Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 03-21-2008, 03:11 AM   #1
corn
96 4.3 wont start
I went to move my s10 today & it wont fire. Cranks & cranks. It has oil pressure when cranking so I know its not the sender. Ill try a cap, coil & plugs & see if that helps. I dumped a little gas in the TBI but not even a pop. Its got quite a few miles & I was a little worried about the timing chain, but the way it sounds on the net they dont go out very often. Any other ideas what to look for? Talk slowly, Im pretty dumb when it comes to the newer stuff. Todd?...Thanks...
corn is offline   Reply With Quote
Old 03-21-2008, 06:10 AM   #2
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: 96 4.3 wont start
Check for spark first. No spark? Ignition module is toast. Does the rotor turn when you crank it? If so then the timing chain is good. If the rotor is not turning during cranking, the timing chain is toast.
If the engine turns over fast like no load on it, the chain is my first guess.
Can you hear the fuel pump prime with the key on?
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 03-21-2008, 06:39 AM   #3
corn
Fuel pump primes. I havent had the cap off yet but will tomorrow. I held the pedal to the floor for bit & it coughed one time. Where is the module on a 96? It most definately needs a tune up either way.
Old 03-21-2008, 08:10 PM   #4
454_72_4X4
454_72_4X4's Avatar
My first guess would be spark plug wires if they haven't been replaced in a while.
Especially if the weather has been damp there like it has been here.
I'm not that familiar with the newer motors though.
72 C20 4X4 454 4 speed
89 Trans Am (was) 305 TPI 700r4
93 C1500 2wd Extended cab 350 700r4
98 Sonoma (TPI outa the Trans Am)
03 Yamaha 660 Raptor
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
454_72_4X4 is offline   Reply With Quote
Old 03-22-2008, 01:18 AM   #5
gchemist
gchemist's Avatar
Under hood, passenger side, upper engine area, mounted on front cylinder head below valve cover under ignition coil. Trace the coil wire back from the distributor. The ignition module is bolts to the same bracket as the coil.
The coild and ignition module are connected together with the small harness.
Old 03-22-2008, 01:19 AM   #6
corn
I called a mechanic friend today & he said he has been replacing a LOT of basic tuneup parts because of the humid weather. He also told me that the 4.3 isnt really known for timing chain issues & he gave me a list of things to check. I have to tint windows tonight so maybe Ill dig into it this weekend. I doubt its ever been tuned up, its gonna get one now...
Old 03-22-2008, 01:21 AM   #7
corn
Good, I was wondering where the module was. I was told today that they are known to go bad so Ill be looking that over too. Thanks everyone for the ideas...
Old 03-22-2008, 04:12 PM   #8
68C15
blood type; Retumbo
68C15's Avatar
they call that an ignitor. it has no logic, just a remote switch for the coil.
I can call you tonight.
68C15 is offline   Reply With Quote
Old 03-27-2008, 07:14 AM   #9
corn
Cap & rotor fixed it. They were both origionals yet...
