Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 04-16-2008, 07:33 AM   #1
68c10owner
68c10owner's Avatar
how big of a tire in stock wheel well?
How big of a tire are you guys stuffing the the stock wells? I`ve got a 62 but I`ve got a rearend from a 1973, just haven`t put it in yet. The truck will also be lowered with a 4/6 drop. I`m not looking to build a full time racer but i do plan to have a little fun racing once and a while and I want to be sure I don`t have traction problems.
Anthony
68c10owner is offline   Reply With Quote
Old 04-16-2008, 07:53 AM   #2
Super73
Super73's Avatar
Re: how big of a tire in stock wheel well?
I had a 275/50/15 in there before. i think you can get a 315 in it with the right wheel offset. Just not sure what offset/backspace you would need.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 04-16-2008, 07:57 AM   #3
68c10owner
68c10owner's Avatar
Thanks Super. My buddy ran 295/50/15 Hoosiers in his old 62 but he had a narrower rearend than what I`m running. It`s been at least 12-13 year now but I seem to remember it hooking pretty decent with the hoosiers but the truck was only running low 13`s with a 327 back then. I was thinking about some ET streets, maybe some 28x13.5?
Anthony
Old 04-16-2008, 07:59 AM   #4
Captainfab
60-66 Nut
I know that 295/50/15 will fit with whatever is std. back spacing on a 10" wheel.....4 1/4" maybe? Just remember that the '73 rear end is 1 1/2" wider than your '62 rear end.
Old 04-16-2008, 05:19 PM   #5
68c10owner
68c10owner's Avatar
Yeah thats why I`m asking. i know a 295/50/15 will fit on a 15x8 wheel with about a 4.5" offset using a stock width rearend but like you said, mine is 1.5" wider which is 3/4" per side.
Anthony
Old 04-17-2008, 05:42 AM   #6
djracer
djracer's Avatar
how wide is your rearend? I am putting a Explorer rear end in my little brothers 59. Its 60 wide with 3.73 gears a posi and 31 spline axles and disc brakes. I'm getting it for 250.00
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 04-17-2008, 05:46 AM   #7
Couch
Daily Driver
Couch's Avatar
on my stock width the 295 50 will clear but i had to cut for my 325/50 et streets. but well worth the cut.love those tires.
nitrous...the equal opportunity destroyer.
Couch is offline   Reply With Quote
Old 04-17-2008, 05:47 AM   #8
68c10owner
68c10owner's Avatar
I`m not sure of the actual measurment but it`s from a 73 chevy C-10.
Anthony
Old 04-18-2008, 10:02 AM   #9
PA-IndianRider
PA-IndianRider's Avatar
With "swap meet" season in full swing here in Pa. I'm going to be on the look out for some wheels & tires. I do plan to cut out the bed & add mini-tubs so I can run as wide a tire & wheel size as possible.
But as you know with buying at a swap meet you must be sure that what you buy is going to fit. Got "way to much" stuff laying around the workshop so I don't need to add to the pile!!!
I have seen some pretty large tire/wheel combos mentioned throughout this forum.... but being this truck
('70 C10 swb Stepside) is being setup for drag racing in addition to some limited street driving (oh yeah) I really want to maximize the wheel/tire combo for both "performance & looks"..... Thanks
John aka "Milner"
PA-IndianRider - Pittsburgh, PA
70 Chevy C10 Stepside
"Gasser/Altered Drag Race Hot Rod"
Where were You in '62 ?
PA-IndianRider is offline   Reply With Quote
