03-04-2008, 01:30 PM | #1 |
1970 c10 resto(2nd attempt)
ok so here goes again bought it for 1k lets see how much i get into it on this one.
1k truck 100 storage unit (x6) 75 cheep wheels(theft) 75 tow 150 plug wires, spark plugs, dizzy cap and rotor, freeze plugs, assorted odds and ends. 50 diehard battery 75 harmonic ballencer 400 heads 50 used carb 50 misc bolts, hosing and fittings 130 carb spacer and studs, radiator hoses and clamps 450 engine block, cam, crank, pistons, small starter, bearings 160 gaskets, motor mounts, flywheel, new water neck 50 rear main seal and hold down 50 h/v meling oil pump and pickup 190 aluminum oil pan, alum timing cover, milled wire looms felpro 1 pce gasket 100 holley blue fuel pump and regulator 290 misc tools, sealant plastigauge, grease, cleaner, primer, paint 750 new tires and rims 175 new brake booster 75 oils anitifreese, and hoses 75 engine tuning 75 wiring, windshield wiper blades $5225 to date story with this one is the guy had a voteck class that he was teaching and this was the vehicle they where working on. the owner had got into a bad motorcycle accident and went mental(literally) he took a hammer to the entire truck, hence the dents everywhere. stuff on the agenda 1. install new freeze plugs(done) 2. head gaskets, intake gasket(ended up changing the heads in the proces, done) 3. battery plugs wires dizzy cap header bolts(done) 4. possible leak in radiator, to be repaired, or replaced 5. remove all jerry rigged items and or all duck tape 6. rework wiring (in progress) 7. get carb and install (done) 8. change out the steering column and shifting linkage(parts courtesy of 'jeffspower',done) 9. new headlamp assemballys 10. ac hosing and compressor 11. u joint needs replaced(done) 12. install vacuum lines to break booster, and transmission(done) 13. fix the emergency brake system(in progress) 14. change harmonic ballencer(done) 15. comeplete engine over haul(done 16. pull trans, install shift kit and higher stall torque converter(done) 17. plumb fuel pump(done) 18. Install a oil pressure cutoff to the fuel pump more to come more to come
69 chevy c10 350 3 speed manual wood bed build thread here r.i.p. 70 c10 auto 350 build here Last edited by berencam; 10-08-2010 at 10:32 PM. |
03-04-2008, 08:15 PM | #2 |
Skinned knuckles
Re: 1970 c10 resto(2nd attempt)
Wow, that looks like a little bit of a challenge. Nothing you can't handle though! That's a good start for a project. I like the shifter pin especially!
'72 C-10 longbox soon to be short step! '72 Chevelle (sold in January) '07 Sebring '01 Ranger (I've gotta long commute..) If you try to fail, and succeed, which have you done? My build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=276904 |
03-09-2008, 04:22 AM | #3 |
well got into the engine and found a issue, actually a few. for starters they didnt use head gaskets, next i got the numbers ran on the block and heads, and the heads are 305's but the block is 350. And when i was removing the pushrods i found that one was bent. So i got everything ready to pull the heads and hopefully there isnt internal damage.
03-09-2008, 05:41 AM | #4 |
Tot Roddin'
Looks like a great project... I hope this one turns out better than the last.
Keep safe out there on the road!
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
03-09-2008, 05:48 AM | #5 |
Well, Whoop-dee-do!
They didn't use head gaskets... as in there is none?
Did you get the column yet?
'68 GMC shortbox 4x4 350/SM465/T221- bought it in '83 SOLD '72 K20 500 Cad/TH400/NP205 SOLD '92 Chevy 2500 6.5 mech TD 4L80E crusty daily driver '72 Monte Carlo... sweet low mile toy '11 Dodge Challenger IE 392 6spd... midlife car |
03-09-2008, 06:03 AM | #6 |
not yet but i havent been home since 10am so hopefully there there cant wait to get this one on the road. thanks again for the column
03-09-2008, 09:14 AM | #7 |
72 Chevelle Club
Looks like a good solid truck !! It will be nice when you're done !!!
I Have The Right To Remain Silent,But Lack The Ability 1972 Chevelle ... Mine 2006 Trailblazer... Hers 2002 Buick century ... Kids 2002 K1500 Z-71 EXT CAB ... Daily Driver 2005 Rockwood Roo ... For Camping 1974 Harley-Davidson XLH Sportster 84'' stroker |
03-09-2008, 09:57 AM | #8 |
hey jeff got the steering column in tonight, whoot. they broke the gear indicator tho so thats a bummer but alot better than the one i have hehe. thanks again, and yes as in there is none lol, i dont understand why you would do all that work and get down to the heads and not put them on.
03-09-2008, 11:04 AM | #9 |
Eat My Rust
Good to see ya back!
What other ghetto-rigged tricks are there in this truck? |
03-09-2008, 11:26 AM | #10 |
lets see, no head gaskets for one, tranny linkage held on by zip ties, all kinds of miss matched bolts, they used foam insulation to fix a cab corner the list goes on
03-09-2008, 09:47 PM | #11 |
Well, Whoop-dee-do!
