Old 10-26-2002, 10:37 PM   #1
OLDCHEV4X4
OLDCHEV4X4's Avatar
Edelbrock Big Block Intake
I just traded a rusty 71/72 Chevelle rear bumper for a Edelbrock Performer 2-0 intake manifold. Good deal, ..Yes. My question is what does the 2-0 denote? Do all BB performer intakes have this or do i have something special? Its going on the Suburban 402.
Randy
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 10-27-2002, 01:11 AM   #2
superchevy
Got big-block?
superchevy's Avatar
I think the 'O' is probably for oval port heads.
SC
'68 CST SWB factory 396/T400
buddy buckets, a/c, ps, pb
'72 Corvette convertible 454/4spd/ac, ps, pb
'73 GMC Sierra Grande short wide 454/T400 ps, pb, ac
'77 K5 Blazer black on red, 350/T350/NP205 ps, pb, ac all original
'78 GMC Sierra Classic short wide 454/T400 ps, pb, ac
'72 GMC Sprint SP454. 1 of 38 built.
'73 GMC Sprint SP454. 1 of 71 built.
'75 GMC Sprint SP454. 1 of 25 built.
SOLD! '72 GMC K25 4x4 468/4L80e/NP205
build thread
http://67-72chevytrucks.com/vboard/s...23#post4324423
SOLD!'55 Chevy gasser 496/4spd
build thread
http://67-72chevytrucks.com/vboard/s...96#post4324396
superchevy is offline   Reply With Quote
Old 10-27-2002, 01:51 AM   #3
Desert Rat
Desert Rat's Avatar
Performer 2 Oval Port,its the common Performer Intake youd get from any parts vendor new ones are $160 at Summit part # Edl-2161 ,When i have used ones they sell for $100 if they are real clean,and down.its the best intake for stock to mild mannered Big Blocks but remember if you use a Holley,Carter,Edelbrock Square bore carb you need the adapter gasket.they are a spreadbore intake good for idle to 5500 rpm,and you dont need anything above 5500 in a mild big block.id shy away from the RPM intakes unless you have a lumpy cam,good exhaust,good sized carb.I run that intake on all Big Blocks,unless it calls for more.
Desert Rat is offline   Reply With Quote
Old 10-27-2002, 09:25 PM   #4
OLDCHEV4X4
OLDCHEV4X4's Avatar
OK, so the 2= dual plane
O= oval port
It makes cents now. Thanks dudes.
Randy
72 k/5 Blazer
72 custom/10 8' bed
70 K/5 Blazer
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
