creator of kong
took forever, but it is getting closer
creator of kong
and another
creator of kong
and another.........
creator of kong
last but not least
Shortbox wanna-be.
That's sweet as hell!!
1970 Chevy C20 Custom Camper 402BB Turbo 400 trans. (Slowly becoming a '70 shortbox 1/2 ton) '71 Camaro SS 402/T400 resto '97 Z28 (11.41@127MPH) ![]() |
SLOW BUT SURE,BUT CLOSER
SWEET, looks great!!!!!!!!!
69 C-10, OWNED 35YRS... 350 over 30, 350 Turbo, 3:73 Posi P/S, P/B Black with red and black int. ''LOVE THESE OLD ''TRUCKS....... ![]() ![]() ![]() |
Project 7dos
Looking Good
What Are the Specs of your rear end and the tire size etc. How much of your rear did you cut
Thanks Jason
7DOS - 1972 C-10 350/350 Porterbuilt/Accuair 20x8.5/20x10 Ride Low or Die PSSST - Yes it's bagged. 7dos build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=610290 |
I love the color, very nice looking. How did you make those wheel tubs? Their super cool.
'91 suburban 350 TBI - R 700 4 new daily driver '72 Cheyenne Super 49,000miles 350/350 frame up resto w/ matching numbers. |
creator of kong
Thanks guys..........ummmmm....the rear is a 9 inch Ford, which I had cut down 54 or 56 inches. I can't remember which, right off.it is about 10 inches shorter than the 12 bolt that was factory in this truck......the tires are Hoosier Pro Street radials......29x15.5-15 with a 15x12 inch wheel with a 4.5 inch backspace.......it would hold a 15x14 inch wheel with a 3.5 inch backspace fine, I think..........which I might do at a later date
Saving 1 truck at a time!
Beeauuuuteeeeefuuuulllllll! That truck is awesome! Can't wait to see more. That paint was worth the wait! Did you paint the cab and front clip separate from the bed? On different days? How does the paint match up? Looks great!
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) |
creator of kong
The bed has been painted for, I know 4 or 5 months.......and the paint on the bed matches exactly the same as the cab, from what I can tell..........I was curious about that too, but the guy at the shop told me not to worry about it, because it would match........so far so good, I guess
creator of kong
Do you all think I need to space the back wheels out to the edge of the bed more? I can't make my mind up, whether or not they are in under the bed too far.....................hmmmmmmmmmmmm
#13 |
nuttin a wider tire wouldnt cure.....i think it looks just right the way that it is....thats just how I want mine to look
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications click the clicky to join the site.... http://67-72chevytrucks.com/vboard/payments.php 67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44 Anderson,CA |
#14 |
LOOKS AWSOME......I LIKE THE MEATS IN THE BACK
1968 GMC FLEETSIDE |
#15 |
That's one tuff pickemup! Love it!
Later,
FGC |
#16 |
No, U Da Man!
Very nice Brad. Hope she hooks up for you.
(sold ole blue 1972) ![]() 1997 Dodge 1500 5.9L 1996 Saturn SL2 1.9L 2002 Mitsubishi Montero 3.0L 2005 Ford Escape 3.0L 1967 Olds Vista Cruiser 330-320HP |
#17 |
computer illiterate
speechless!
72 2wd blazer 72 swb 4x4 |
#18 |
Almost Satisfied
![]() Join Date: Mar 2002
flyin...what kind of gas tank set up did you use in your truck? Looks great!
I would go with the wider wheel and tire to fill up the wheel well a little more. Love the color.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
#19 |
Been thinking about the filler neck application as Flying has set up in his awesome red machine. My concern is when I go for my 4/6 drop that I will have problems with the top of the tire hitting the pipe/tube inside the wheel well. Any thoughts on that issue?
Larry |
#20 |
![]() Join Date: Jun 2002
flyin, truck looks great. In my opinion the wheel wells need to be filled in a little more. Were you planning on just going with 15x14's and using the same tire, or going with a 31x18.5x15 on 14" wide wheels. That combo would fill it up nicely!!! Of couse, it may actually be cheaper to narrow another housing and get another set of axles. The combo i mentioned above 18.5's on 14 w) would run in the neiborhood of $ 1000.00 Those hoosier pro street radials look awesome but they carry one heck of a price tag!! Which you already know that since you bought a pair. If you want to sell the 15x12's, i may be interested! Let me know.. Once again, the truck's looking great!! Later!
![]() click here to see my buildpage http://67-72chevytrucks.com/vboard/s...d.php?t=394656 ---------------------------------- 1979 C10 Silverado Big10 SWB Factory 454/400 Cardinal Red/Santa Fe Tan (original paint) 1969 Camaro X44 LS swap 1968 C10 SWB Fleetside (SOLD) 468BBC MultiPort TPI / Dynamic EFI P4 Black/Black 1963 Nova SS convertible (SOLD) 194 I6/ PowerGlide |
#21 |
creator of kong
Thanks everyone!!!!!!!!.......I am going to do some checking around....I might put a wider tire on my 12 inch wheels, or I might just put spacers behind these..........I dunno just yet.........I will keep you all informed
#22 |
That looks real good. Its a truck I think we all appreciate. Ya gotta love that fresh, shiney paint. Makes you wanna never take it outside.
Nick Rodenberg 72 Cheyenne 10 V8 350/TH350 white/ochre/white/ochre, ochre/saddle interior Retired and in the dry... still runs. I now drive Red '01 Ford Focus... better MPG!!! |
#23 |
Me Likey!
![]() I really do love the pro street look on these trucks! Yours looks absolutly marvelous! ![]()
Zurbo's Chevy - 1972 Black/White Cheyenne Super. 402 Big Block /THD 400, factory air and tilt. My other Chevy - 1998 Camaro SS |
#24 |
Thats the Hillbilly way
Looks AWESOME
BILL Torrance Calif 90504 Member DUF Club Member Old Farts Club 72 3/4ton Custom Camper BB402/400 trans Dynomax Cerama-coat headers , Hei distributor ,Edelbrock 1411 air,ps,pb,leafsprings ,98 chevy 60/40 seat,S10 shoulder belts tilt,3.54 Dana 60 rear. 16" Eagle wheels with LT265/75 16 tires,Gaylord Lid,H4 headlights with 100W relay conversion. " If I knew I was going to live this long I would have taken better care of myself " Marriage changes passion...suddenly you're in bed with a relative. A GUY'S PRAYER.... Lord, I pray for a nympho with huge boobs who owns a liquor store and likes to fish and hunt and has a Harley .Amen , |
