03-15-2008, 06:04 PM | #1 |
Retired Air Force Veteran
In-Line Frame Mount Transmission Cooler
I'm interested in installing an In-Line Frame Mount Transmission Cooler.. Is anyone using one? Is it working for you. What is the difference between the longer and shorter tranny coolers. Also, some coolers have an inlet/outlet on the same side and some have them on opposite sides. Any feedback? Thanks.
Harry 69' SWB Step Side 1/2 Ton w/68' Front Clip Swap from Leafs to Trailing Arms (Complete) Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front) 3/6 Drop Help Support The Board Click Here For Information On How To Subscribe Krue's FAQ Page Vendors |
03-15-2008, 06:19 PM | #2 |
Re: In-Line Frame Mount Transmission Cooler
You mean like this?
I don't have a tranny temp gauge, but I'm sure it's doing its job. This is mounted on the front crossmember. It's the shorter one with the lines going in on the same side.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
03-15-2008, 06:26 PM | #3 |
I run one on my Nova.... You can see it under the front bumper in this pic... It works well and trust me the tranny takes some abuse!
68 C10 Shorty TPI,Bagged, and all the good stuff. Classic trucks feature June 06, On the cover of Jegs Christmas Catalog 08 67 C10 Shorty Shop truck project Bagged and Z'd under destruction and getting nowhere fast. 64 C10 Shop Truck/Daily driver, Bagged, Dropmember, SOLD!!!! Gone but not forgotten.. 54 GMC under the knife getting a S10 chassis swap and bagged. See my build thread... 07 GMC Sierra 5/7 drop, 22's and 24's Air ride on my mind.. http://67-72chevytrucks.com/vboard/s...d.php?t=339340 See pics of my trucks in my profile |
03-15-2008, 06:30 PM | #4 |
Exactly what I wanted to here. Are both of you guys running steel braded lines?
03-15-2008, 06:31 PM | #5 | |
I'd rather not talk about what I used.....
03-15-2008, 06:32 PM | #6 |
Whatever it is, I'm sure it works
03-15-2008, 06:35 PM | #7 |
I seen an 18" cooler at a show this weekend for $45.00. I should have bought it.
Harry 69' SWB Step Side 1/2 Ton w/68' Front Clip Swap from Leafs to Trailing Arms (Complete) Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front) 3/6 Drop Help Support The Board Click Here For Information On How To Subscribe Krue's FAQ Page Vendors Last edited by myoldchevytruck; 03-15-2008 at 06:37 PM. |
03-15-2008, 07:09 PM | #8 |
they're good coolers/ the ones with both fittings on the same end are double pass meaning the fluid goes thro the length of the cooler twice as the ones with fittings on each end the fluid goes thru once
03-15-2008, 07:28 PM | #9 |
Thats how mine is set up... I hard lined mine..
03-15-2008, 07:48 PM | #10 |
Here's mine (24") mounted on the frame rail on passenger side. I used "push-on" style fittings to plumb it. Hasn't seen alot of road time yet, so I don't know how well it works.
Another nice thing about having inlet/outlet on same side is it's easier to plumb. Also.....I don't think one is better than the other in regards to cooling (dbl pass vs. single). When I looked inside mine it looked like one big chamber and even if there was a divider down the middle to get "dbl pass" you're still only using half the cooler on each pass.......just can't see it making much of a difference. It's all about surface area of the cooling fins. I would just get the longest one that will fit your application.
72 Cheyenne SWB Fleet Nut & bolt frame off in progress...99.9999% - supercharged 383 - 4 wheel discs - relocated fuel tank - My Build Thread Last edited by SactoJim; 03-15-2008 at 07:57 PM. |
03-15-2008, 08:10 PM | #11 |
Gettin By on Gettin By
Are you guys running those inline cooler only, or in addition to a raditor wil tranny cooling built in??
03-15-2008, 09:18 PM | #12 | |
That's the only "proper" way to go IMO.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 03-15-2008 at 09:19 PM. |
03-15-2008, 09:19 PM | #13 |
Mine's not run is series with my radiator, but I do have a derale pan that has cooling tubes in it.
When I start driving it more, I may route through radiator if I need (I have a tranny temp gauge hooked up)
72 Cheyenne SWB Fleet Nut & bolt frame off in progress...99.9999% - supercharged 383 - 4 wheel discs - relocated fuel tank - My Build Thread |
03-16-2008, 09:30 AM | #14 | |
18 Till I Die
Any more pics of that install???
2011 GMC Acadia 1969 GMC BBC LS7 2007 GMC Crew Duramax 1987 Camaro Iroc 350 Tuned Port Injection 42000Km 1987 Chevrolet Silverado 350 TBI 1987 Chevrolet Silverado 350 TBI(yes 2) Take me drunk, I'm too home... |
07-24-2009, 07:22 AM | #15 | |
If you are really curious as to the effectiveness of the unit, use a laser temp gauge and check the line going into the first unit, and then about a foot or so behind the second one. If there is no Delta, you wasted your money and time
1966 Chev C10 Custom LB Built 327ci, 700R4 Stage II, Mezier Elec Water Pump, Vintage Air, CPP Disks w/ABS, 22" Billets w/ Goodyear Eagle Low Pro's, Rear Pan, Hidden Hitch, Bagged |
07-24-2009, 09:36 AM | #16 |
Vintage Evil
I wonder if they would get enough airflow mounted inside of a side frame rail to do any good. Like on the one pic. I can see the others that are up front doing just fine.
07-24-2009, 12:29 PM | #17 |
That's right, it's Copper!!
Here's mine, it works great!
Tom: 1968 Chevy SWB ZZ383 W/700R4 Gen-II Compact Vintage Air System PPG paint, Mandarin Copper and Vanilla Shake. http://www.hubgarage.com/mygarage/fastom Stupid should hurt and eventually become fatal! |
07-24-2009, 12:37 PM | #18 |
I have never used one of these frame rail mounted coolers but I would be afraid of puncturing it or damaging it while driving and maybe losing all my trans fluid. However, I plan to take my truck out to the desert. Also, you need good airflow around the cooler to take away the heat. Also, I believe the fluid should go through the radiator first and then through the added on cooler for even more cooling of the fluid.
07-24-2009, 11:23 PM | #19 |
chevy truck fan
i was going to run the summit rectangular one in the same location that the others have (under the front bumper), but i got talked out of it by a friend of mine who thought that the location would get alot of road debris abuse. i was also looking into getting the inline frame one but did not for the same reason. i am currently running mine to the radiator cooler on the side. it is a 383 motor & a 700r4 tranny. what is the opinions of you guys that are running these types of coolers in relation to road debris & such????
