Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 03-04-2008, 08:07 PM   #1
fun in dirt
fun in dirt's Avatar
amp wiring ?
Does the "amp rem" wire out the back of the head unit go to the "p conn" on my amp? If not what are each of those for? I want to be sure before smoking something up! THANKS
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432
'85 K30 "Big Nassy"
'06 3500 Duramax ...tow truck
'06 Silverado SS...DD
'06 C1500 WT...DD
'07 Classic C1500 WT...DD
Built & sold cause can't keep 'em all:
'72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190
'55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938
'69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541
'86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619
fun in dirt is offline   Reply With Quote
Old 03-04-2008, 09:45 PM   #2
454HO
Re: amp wiring ?
'amp rem' is the wire coming out of the head unit that turns on the amplifier. Not sure what 'p conn' is. What is the brand and model number of your amplifier?
- Greg
454HO is offline   Reply With Quote
Old 03-04-2008, 10:48 PM   #3
Classic69
Love That '69
Classic69's Avatar
Re: amp wiring ?
Like 454HO said, the 'amp rem' wire coming from the head unit is the wire that turns on the amplifier when you turn your deck on. On your amp there should be 3 connections beside each other. Ground (GND), Power (B+), and your Remote (REM).
I AM CANADIAN!!!!!
1969 Chevy C/10 Truck - SBC V8, TH-350, 3.73 Posi, 1000W Rockford Fosgate Stereo System, B&M Megashifter, GT Grant Steering Wheel, Dual Magnaflow Exhaust System, Dynomax Headers, Lowered 1" Front & 3" Rear, Front/Rear Sway Bars, Racing Seats, 6000K HID Headlights
2008 Chevy Colorado LT - 3.7L I5, 4 Speed Automatic, Crew Cab, 4X4, Z71 Off-Road Package, "Ground Effects" Package, K&N Cold Air Intake, Supermod PTB, Magnaflow Exhaust w/ Resonator, 500W Kenwood / Rockford Fosgate Stereo System, Custom LED Lighting, 6000K HID Low's / High's, Blackcat Customs Gauges / Needles, Carbon Fiber Interior Accents, KrFabs 2" Lift Shackles / Torsion Bar Crank with Rancho RS5000 Shocks, Superskids Skid Plates
Classic69 is offline   Reply With Quote
