03-05-2008, 04:54 AM | #1 |
A guy with a truck
My weekend project
I'll let the pics do most of the talking. This was as easy as pie- maybe easier- I don't even know how to make pie Everything was a bolt-on. The only pain in the neck part were the (&@$#()@& RIVETS!!!
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy Last edited by gringoloco; 03-05-2008 at 05:04 AM. |
03-05-2008, 05:24 AM | #2 |
Re: My weekend project
Nice job, wish i could get that much done in a weekend, is that a reqular blazer tank
1997 pontiac grand prix gt (daily driver) for now; 2004 dodge ram quad cab (wife's truck) 4.7; 2000 pontiac booneville (wife daily driver) 1972 chevy cheyenne 350 bored 40 over 700r trans 373 gears ( posi) soon to be daily driver; 2002 gsxr750 sold |
03-05-2008, 05:32 AM | #3 |
A guy with a truck
Thanks! Yep. Poly Blazer replacement tank. Bolts right in like it was meant to be...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
03-05-2008, 05:36 AM | #4 |
senior member
quick question about your notch, first off where did you get it CPP seems to be the cheapest ive found yet, and secondly seeing as you had a chance to look at this would it still be structurally sound if the part where the airbag bolts go thru was cut off?
69 GMC bagged |
03-05-2008, 06:40 AM | #5 |
67-72 parts collector,…
I see alot of nice parts there. How hard was it to locate the trailing arm crossmember? Did you us a stock one or the ECE version? Is this one getting the dropmember also? Again,... nice work.
03-05-2008, 07:49 AM | #6 |
You love those trailing arm conversions
03-05-2008, 08:04 AM | #7 |
blood type; Retumbo
the trailing arm forward mounts will bolt right up to the center X member. no holes to drill or anything.
03-05-2008, 08:13 AM | #8 | ||
A guy with a truck
As for cutting it off: The frame is already triple thick there before bolting in the notch, so you end up drilling through a inch of metal. I still would not chance it without welding/boxing it in. In that case, I would just build a custom notch out of pipe/plate. Quote:
The leaf spring trucks already have the trailing arm crossmember in place, just no trailing arm brackets on it. I just pulled the old one and replaced it since a previous owner somewhere along the way took a cutting torch to the one on the truck. It's a stock piece I modified by cutting 4.5" holes in for exhaust routing. Just bolted it in place with grade 8 hardware. There is some info in a few of my 4wd to 2wd Blazer conversion posts about locating the trailing arm crossmember in a chassis not originally equipped with t-arms. No Dropmember for this one- yet... I do! Can you believe this is what I do for fun?
03-05-2008, 08:16 AM | #9 |
A guy with a truck
Yepper. That would be a whole hell of a lot easier than what I had to do to replace the whole crossmember. It did not want to leave its home!
03-05-2008, 09:39 AM | #10 |
I am getting ready to do the same thing, except my truck is a coil spring truck so I have a few questions. How did you mount the air bags? did you have to fab some brackets or plates. Will the axle bottom out in the c-notch if you fully deflate the bags?
03-05-2008, 06:26 PM | #11 |
Tot Roddin'
Man oh man... and I thought I got something accomplished this weekend. Looking good gringoloco! Is the front for next weekend?
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
03-05-2008, 06:27 PM | #12 | |
A guy with a truck
The axle will bottom out in the notch. I am using button style 3/8" tall bumpstops so it won't clang if it hits.
03-05-2008, 06:31 PM | #13 | |
A guy with a truck
First thing I need to do is get the bed back on so I can route my exhaust. I plan on raising the floor 3", so it's not just a bolt-on deal...
03-05-2008, 06:40 PM | #14 |
Damn man, over a weekend, You make the rest of us look bad. Did you have to weld on your axle to change over to the trailing arm perches? I have leaf springs and this is my next mod.
Mike 68 C10 LWB midnight blue metallic 307ci, 700R4, HEI front discs, leaf spring rear tilt steering wheel, stock ride height, rally wheels, 2007 Dodge Charger(Hemi) |
03-05-2008, 08:02 PM | #15 |
Thanks for the answers. Looks great so far. What kind of bags are you running. What about shocks?
03-06-2008, 03:46 AM | #16 | |
A guy with a truck
I did not weld this one, I just swapped axles from a '73-up truck into a '70 housing- direct swap. I did, however, weld new perches on the rear I used in my Blazer conversion using the ECE pieces. They are very nice and worked perfectly. They are Slam Specialties RE200 7" diameter. The shocks are some drop shocks I had laying around- I will swap to Monroe-Matics as soon as I get a good part# for the needed length.
03-06-2008, 08:48 AM | #17 |
A guy with a truck
Here's phase 1 of what I'm doing to provide a little room for the exhaust. Pay no attention to my bed floor- it's not all rust, some of it is dirt- except for the holes, they're dirty rust...
03-06-2008, 12:51 PM | #18 |
LAIDOUT
Nice job Gringoloco, but I agree you are making the rest of us look bad! I wish I had raised my bed floor before I sprayed in the bed liner, oh well I will on the next one.
03-06-2008, 02:03 PM | #19 |
Restoring a 68 SWB
Do you think trailing arms are better than the leafs? I am looking at picking up a swb truck that has leafs, and I definitely want to lower it and notch the frame. I won't use it for hauling anything other than a small trailer occasionally. I would rather have a better ride. With that said should I ditch the leafs?
Nice looking job btw. I just wish I had something to tinker on right now. |
03-06-2008, 06:44 PM | #20 |
wish I could get that much done in a weekend.....maybe when I get home I can knock some good projects out
03-07-2008, 05:26 AM | #21 | ||
A guy with a truck
03-07-2008, 05:32 AM | #22 |
A guy with a truck
I created another mount at the middle support that normally rests on the framerails. I didn't feel like there was enough support there with just the wheeltubs to keep it from bowing. I just drilled a 3/8" hole through the flloor, support, and frame and notched the floor for the square head on the carriage bolt with my jigsaw.
To the untrained eye, it will appear factory- which is kinda what I'm going for with this floor raising. Hopefully, at first glance, even those 'in the know' won't spot it...
03-07-2008, 07:47 AM | #23 | |
03-07-2008, 07:56 AM | #24 |
A guy with a truck
What did you do on the bedsides? I've got a plan, just curious to see what you did before I execute...
03-07-2008, 08:11 AM | #25 | |
1 'short' bolt @ the F/R of each side holds the 'frame' to the floor & is bolted to the floor only. The remaining holes get bolts long enough to go through the SQ-tubing 'frame' + the bedsides. I call it my plan because I haven't bolted the bedsides on yet.... I was waiting on a new front bed-panel from Mar-K (which I now have) & I didn't want my primered parts out in the weather any longer than absolutely necessary. What did you have in mind? What about your filler neck for your blazer tank?
