Old 04-19-2008, 08:19 PM   #1
lytemup454
lytemup454's Avatar
Some Assembly Required
well this my new truck i bought a few weeks ago. It's a 68 body on a 71 1/2 ton frame with a 70 drive train. It's got a 402 TH400 and a 12 bolt. nothing is bolted down core support bed hood, brake lines need to be hooked up and i'm missing shift linkage for the trany. i have a new windshield and an unmolested wireing harness. the body is in great shape the only rust is in the two rear cab supports but it's not bad at all and then the rocker of course. well enough babble here it is.
lytemup454 is offline   Reply With Quote
Old 04-19-2008, 08:24 PM   #2
IvelDesigns
Commander Taco Bello
IvelDesigns's Avatar
Re: Some Assembly Required
wow, great looking start there. What are you plans for it?
IvelDesigns is offline   Reply With Quote
Old 04-19-2008, 10:36 PM   #3
lytemup454
lytemup454's Avatar
thanks for under a G, i think it wasn't a bad deal i wish the motor was in better shape and i could use it. i really just want to get it running and on the road. like most of us i'm on less than a shoe string budget so i qwant to address all mechanical features rebuild power steering, Brakes suspension... then i want to do the truck arm conversion and a 5-7 ECE drop. as you know life has a way of changing plans so for now i want it to be safe and reliable
Old 04-28-2008, 08:15 PM   #4
lytemup454
lytemup454's Avatar
Angry Re: Some Assembly Required
well yersterday was alot of firsts for me i pulled my first motor and disasembled it. In the process i trashed the crank, i was useing the harmonic balancer puller and didn't use the point that goes in to the crank and wiped out the the threads. I've never used a pulled before and learned a very important lesson. So i'm going the see if it's possable to redrill and retap the threads for a bigger bolt but i'm not holding my breath. Any one in eastern oregon have a 396 crank LOL. also when i was pulling out my motor i noticed my heater box had some cracks in it does any one know how i can repair those? thanks
Old 04-28-2008, 08:19 PM   #5
68 short step
wow thats a heck of a throttle return spring.... nice start..
68 short step is offline   Reply With Quote
Old 04-28-2008, 08:43 PM   #6
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Nice little project ya got there...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 04-28-2008, 11:52 PM   #7
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Wow the interior looks amazing, good luck with the build!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
