Old 04-24-2008, 12:51 PM   #1
salrod00
salrod00's Avatar
02 silverado check engine light
i just purchased a regular cab with a v6 vortech motor in it. the check engine light is on and i went to three different autopart stores to check it out. the problem is that they cant even download the info into the code reader. they plug it in but the code reader doesnt even turn on. they told me to check the fuses and my wiring to see if something is disconnected or not. anyone has a clue why it would not send any signal to the code reader. the truck stall a little bit .
salrod00 is offline   Reply With Quote
Old 04-24-2008, 05:20 PM   #2
ed2552
ed2552's Avatar
Re: 02 silverado check engine light
There may be no power going to the Connector, may be a fuse, may be why the light is on, go to the fuse box on the side of the dash, and there should be a fuse there or in the engine compartment fuse box that says diagnostic or something like that
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs
72' GMC C2500, 350, TH400(?), Dana 60
'67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST!
'65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT!
09 Yukon Denali 82k Miles 6.2L/6A
ed2552 is offline   Reply With Quote
Old 04-25-2008, 01:21 AM   #3
salrod00
salrod00's Avatar
thanks man yeah it was a the fuse going to the cigar lighter. i found out that it is my coolant thermo sensor and 02 sensor. also one of my injectors is bad.. just my luck
Old 04-25-2008, 01:53 AM   #4
ed2552
ed2552's Avatar
Yeah, hate it when stuff like that creeps up on ya
