03-06-2008, 08:32 PM | #1 |
Questionable
Easy way to remove tires from wheels?
You know, I have these four rims I need to refurb, and they have tires on em.
Any suggestions on how to easily remove a tire from a wheel in less than 2-3 minutes? I tried using two tire irons to break the bead and wedge over the rim like I'd done in the past, but they were cheap tires and came off easy. The tires are going off to recycle, so I don't care if I gotta cut em off. I gave up after 15 minutes of putzing around and figured I'd come here and ask before proceeding.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
03-06-2008, 08:35 PM | #2 |
No Matter What.
Re: Easy way to remove tires from wheels?
If the air is out get a razor and cut both sidewalls and beads. That should give the tire enough flex to get it off the rim.
Currently own: 89 Chevy Silverado Previously Owned:Starting with my first vehicle 86 Mercury Cougar /89 Olds 88 /88 Chevy S-10 /84 Pontiac Firebird(I miss it) /91 Chevy S-10 Last edited by get me on the road; 03-06-2008 at 08:35 PM. |
03-06-2008, 08:41 PM | #3 |
Questionable
That's part of the problem - the bead is steel belted, and so is the sidewall. It was tough enough that I'd have needed a grinder to cut through it, and I'm not going to make that kinda mess in my yard
03-06-2008, 09:16 PM | #4 |
member
I have the same problem. I have maybe 12 tires that i would like to strip from the rims.
1967 C/K10 Chevy Panel 1968 C/K20 Chevy Pickup 1968 C/K10 Chevy Suburban 1941 Chevy Sedan Delivery 1960 Chevy Sedan Delivery 1972 Camaro SS 396 #s matching 1971 Harley FX Superglide |
03-06-2008, 09:20 PM | #5 |
Skinned knuckles
I've used my skill saw to cut the sidewall around the bead before and then a hammer and chisel or prybar to break the bead, but still not fun. Once the bead is left, you could cut through it with a grinding wheel..
Still messy and smokey!
'72 C-10 longbox soon to be short step! '72 Chevelle (sold in January) '07 Sebring '01 Ranger (I've gotta long commute..) If you try to fail, and succeed, which have you done? My build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=276904 |
03-06-2008, 09:27 PM | #6 |
yeller
Tire shops don't charge much at all for dismount...why not just bring them there? Shouldn't cost more than $10 for all four.
Sounds like the easiest approach to me.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
03-06-2008, 09:33 PM | #7 |
i'm with bigblock ... going rate around here is $5 a tire to dismount
03-06-2008, 09:44 PM | #8 |
Questionable
I thought about that. I just hoped there was some way I could do it myself. Trying to stuff four big ass wheels and tires in the back of my VW is a bear.
03-06-2008, 09:49 PM | #9 |
Junior Member
Sawsall!
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
03-06-2008, 09:56 PM | #10 |
sawzall, or maybe see if you can find a mobile tire truck person, usually the people who do the semis have a machine on the truck
03-06-2008, 10:04 PM | #11 |
Skinned knuckles
A sawsall doesn't work. It just vibrates the sidewall back and forth. That's why I had to switch to my trusty skill saw. Just harder to corner with it..
03-06-2008, 10:32 PM | #12 |
I have used a Metabo angle grinder with cut off wheel and it worked great.
Phuloi68 Indy survivor Norwood survivor Big Sandy survivor for those who fight for it...
F R E E D O M has a price the protected will never know. |
03-06-2008, 10:35 PM | #13 |
shifty
here was my solution http://www.harborfreight.com/cpi/cta...emnumber=34542 Once secured it does really well, especially for the price. But if you don't see your self doing it much, I'd go have someone dismount them for you.
03-06-2008, 10:43 PM | #14 |
Son of a gun
Shifty, If you were local I'd be happy to do them on my tire machine, but your not! Cheap or expensive, your tires should come off with tire irons. Are you standing on it to make sure that the bead is down in the drop center? If not, the bead will not come over the rim. Stand on one side of the tire to smash it down, and pry the opposite side up with your iron. Then go over a couple of inches and get a bite with your second iron. I've cut tires off of rims before and it is TONS more work than breaking them down.
Bill BEATERS ARE NEATER |
03-06-2008, 10:59 PM | #15 |
Questionable
Thanks, Bill, I'll give that a shot. Here's the catch - I jumped all 180lbs of my ass up and down on that joker and it just would NOT come off the bead. Maybe that's where I went wrong. It's been so long since I tried that I just couldn't remember how I did it the last time.
03-06-2008, 11:04 PM | #16 | |
Son of a gun
Put the tire under your heaviest truck's bumper, and put a jack between the bumper and the side wall. Jack away until you have lots of pressure on the side wall. If it doesn't break loose, get a BFH and hit the side wall close to the jack until it comes loose. I do have a couple more tricks up my sleeve for breaking beads, I'll post if you will need em. they do make a duck billed hammer that is super dandy at breaking beads, but you probably won't want to buy on for a couple of tires.
Bill BEATERS ARE NEATER Last edited by Bus Ted Knuckle; 03-06-2008 at 11:04 PM. |
03-06-2008, 11:05 PM | #17 |
Questionable
Will give it a shot when I get home today. Wife is out of town, so I got all night to get dirty and putz with some tires
03-06-2008, 11:08 PM | #18 |
~Rest In Peace~
dont use a shot gun
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
03-06-2008, 11:20 PM | #19 |
Questionable
Great, ruin my fun, why doncha?
03-07-2008, 12:54 AM | #20 |
Java Mechanic
I had a buddy who used to get tires off using the bucket of a little Kabota tractor.
Keith 11 Lincoln MKT -- Momma's wagon 13 G37xS -- middle age crazy car 68 C20 Fleetside -- RIP Decorating the whole town up at a cost of $27 .... |
03-07-2008, 01:13 AM | #21 |
Son of a gun
I'll break the tough ones down with the 3 point on my farmall
03-07-2008, 01:14 AM | #22 | |
Questionable
Oh damn, I totally forgot, I have one of those under my bed. I'll have my dog pull it out after work.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. Last edited by shifty; 03-07-2008 at 01:14 AM. |
03-07-2008, 01:33 AM | #23 |
Iv Jacked My Truck Up And Put The Tire Under My Brake Drum, Set The Truck Down On It And Hit It With A Hammer. Just Make Sure You Jerk The Valve Stem Out
03-07-2008, 01:34 AM | #24 |
As stated the easiest way is to use a tire machine. You will save yourself a lot of headache just taking them to a tire store.its a fight to get them off by hand especially on tires that dont have a lot of sidewall. either cut the tire or just take two trips to the tire store. its worth the drive
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
03-07-2008, 01:35 AM | #25 |
Questionable
Oh, I try to jerk my valve stem regularly.
Seriously though, I cut the valve stem out already. That was initiative #1. The crappy part about this is, if the tires were on the truck and it was rolling, I could de-bead them in a heartbeat on a backroad Alas!