Dammit. I thought Fedx would be the better choice over Uncaring Package Shippers. That and it didn't have to ship far. I would liked to of found a bigger box- but finding one it would fit in at all without being the size of a refrigerator box was tough.
03-09-2008, 11:51 PM | #13 |
doesnt look too bad though....
-wes |
03-10-2008, 04:53 AM | #14 |
laying low
Berencam. Is this the truck you bought to replace the wrecked one? Or is this a 3rd one?
And Lord help us if that votech class was the ones who did all the "repairs" to this truck. Engine, tranny linkage and all? No head gaskets and it actually ran and held coolant? It's nothing you can't handle. Just a little more work than you might have counted on. If you have some decent 350 heads now would be a good time to put them on as the small chambered 305 heads might make it ping a bit. I put some on a 327 years ago and it was just too much compression and I had to keep the timing retarded to keep it from pinging and it made it real sluggish. Just a bit of info for your consideration.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
03-10-2008, 05:01 AM | #15 |
yes boog this is the one i bought then the guy went back on his word, well i held him to his end of the bargain and he decided to take a final 500 and it was mine. So i ended up paying 1k for it. Its not to bad of shape but im afraid the engines going to be to gone to repair in the truck.(guess that means ill be buying a engine hoist its my birthday in a few days anyway hehe) But ill find out what kinda real damage there is to the engine when i take the heads off tonight.
On the 350 heads mater, i dont have a set, and not enough cash to get one right now. but my plan is to get it running and out of the storage unit then do a head swap later(when im not paying 100 a month for the unit) |
03-10-2008, 05:31 AM | #16 |
laying low
Ah. So did you actually hear it run? Still plenty good deal for the money.
03-10-2008, 06:17 AM | #17 |
yea it ran albeit poorly, it was idling decent. kinda amazing it even ran at all now that im getting into it
03-10-2008, 11:08 PM | #18 |
got the heads pulled off last night and i didnt see any cracks in the heads or block. Also since there was a bent pushrod i was worried of bent valves, pitted pistons, but they are fine too. The head block surface is very dirty and has paint over spray and debris all over. So it looks like the engine is going to be ok. going to clean the surfaces and reinstall.
03-11-2008, 06:05 AM | #19 |
laying low
It's too clean down in there for it to have run very much B. How did the plugs look? If the pistons aren't a floppin around in the cylinders and no bent valves a new gasket set and it might run out alright. There's hope for it.
03-11-2008, 06:44 AM | #20 |
plug had carbon buildup but other than that nothing wrong with them.
03-11-2008, 06:48 AM | #21 |
1972 Chevrolet SWB
Make sure the intake bolt in the area of the bent push rod is the correct length,wouldnt be the first time I have seen a little longer than correct length bolt used which presses against and bends the pushrod.
My New thread with pics (not my build thread yet.) http://67-72chevytrucks.com/vboard/s...46#post2573646 1972 Chevrolet 1/2 ton short wide bed,68 frt clip Project. 1980 Camaro Inherited when father passed,68K Miles 2003 Ford Mach1 FUN as Hell!! 2002 Dodge Ram 5-8 slam Rolling BillBoard (Gone not forgot) 2004 Dodge Ram HEMI 10" lifted on 37's and 2wd. |
03-12-2008, 11:41 AM | #22 |
Bolts all seem fine. I got to the truck today and did some work on it. Pulled the radiator and all pulleys. Then pulled the harmonic balancer and installed a new one. I decided to go ahead and buy new heads so i wont have problems down the road with the high compression. They should be in tomorrow. The are re-maned 350 76 cc heads. It was my 21st birthday today so i didn't get too much done on the truck. but hopefully i should get the pulleys, belts, column(needs painting also) all installed tomorrow, mabee get the heads on if i have enough time and they show up soon enough. Will post pics tomorrow.
on a side note, is there any reliable way to check a radiator for leaks other than just hooking the hoses up and crossing your fingers? |
03-12-2008, 11:55 AM | #23 |
1972 Chevrolet SWB
A pressure tester works great but if the radiator is out of the truck,you would have to make caps for all the inlets/outlets.
Just make sure you watch the lengths of your intake bolts when you go back in,I have seen way too many guys use a longer than needed bolt and in a certain hole they will make contact with a pushrod and cause a bent one.Just check.
03-13-2008, 12:25 PM | #24 |
Well got a ton done today, i got my new heads on and torqued, got the steering column painted and installed, changed the thermostat, and temp sensor, gaped all plugs, installed all studs in intake for the carb, installed the carb, installed the vacuum elbow in the intake and a whole lot more. If things go good i might get to turn the key in a couple days. Heres lots of pics with todays progress.
What is the procedure for installing rocker arms, adjustment before startup and after. Also if anyone has a auto linkage picture id appreciate it if you posted it. Mine was in pieces from the p/o and i have no clue how to put it back together. Last question, is it advisable to sand a coat headers. The ones i have have severe surface rust and im afraid if i dont do anything about it it will eat a hole right in them. |
