
hunny i need a beer my shotgun shells and a rocking chair i will be on the front porch
I can die happy now i own a c-10
TRICKNRACY cars baby
TRICKNRACYCARS.ORG
ohsocountry86 is offline   Reply With Quote
Old 03-07-2008, 10:28 AM   #5
vegas_k10
well i havent had a chance to work on it, ive been busy. I did a little, got the allen heads out and took the lock out, and also i removed the c clip inside the hub. What else? anyone done this before? thanks
i dont want to mess it up its my way to work lol, any help is appreciated
Old 03-12-2008, 09:59 PM   #6
msgross
msgross's Avatar
right now it's not driveable though... You have to get a spindle socket from autozone rental (or buy one), pull the spindle & caliper. You might have to seperate the rotor from the inner spindle to get the studs out. I bought some at NAPA for the rear. Easier to press them in and out but oyu can hammer them out, and use a lug nut to pull them tight before reinstallation. Either way you need to get instructions for pulling the spindle because it's important to tighten the spindle nuts properly....
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 03-13-2008, 07:12 AM   #7
vegas_k10
what do you mean tighten the spindle nuts a certain way?? i wasnt aware of this damn im glad i didnt go do it today haha. I got it all apart sorry guys for the delay, i got it apart and new studs are in but it comes to my attention that theres a procedure to tighten the nuts?? can anyone shed some light in reinstallation?? thanks guys for all the help!
Old 03-13-2008, 07:57 AM   #8
msgross
msgross's Avatar
THe end of this article talks about it. The spindle stays on the knuckle but when you reinstall the hub to the spindle (with the two large nuts and locking ring) then you should tighten it down per the instructions... I might have used the incorrect terms earlier... The studs are in the hub...
http://www.pavementsucks.com/tech/dana44hub.php
The Garage:
