03-19-2008, 04:06 AM | #1 |
Help with a fuel inj. wire harness???
has anyone rewired a stock fuel injection harness to make it work in a blazer
(i no yhat i dont need the back 2 o2 sencors) ?? help if you can?? vortec 98 stock harness?? |
03-20-2008, 03:42 PM | #2 |
Re: Help with a fuel inj. wire harness???
It can be done but all the ones I've seen 'done' ended up so hacked it made ya wonder how they worked at all.
So your trying to install a '98 TBI set up on your blazer? Are you using the vortec heads/manifold assemblies? What about using an after market wiring harness? Have you looked into that? Makes for a pretty simple plug & play installation with one of those. What are you doing for fuel delivery? In-line electric pump or are you changing out the tank for one that has an in-tank pump and baffles? |
03-23-2008, 07:29 AM | #3 |
it is a vortec motor with a in line fuel pump with a regulator i was trying to save money on the harness i no every one makes a after market harness?? the tank was replaced with a bigger tank years back but wanted thinking about fuel inj at that time> i found a local company to reprogram the computer But was trying to find some one that has reworked the harness???
